Optima
#2930457
06/06/21 10:00 AM
06/06/21 10:00 AM
Posts: 16,148 Mesa, Arizona
dart4forte
Mesa, Arizona
Have a new Optima Redtop. I know that Optimas are sensitive to charging. During the hot summer months down here in the desert SW I like to keep my battery on a battery tender. Anyone have experience with this?
Abe Lincoln
Re: Optima
[Re: dart4forte]
#2930474
06/06/21 11:30 AM
06/06/21 11:30 AM
Posts: 732 Michigan
BlueRacer69
I'm in Michigan, have the same Red Top battery as you in my BB Dart. Its now 4 yrs old and still cranks over like the first day I got it. I keep mine on a Battery-Minder charger at all times, unless the car is going to be driven some place. Hope this answers your question.
Re: Optima
[Re: topside]
#2930706
06/06/21 11:29 PM
06/06/21 11:29 PM
Posts: 16,483 On the run…
BloFish
On the run…
I was under the impression that they had to be charged a special way.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: Optima
[Re: BloFish]
#2930725
06/06/21 11:50 PM
06/06/21 11:50 PM
Posts: 10,215 Someplace you aren't
SomeCarGuy
When they get really low the charger doesn’t sense them. Have to hook at regular battery up to it so it will take charge. As long as they aren’t way low they take charge.
I want my fair share
Re: Optima
[Re: BloFish]
#2930754
06/07/21 06:20 AM
06/07/21 06:20 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Whatever charger you use make sure it has a setting for AGM batteries and use that setting.
The 4amp Optima charger is a great value at around $100. It can charge 4 amps and it is a maintainer as well, it also tells you what it is doing on this display which is nice. I have never used the larger optima charger but I am sure it is good as well.
68 Barracuda Formula S 340
Re: Optima
[Re: Bad340fish]
#2930815
06/07/21 10:46 AM
06/07/21 10:46 AM
Posts: 43,560 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I put a lead acid battery in series with the Optima then it charges just fine. That way you also have two charged batteries!
JB Rhinehart, Realist
A-Body's RULE!
Re: Optima
[Re: Rhinodart]
#2930829
06/07/21 11:21 AM
06/07/21 11:21 AM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
I put a lead acid battery in series with the Optima then it charges just fine. That way you also have two charged batteries! Important correction: You put a lead acid battery in PARALLEL with the Optima.....
Re: Optima
[Re: Pacnorthcuda]
#2930933
06/07/21 03:20 PM
06/07/21 03:20 PM
Posts: 6,224 JERSEY
RJS
JERSEY
I have a yellow top that I just charged on my 25 year old Sears charger on the 2amp. setting. It took about 12 hours but worked great. Ron
Re: Optima
[Re: SomeCarGuy]
#2932007
06/10/21 02:50 PM
06/10/21 02:50 PM
Posts: 86 Alabama
WarEagle1
Alabama
When they get really low the charger doesn’t sense them. Have to hook at regular battery up to it so it will take charge. As long as they aren’t way low they take charge. Concur with this. ^^^ I have a 6 yr old RedTop in my Cuda (seldom driven). It used to run down from sitting and had trouble getting it to take a charge. I keep a Schumacher tender on it now (for several years) and it keeps it topped off. No issues.
