Re: Timing Chain Tensioner: Yay or Nay?
[Re: tmef]
#2926515
05/25/21 03:09 PM
05/25/21 03:09 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Never used one yet. Just something else that can cause problems so spend the money xtra money towards a better chain set.
[Re: pittsburghracer]
#2926541
05/25/21 04:05 PM
05/25/21 04:05 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Evrytime I take a motor apart, even after just a little while, the chain is as sloppy as a pie eating contest. So I tried the tensioner on my stroker 392 Hemi for the drag Week car. I was skeptical, expecting to see shavings of plastic in the oil and trenches dug into the plastic guides. But nope. Timing was steady, and when I pulled it apart there was zero wear on the tensioner guides. I'd do it again.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2926655
05/25/21 09:14 PM
05/25/21 09:14 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Evrytime I take a motor apart, even after just a little while, the chain is as sloppy as a pie eating contest. So I tried the tensioner on my stroker 392 Hemi for the drag Week car. I was skeptical, expecting to see shavings of plastic in the oil and trenches dug into the plastic guides. But nope. Timing was steady, and when I pulled it apart there was zero wear on the tensioner guides. I'd do it again. I used one on a 340 build but also used a crankshaft oil slinger and the oil dripper on top oil hole it was A-Ok when pulled down many years later
[Re: scratchnfotraction]
#2926788
05/26/21 10:27 AM
05/26/21 10:27 AM
Posts: 1,073 oregon
greendart408
oregon
I have never ran them on anything, until I was putting together my daily driver mid 12s deal in my 69 dart on the cheap for fun. Double row chain was super loose. Aka junk, I put one on and 13,500 miles later with 3 cam swaps it looks brand new. The timing is rock solid steady. My chain isn't the smooth chain either. Just my real world experience.
[Re: tmef]
#2927278
05/27/21 02:49 PM
05/27/21 02:49 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I installed the tensioner into my LA SB about a year ago... and noticed that the oil slinger was hitting the bottom of the tensioner... AFTER I had the assembly all setup (degreed, etc). That was not good to see the slinger cocked at an angle against the tensioner!
So, I carefully ground the bottom of the tensioner (using a Dremel) so to give about 1/8" clearance. So far, engine runs great! BUT... I'm a bit worried about the tensioner. I used a PRO GEAR double roller chain setup that I bought from Hughes, as well as purchased the tensioner also from Hughes.... I later spoke to them about it (interference problem)... they said that they'd never heard of that matter... but also.. that the tensioner was never made to fit the LA engines... only the MAGNUMS (V6 and V8).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2927295
05/27/21 03:18 PM
05/27/21 03:18 PM
Hemi_Joel
Minnesota
It wasn't made to fit an early Hemi 392 either, but with a couple mods, I made it work. BTW, this is a great topic.
[Re: moparx]
#2927306
05/27/21 03:51 PM
05/27/21 03:51 PM
Hemi_Joel
Minnesota
I did end up putting a gear drive in it. Not that I had any issue with the chain/tensioner. I figured it was going to be a problem, so I ordered the gear drive after the motor was together. I probably should have done it in the first place. Project creep turned this motor into a lot more than originally planned.
[Re: MR_P_BODY]
#2927702
05/28/21 02:28 PM
05/28/21 02:28 PM
Mopar Mitch
The tensioner wasnt made for the double roller chains.. it was designed for the silent chains.. I have used then in my LA builds a couple of times but normally I run a gear drive set up(far better)...
THIS SHOULD BE ADVISED BY THE MOPAR RETAILERS!... USE AT YOUR OWN DISCRETION!
Mopar Mitch
[Re: tmef]
#2927717
05/28/21 02:56 PM
05/28/21 02:56 PM
Posts: 1,761 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I tossed the MP one into my 360 build some 10 yrs ago. After 10 summers of occasional use, so 10K of the typical weekend driving, I recently tore the motor down as I started to build the W2 stroker replacement.
My combination was using the Sealed Power 220-3103 chain, which is a double roller.
Anyways, off everything went, no wear, no problem. The chain was on pretty tight after all these years, and I have always found my ignition timing to be absolutely solid, no jumping around, etc.
I will be putting the very same tensioner back on my stoker...although I've always wondered if I should be tossing the crank oil slinger into that mix???
[Re: tmef]
#2929253
06/01/21 05:53 PM
06/01/21 05:53 PM
Posts: 15,487 Florida
scratchnfotraction
Thanks all. I am gonna run it. It's brand new and I always use an oil slinger and drip tab. I bought a parts truck once that had a 318 in it. The owner said it just quit running one day. I pulled it apart to find the timing chain so loose it had eaten the entire drip tab away as Scratchn said earlier. It was after that it finally skipped teeth and quit running. I am overkill with oiling mods on my LA junk. I drill block/cap/pump to 1/2" add 4 extra holes in oil filter plate and galley feeds to 9/32" run full groove main bearings/windage tray, add 1/4" drain back holes in-between lifter bores, drill a hole in the oil galley plug/thrust plate to help oil chain. early LA engines had a hollow bolt on the thrust plate to oil chain. I do the same when adding a tensioner. If I use the stock oil cooler off the police car/engines I do not drill galley plug/thrust plate or bolt to oil chain as the cooler dumps oil back to the pan thru a hollow fuel pump bolt oiling the chain with cool oil returning to pan. I just use a drip tab and crank slinger with cooler. also the police engines used a HD double row chain & gears stock but oil it with cool return oil for longevity. windage tray & full groove main bearings = more oil to rod bearings along with #1 & #4 cam bearings have oil groove for full time oiling to rockers. I have yet to find a replacement set of cam bearings with #4 bearing having the oil groove. but I have 4 police engines that have them. I have the machine shop cut the cam journal instead. Ma Mopar would not have done these mods if they do not improve longevity in severe duty engines... so is it really over kill? on a side note.. when I look to buy a tensioner I do shop ebay for early NOS Mopar tensioners for v6 engines. and try not to use the AZ/advance store cheapy on the shelf brands form china. seems to be better quality that way. good luck
#2929723
06/03/21 10:50 AM
06/03/21 10:50 AM
Mopar Mitch
Regarding sourcing the tensioner, I believe there is is only one manufacturer of it... every distributor gets the exact same one... no differences (other than marketing).
Mopar Mitch
