Page 2 of 3 1 2 3
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: moparjim79] #2922113
05/13/21 01:40 PM
05/13/21 01:40 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Originally Posted by moparjim79
Tell us what you're using them for
They are being used to attach a steel liftgate system to an aluminum trailer.
I need the flush head sex bolts so they can mount the steel flange to the aluminum tube, and then install sheeting, or trim over to hide the fasteners from view. Its much more aesthetically pleasing than a bunch of bolts sticking through the side of a trailer.
I want to use grade 8 because of their hardness, and shear strength properties. Stainless might work, but its not the same as grade 8.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2922121
05/13/21 02:13 PM
05/13/21 02:13 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Have you enough material thickness to prevent pull through after countersinking? What electrolysis prevention measures are you taking?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: 3hundred] #2922127
05/13/21 02:29 PM
05/13/21 02:29 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Yes there is plenty of thickness, and the holes through the tube are slugged so it can't collapse. The aluminum is a custom double hollow with 0.3125" wall, the steel flange is 1/4" plate.
We will use the same electrolysis prevention as is used to attach steel axle subframes to aluminum trailers, or steel tongue, gooseneck, kingpin, and A frame couplers.
This isn't something being built in my backyard.
I was hoping there was a diverse enough occupational background among the members to help source a piece of hardware that I had not ever tried to locate before.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2922199
05/13/21 06:47 PM
05/13/21 06:47 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
What you are actually looking for are countersink bolts with Allen heads? We get all out stainless from Applied. McMaster-Carr probably has what you need too.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: slantzilla] #2922244
05/13/21 09:25 PM
05/13/21 09:25 PM
Cleveland, OH
TWS Offline
TWS  Offline
Cleveland, OH
OK, I had to google "sex bolts" to see what they were, and holy cow! This is what I have been looking for high and low, calling up fastener vendors all over the place with no luck. I had never heard of the term before. The thing that is disappointing is that with all of the specialty fastener companies all over the country that were contacted, none had ever seen what I was showing them in the pics.
So, thank you hp383 for posting this question...my fastener quest has likely been solved; quite a variety of potential sources out there.
Parts Wanted - Challenger SE Trim Screws
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: TWS] #2922257
05/13/21 09:46 PM
05/13/21 09:46 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
OMG! 40+ years in the structural steel business, countless AISC, RCSC, TSSI meetings and I've NEVER heard the term before. I really thought it was a typo for hex bolts and was nonplussed when he mentioned countersunk. Never too late to learn something new.
'69 300 Convertible
'16 300 S Hemi
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2922288
05/13/21 11:47 PM
05/13/21 11:47 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Note, electrolysis concerns are greater between SS & Alum than Alum and steel, contrary ro what most think.
Seems to me the fastener design sought would have a difficult time achieving a typical marked grade 8 rating, or the needed clamping load.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sniper] #2922290
05/13/21 11:49 PM
05/13/21 11:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by Sniper
Originally Posted by jcc
Not sure you can find stainless in grade eight, or sex bolts in grade eight for that matter.
https://www.mcmaster.com/sex-bolts/...ng-barrels-and-screws-for-door-hardware/
Nope - you can't. I don't think you can harden stainless, even though it's already hard. No way stainless is grade 8. When you need grade 8, you need grade 8!
17-4 Stainless is available and very comparable strength wise to typical grade 8, and far superior to typical grade 2 stainless fasteners.
Physical Properties:
Melting Point: 2560 - 2625°F (1404 – 1440°C)
Density: 0.282 lbs/in3 / 7.8 g/cm3
Modulus of Elasticity in Tension: 28.5 X 106 psi / 197 GPa
Mechanical Properties:
Condition: Solution Treated (A)
Tensile Strength Minimum (psi): 160,000
Yield Strength Minimum 0.2% offset (psi): 145,000
% Elongation in 2” Typical: 5%
Hardness: Rockwell B85
Condition: Hardened + Aged (TH1050)
Tensile Strength Typical (psi): 200,000
Yield Strength Typical 2% offset (psi): 185,000
% Elongation in 2": 8%
Hardness: Rockwell C35
Condition: Aged (H1075)
Tensile Strength Typical (psi): 175,000
Yield Strength Typical 2% offset (psi): 165,000
Hardness: Rockwell C37
Condition: Aged (H900)
Tensile Strength Typical (psi): 210,000
Yield Strength Typical 2% offset (psi): 200,000
% Elongation in 2": 7%
Hardness: Rockwell C45
For reference sake, its likely double the cost of typical SS.
