Re: Clover leaf removal Indy intake [Re: HardcoreB] #2900715
03/19/21 12:56 PM
03/19/21 12:56 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
Thank you all for the input. At this point I have started the porting. I have removed the majority of the cloverleafs and I and going to cut back the two dividers like Wilson did in Andy's intake. I will not be extending them due to the fact that I cannot Aluminum weld and do not really have the budget to have someone else do it. Unfortunately, my comparison will not be real scientific. based on a completely different engine combination. But like my late dad used to say "God hates a coward!" So I am letting the chips fly!!!!!! What is the worst thing that can happen? I screw up a perfectly good intake! LOL!
Also I would post pictures but launching the space shuttle remotely from my phone is easier than posting picks on this site.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: Clover leaf removal Indy intake [Re: 451Guy] #2900719
03/19/21 01:03 PM
03/19/21 01:03 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by 451Guy
... I and going to cut back the two dividers like Wilson did in Andy's intake. ...
Yes GOOD...if you measure the divider-wall length, you will have a gage to make them all the same length. This is similar to what Wilson did. Most of my time spent IIRC was 'port-matching' because as i remember it, it was all over the map BAD. Also as evident by the latest data...LEAVE A BURR FINISH in the manifold.
Re: Clover leaf removal Indy intake [Re: 451Guy] #2900896
03/19/21 08:38 PM
03/19/21 08:38 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
What type /tool/blade you use to cut out the clover ? bawling i would of like to see pictures of how this was done.
Re: Clover leaf removal Indy intake [Re: racerx] #2900941
03/20/21 12:59 AM
03/20/21 12:59 AM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
I used a 4 inch aluminum cut off disk in a grinder. The one I used was slighty used to reduce the diameter a little. I cut wide if that makes sense. I then did some rough shaping with a file. Then i started to conture with a aluminum rotary burr. Now i am still trying to figure out how I am going to trim the runner divider!
Thanx 451 Guy
Re: Clover leaf removal Indy intake [Re: 451Guy] #2900988
03/20/21 08:24 AM
03/20/21 08:24 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
I'm looking for the results, been thinking on this mod for a few days now.
Re: Clover leaf removal Indy intake [Re: 451Guy] #2900999
03/20/21 09:13 AM
03/20/21 09:13 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I'm sure someone here has a good answer to that, its hard to get down in there. Wilson cuts your intake in half to port and then welds them back together. Mine didnt have the dividers.
Re: Clover leaf removal Indy intake [Re: 451Guy] #2908472
04/09/21 05:53 PM
04/09/21 05:53 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
bump Didn't what this to get lost any updates on this?
Re: Clover leaf removal Indy intake [Re: 451Guy] #2908599
04/10/21 05:59 AM
04/10/21 05:59 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We've used an early 4500 440-3 that appeared to be just a plunge cut, 4150 version. It was cut in 2 horizontally, the clover removed, welded and blended. We eventually swapped that out for a 440-3X both these manifolds had distribution issues with cylinders # 1 & 2 running leaner than the rest. We improved this with an old school trick of grinding a couple of grooves at the entry to the runners of 1 & 2.
Re: Clover leaf removal Indy intake [Re: Tig] #2908618
04/10/21 07:59 AM
04/10/21 07:59 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
This is a new intake I got last week untouched . just to show what the new one are like.
Re: Clover leaf removal Indy intake [Re: VernMotor] #2927994
05/29/21 09:35 AM
05/29/21 09:35 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Any updates on this thread?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Clover leaf removal Indy intake [Re: 68 HEMI GTS] #2928018
05/29/21 10:24 AM
05/29/21 10:24 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
bump for this ? work
Re: Clover leaf removal Indy intake [Re: racerx] #2937173
06/27/21 07:45 AM
06/27/21 07:45 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
bump bump Don't let this get lost coffee
