Back Spacing Calculation #2928082
05/29/21 12:51 PM
05/29/21 12:51 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So my Cuda has 15x15 wheels with 5" back spacing. It has 31x16.5 hoosier DOT pros on it.....
I want to put a set of 315 drag radials on it with a 12 wide rim. My calculation says I only need 2" of back spacing....And now I can't find any rims with that spacing only 3.5" BS....
Re: Back Spacing Calculation [Re: Dragula] #2928095
05/29/21 01:13 PM
05/29/21 01:13 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
New rear I’m afraid. Really hate the tucked in deep wheel look (5” between tire and fender)
Re: Back Spacing Calculation [Re: Dragula] #2928099
05/29/21 01:25 PM
05/29/21 01:25 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I believe RC Components has a 2" backspace rim. They are pricey but they are nice.
Ok
Re: Back Spacing Calculation [Re: Dragula] #2928110
05/29/21 01:47 PM
05/29/21 01:47 PM
AndyF Online content
AndyF  Online Content
That is correct if you want to take all of the width off the backside of the rim. You can pull the whole tire in close to the center of the car by splitting the difference. It is really just about looks since performance should be the same.
Re: Back Spacing Calculation [Re: Dragula] #2928174
05/29/21 03:30 PM
05/29/21 03:30 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Holeshot offers 2.5" BS on 12" wheels
Re: Back Spacing Calculation [Re: RTSE4ME] #2928325
05/29/21 09:42 PM
05/29/21 09:42 PM
Dragula Offline OP
Dragula  Offline OP
So is my math correct?
Re: Back Spacing Calculation [Re: Dragula] #2928411
05/30/21 09:10 AM
05/30/21 09:10 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Yes, the 12" wheel with 2" BS will be the same distance to your fender as your current wheel.
If you want the wheel more tucked in get more BS just don't get black wheels
Re: Back Spacing Calculation [Re: RTSE4ME] #2928469
05/30/21 12:12 PM
05/30/21 12:12 PM
Dragula Offline OP
Dragula  Offline OP
I like those, and price is competitive....I might go with those because if I add a bead lock, I want to be sure to clear the fender
Re: Back Spacing Calculation [Re: Dragula] #2928475
05/30/21 12:24 PM
05/30/21 12:24 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
If you go with beadlocks you might want to contact McFab. They can add a 1/2" to the front or rear spacing. When I did mine I added 1/2 to the rear, wish I had added 1/2" to the front also. My rims are now 12.5.i run 29.5x11.5w. it would flatten out the sidewalls a little.
Ok
