I need to go just a little faster looking to hit 7.0 in 1/8
#2927233
05/27/21 01:04 PM
05/27/21 01:04 PM
Posts: 95 Cumming Georgia
cspracer
Cumming Georgia
I am currently running a 1970 Plymouth that weighs around 3120 lbs. The car consistently runs 7.15 in the 1/8th. I would like to get the car down to run in the 7.0 index class, so I am looking at a few options and would like to hear peoples opinions. Here is my current setup: 440 engine Heads - 906 ported w/1.81 & 2.14 valves Competition Cam - solid .525 lift, 248 duration, 110 Lobe Sep Intake - Weiand Team G Carb - 1050 Holley Dominator Headers - Hooker Comp 1 7/8 Coil - MSD Blaster Ignition - MSD 6AL Dist - MSD Pro Converter - TCI Gear - .488 ratio posi Tires - Hoosier 29x10x15
The car has been run a good bit and seems to be a 7.15 car with what I have. I have a few options, so I wanted to see what you think.
I have a set of Edelbrock E-Street Heads, closed chambered 75cc that I was putting on another car. These would save some weight, and I would have to go to the 2" headers. Would these heads & bigger headers get me to 6.9-7.0, or do I need to do something different?
I am also considering going to Hoosier radials instead of my current bias tires. Anyone make this swap pick up any ET?
I also have a .456 gear spool I could slide in vs. the .488.
Any other suggestions on how to get a quick and easy 20-25 HP?
1968 - 383 Roadrunner 4 speed street car, Dad bought new 1970 - 440 Roadrunner drag footbrake car 6.99 1/8th 2016 - Hemi RAM 1500 - Hauls all the toys North Georgia / Central NC
Re: I need to go just a little faster looking to hit 7.0 in 1/8
[Re: cspracer]
#2927262
05/27/21 01:54 PM
05/27/21 01:54 PM
Posts: 19,548 north of coder
moparx
here is a bump for you. way back in my NU-BE days, we thought the trick to quick times was 4:88, 5:13, and 5:38 gears, no matter the tire size. well, 10.00, 11.00, and 12.00 x 15 were the tire sizes normally in use. anyway, fast forward to the last time i had my charger out, [2006-2007, then back in storage it went] i dumped the 5:38's and installed 3:91's. the engine was not touched other than fresh gas and new plugs. it went within 1 tenth of the 5:38's best time. not sure what that means, but you might want to try your 4:56's or maybe even 4:30's. the heads and headers you mentioned couldn't hurt. i would certainly give them a try if it were me, and i don't know anything..........
[Re: moparx]
#2927268
05/27/21 02:08 PM
05/27/21 02:08 PM
cspracer
Cumming Georgia
Thanks Bob. Talking to Hoosier they seem to think for bracket racing the bias tires are better than the radials, more consistent and last longer. When I stopped racing 10 years ago, this car was way better than the driver at consistency!
[Re: B1MAXX]
#2927272
05/27/21 02:22 PM
05/27/21 02:22 PM
moparx
i think CAB has said for years, 2" headers work way better than 1 3/4 or 1 7/8". [if and] when i get my charger going again, i have a set of 2" to 2 1/8" step TTI headers i'm going to use on my 446. it has ported RPM's, 11:1 compression, and .590 purple cam, with a 4500 converter. the car has 3:91's in it now, but i may step up to 4:10's or 4:30's, depending on what size tire i go with. i'm hoping that combination might make my car a fun ride, even though it weighs a bunch.
[Re: DusterKid]
#2927307
05/27/21 03:51 PM
05/27/21 03:51 PM
cspracer
Cumming Georgia
I believe the converter is a 3500 stall. The chamber of the 906 has not been altered, so I assume since they are open chamber, there would be some compression gain with the Edelbrocks. The flow of the906 is probably close to the stock Edelbrocks since these were professionally ported. You are correct the two areas I think heads would help is more compression and lighter weight. I just run the 1/8th, and getting a consistent 7.0 is fast enough for me. Any faster and I will start breaking everything behind the motor. Dad ran 6.65 with a hotter 440 and we broke everything from the engine back!
