Re: Daily driver w/carb misses at 30-35 mph [Re: topside] #2932398
06/12/21 01:25 AM
06/12/21 01:25 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Originally Posted by topside
OK, so if I'm reading & understanding correctly:
Happens at a light decelleration, butterflies partially/mostly closed.
At that point, should have a pretty high vacuum reading, not pulling much fuel, no load.
Maybe it's a bit too lean @ cruise, or maybe advance weights are sticking (not sure what ignition you have).
When you say "missing", does it feel like chugging, or dropping the occasional spark, or like a burble from the exhaust ?
Happens when I pull back very slightly on the accelerator due to going down a very slight downgrade. I just pull back ever so slight on the pedal. I'm only pulling back about 5-10%.
Seems like it's loosing spark. The first time it did it I thought I was running out of gas for a second.
Re: Daily driver w/carb misses at 30-35 mph [Re: VITC_GTX] #2932435
06/12/21 09:51 AM
06/12/21 09:51 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Here's my WAG......
How old is the timing chain?
In my mind, I'm picturing when the engine is under load, you've taken up the slack in the chain, but when you 'let up' you're into the slack for a moment.
I had a 360 years ago with high miles on its original chain set, and it had several hesitation/stumble issues that went away with a new chain.
shruggy
John
Re: Daily driver w/carb misses at 30-35 mph [Re: VITC_GTX] #2932476
06/12/21 01:06 PM
06/12/21 01:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
[quote][/quote]Forgot to mention that is has aftermarket electronic ignition under the cap (no points).
Is this a conversion of the old distributor? If so make sure the ground wire from the breaker plate to the housing is intact and good. I had troubles with an Oldsmobile and the breaker plate would intermittently loose ground at various vacuum conditions causing a stumble. As the vacuum advance was working the plate it would loose ground. If it was removed add one and see if it helps.
Re: Daily driver w/carb misses at 30-35 mph [Re: NITROUSN] #2932506
06/12/21 02:12 PM
06/12/21 02:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by NITROUSN
Quote
had a Chrysler electronic ignition pickup coil break the wire internally once, that was a fun one to find wink beer
Re: Daily driver w/carb misses at 30-35 mph [Re: NITROUSN] #2932642
06/12/21 09:46 PM
06/12/21 09:46 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Old distributor with conversion.
Thanks for all the ideas guys. I had to help my daughter move into her first house today so I'll attack this tomorrow.
Re: Daily driver w/carb misses at 30-35 mph [Re: VITC_GTX] #2932729
06/13/21 09:27 AM
06/13/21 09:27 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Originally Posted by VITC_GTX
My daily driver (’57 BelAir 2dr hardtop). ... even though the carb was having issues, choke didn’t work well and was frequently idling high, accelerator pump didn’t work so it had a hesitation from a stop... I finally took the time to replace the carb with an Edelbrock 1403 (500 CFM with electric choke).
With the old carb the car would slightly miss at about 40-45 but you could barely feel it.
I’ve replaced the plugs..
This could have been an issue before I changed carbs as the last carb had issues that may have been masking other issues.
Thoughts on where to start?
How confident are you the old and new carbs are set up correctly? .. if you aren't confident, I'm tempted to suspect the carbs..
Can you repeat the problem with the car sitting in your driveway and you manipulate the throttle?
If you can, watch the carb throats and see what the fuel is doing.. Flooding or leaning out?
Or do you HAVE to be on the road.. ?
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Daily driver w/carb misses at 30-35 mph [Re: 67SATisfaction] #2933390
06/14/21 10:36 PM
06/14/21 10:36 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
lLol. Not laughing at you but with you. Had the Cyclone's engine rebuilt and bought a really nice Quickfuel carb. Nope, that seemed to just go dead at about 2500rpm. Installed a dyno mule Holley that we knew was right, boom, same freaking thing. Finally went with a Holley Sniper EFI system and that took care of the problem. Where was the problem? Not a clue as we replaced the billet distributor, AL box, coil, etc all with Holley gear. Cost plenty to finally get the car running right. Hate to say it but carbs are going to be a thing of the past. Why? Fewer and fewer folks know much about them. Seems like only yesterday that I bought the barracuda and Bee but coming up on 20 years now. I'm will to wager the number of folks that understand(I do) carbs and can fix them(not me apparently) has taken a 50% drop in that time.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Daily driver w/carb misses at 30-35 mph [Re: klunick] #2933397
06/14/21 10:59 PM
06/14/21 10:59 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I used to rebuild a lot of carbs back in the day, I was the carb rebuild guy in the shop. Its a lot harder to find a good quality carb to rebuild these days because most are getting quite old, throttle bushings are getting bad on most cores. Many of the "new" carbs are not up to the quality the ones from the 60s -early 80s were (and those 80s carbs were very good either), and the current kits leave a lot to be desired as well.
The last vehicle I owned with a carb on it was wrecked in 2011 (nothing to do with the carb). Everything is now EFI and I won't be going back to carbs. Gene
