Page 3 of 3 1 2 3
Re: F-150 Lightning returns [Re: not_a_charger] #2927260
05/27/21 01:52 PM
05/27/21 01:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You can easily multiply TQ with gear ratios, not like it can do anything a gas engine can't. 400# Tq at the flywheel with 2.00 rear gear ratio would give you 800# TQ, 3.55s like most trucks have makes that 400# into 1420# not to mention transmission gear multiplication and converter multiplication. On the other hand you can not multiply HP, it is what it is and a truck with 500+HP is fun. I am curious at what percentage of discharge does it no longer make the rated HP number? Will it only make that HP at 100% charge? Will it still do that at 10% charge?
Re: F-150 Lightning returns [Re: not_a_charger] #2927360
05/27/21 06:08 PM
05/27/21 06:08 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
Originally Posted by not_a_charger
Ford put out a bulletin this week about being careful to avoid exposing their EVs and hybrids to excessive heat, which is causing concerns about the paint process in the collision repair industry. It will be interesting to see what's done to ensure proper refinishing if shops can't use the bake cycle on their booths at the temps they normally would.
if you ask me this is total BS.
when i bake a car it's at 145 for 40 min. in all reality the temps of the non exterior sheetmetal doesn't get that high.in my opinion they barely hit 100. the sheetmetal gets to 140 for about 15 min at most.
cars in the south regularly hit those temps and higher when they sit out in the sun all day.
I'm glad you replied. I thought it was interesting that, in the day and age of OEM repair procedures being emphasized (and rightfully so), that Ford would put out this statement. The statement itself is somewhat vague, and is likely a CYA move, as opposed to a "You must/must not fix the vehicle this way."
for the most part it's just CYA.
another angle i have heard in PPG paint school training some really high volume production shops bake at much higher temps with shorter baking times. this allows them to paint more cars in a shorter amount of time.
i have heard they bake at 175* for 10 min to heat up the metal then drop it down to 150 for 20 min. i have heard from others they start out at 160 for 5 min. then crank up the heat to 190 for 10 min. then drop down to 140 for another 5 min and they are done baking.
i have tried the 175-150 method and didn't care for it. it seems to solvent pop easier. and the clear isn't cured like i like it before buffing. it seems like the top is cured but the under coat still seems soft unless you let it sit for a couple of hours before buffing. in my situation this delay is counter productive. the 10 min shorter bake is wasted sitting around for 2 hours before buffing. i like to bake for 40 min, cool off for 5 min then start buffing. i can have the car buffed and 1/4-1/2 of assembly done before they start buffing.
at those higher temps i can see damaging the electronics and other things. i could see myself baking a EV at 120 for 50 min. this is how i bake CNG cars that aren't supposed to be baked.
i guess time will tell.
perception is 90% of reality
Re: F-150 Lightning returns [Re: HotRodDave] #2927516
05/28/21 07:02 AM
05/28/21 07:02 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I believe they are like your cell phone. It works like normal then it turns off when the battery dies. Kinda of like a gas vehicle, its fine...until its not.
68 Barracuda Formula S 340
Re: F-150 Lightning returns [Re: Bad340fish] #2927605
05/28/21 11:40 AM
05/28/21 11:40 AM
Home
SRT6776 Offline OP
I hate internal combustion engines!
SRT6776  Offline OP
Home
Interesting, the 300 mile range is from the EPA which includes 1000lbs of cargo on board. The truck with just you in it is 367 miles
Re: F-150 Lightning returns [Re: SRT6776] #2927614
05/28/21 11:58 AM
05/28/21 11:58 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Watched that earlier. LOVE that guy's videos.
Earning every penny of that moderator paycheck.
DBAP
Re: F-150 Lightning returns [Re: not_a_charger] #2927686
05/28/21 02:12 PM
05/28/21 02:12 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
That was an excellent video. Yeah, I'm sold.
Re: F-150 Lightning returns [Re: MarkZ] #2927802
05/28/21 05:49 PM
05/28/21 05:49 PM
hooziewhatsit Offline
Right? shock That truck looks pretty darn good.
300 miles with 1k of cargo is a pleasant surprise.
Re: F-150 Lightning returns [Re: hooziewhatsit] #2927906
05/28/21 10:32 PM
05/28/21 10:32 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
The frunk is pretty impressive too - very handy!
Ride eternal, shiny and chrome
Page 3 of 3 1 2 3