The other thing I am considering is simply swapping the cam for a slightly bigger one. I know that can be a rabbit hole, but I am probably running more carb than I need now, so a little bigger cam might get me there.
Thanks for the input.
[Re: B1MAXX]
#2927310
05/27/21 03:56 PM
05/27/21 03:56 PM
cspracer
Cumming Georgia
I hear mixed messages on headers. I have to believe 2" is better than 1 7/8, however that is not the cheapest option as most 2" headers cost close to $1000 or more. Seems like a cam swap could be done for less.
If I change to the Eddy heads, I will have to go with the bigger headers anyway since they have angled plugs and you can not get a plug in with smaller headers on it.
Thanks for your input and suggestion. I will let everyone know what I end up going with and how I eventually get there.
[Re: cspracer]
#2927312
05/27/21 04:02 PM
05/27/21 04:02 PM
Posts: 3,237 Md.
carnut68
Md.
What TeamG intake are you running 4150 or Dominator?
America First!
[Re: topside]
#2927313
05/27/21 04:06 PM
05/27/21 04:06 PM
cspracer
Cumming Georgia
This car is a race car and I cut a lot out of it years ago. Doors have been cut, glass in doors remove and Lexan installed, hood and trunk supports all have been removed, so the 3120 is legit, but I can not remember if it included me as a drive or not! I need to get it weighed again, since that weight was in 2001. I have done more to the car since, including putting an aluminum water pump and housing.Not much left to reduce unless I start buying a lot of fiberglass. Only running about a 1.5 gallon fuel tank!
1/8th mile trap speed - 96 mph 60' - avg 1.63 min 1.51 Shift at 5800 rpm Rev Limit at 6400 so I never go this high Usually the shift light is on when I go through the finish line, so I would say I am hitting 5900-6000 rpm at the line.
[Re: carnut68]
#2927315
05/27/21 04:07 PM
05/27/21 04:07 PM
cspracer
Cumming Georgia
I am running the dominator Weiand Team G, not the 4150. I also have two spacers, each about 1" below the carb.
[Re: cspracer]
#2927317
05/27/21 04:11 PM
05/27/21 04:11 PM
Posts: 1,113 Usa
A39Coronet
Usa
Radials...and going a size or two smaller (a 7.15 car doesn't need a 10" tire) may put you there.
Do you have E85 in your area?
[Re: VernMotor]
#2927319
05/27/21 04:15 PM
05/27/21 04:15 PM
cspracer
Cumming Georgia
The Eddys I bought are the closed chamber 75cc. Bought them for that reason.
[Re: A39Coronet]
#2927320
05/27/21 04:16 PM
05/27/21 04:16 PM
cspracer
Cumming Georgia
We do have E-85 here.
So you think going with a 9" radial would pick up the ET?
[Re: cspracer]
#2927335
05/27/21 04:51 PM
05/27/21 04:51 PM
Posts: 3,237 Md.
carnut68
Md.
The 906s I had were 91cc. A solid FT might get you there. A good 4200 convertor wouldn't hurt. To bad you couldn't snag a 557 or 528 cam and lifter package they offered a few years ago for 200 bucks from Jegs. It would be nice cheap experiment.
America First!
[Re: carnut68]
#2927336
05/27/21 04:54 PM
05/27/21 04:54 PM
cspracer
Cumming Georgia
The 557 cam is the one I was looking at. I figured the 528 would not be much different than what I have now @525. Cams are kind of hard to come by these days.
[Re: cspracer]
#2927340
05/27/21 05:14 PM
05/27/21 05:14 PM
Posts: 3,237 Md.
carnut68
Md.
The 557 cam is the one I was looking at. I figured the 528 would not be much different than what I have now @525. Cams are kind of hard to come by these days. I bought the 557 and the 590 both with lifters for 400 bucks about 7 years ago. I know the 528 has an outrageous price. What's the 557 going for? My car ran 11.41 @117 with the 557 and a 3800 T/A with 3.91s and 9 in ET streets. TorkerII intake and 950 Holley. Put the 590 in it and it went 11.28 @ 119.
America First!