Irrelevant if no one makes sex bolts in 17-4 stainless.
Ouch.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sunroofcuda] #2922363
05/14/21 09:07 AM
05/14/21 09:07 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
These what you're after? When it comes to grading bolts not all types are graded in the conventional numeric way. Particularly when you're dealing with socket heads.
https://spaenaur.com/catalog/B200/#zoom=z
Guess these aren't what you're after, huh?
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: jcc] #2922384
05/14/21 09:49 AM
05/14/21 09:49 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
True, back in my sailor days I at one time used to refurbish satellite communications antenna. Aluminum castings held together with "CRES" bolts, which is what the Navy calls stainless steel, as in corrosion resistant. Every bolt hole in the aluminum was helicoiled and liberal amounts of antisieze was used to help prevent corrosion. It was very easy to tell when antisieze was not used, because you had to fix the resultant broken off bolt.
Be sure to account for the antisieze's different lubricity and it's effect on the torque values.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sunroofcuda] #2922825
05/15/21 01:46 PM
05/15/21 01:46 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Yeah - sex bolts?
wasn't that a rock band in the 80's? laugh2
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Stanton] #2923214
05/16/21 06:50 PM
05/16/21 06:50 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Originally Posted by Stanton
Quote
Thank you but no, those are socket head cap screws. Sex bolts are a different product.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: jcc] #2923218
05/16/21 06:58 PM
05/16/21 06:58 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I do not want a stainless steel fastener. I know that stainless steel and aluminum do not play well together.
I don't know why many replies seem to assume that is what I am looking for.
I am only able to find stainless steel. But want just a normal grade 8 fastener, possibly zinc coated, or black oxide, the finish isn't my main concern.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2923219
05/16/21 07:00 PM
05/16/21 07:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So all along I thought you meant "hex" bolt but your last reply got me curious so I GOOGLED "sex bolt" . Well Good luck finding those things in grade 8 !!! I doubt they even come in Grade 2 !!! The head would be the weak point.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Stanton] #2923220
05/16/21 07:02 PM
05/16/21 07:02 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I have found them in grade 5
So I will keep hunting.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2923268
05/16/21 09:01 PM
05/16/21 09:01 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"I can find them in 18-8 Stainless, but I would really like to have Grade 8." quoted from your opening post.
This could be understood that you wanted grade 8 Stainless, and you have now cleared that up.
I am surprised you found Grade 5, Good luck in your quest.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2923329
05/16/21 10:50 PM
05/16/21 10:50 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
In your original post where you said
Quote
Prefer to find a tapered seat style for a flush mount.
is part of what confuses people to what you want since it looks like the sex bolt isn't designed to be flush where a flat socket head bolt IS designed to be flush.
Yes, you could make the sex bolt flush, but it doesn't look like it has a tapered seat under the head.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: SNK-EYZ] #2923489
05/17/21 01:09 PM
05/17/21 01:09 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Quote
They are available in button head and tapered seat from most sources. The problem is finding a larger diameter, in a grade 8 steel.
It may not be available, and if that is the case I will look into other means of fastening the lift gate side posts to the trailers.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2923501
05/17/21 01:43 PM
05/17/21 01:43 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Okay, when I searched sex bolts it showed ones that weren't flat socket head style, more like a button head.
I only see them in stainless in the sizes and type that you're looking for.
https://www.mcmaster.com/sex-bolts/flat-head-binding-barrels-and-screws/
https://www.boltdepot.com/Sex_bolts_Socket_flat_head_Stainless_steel_18-8.aspx
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sniper] #3097579
11/27/22 04:02 PM
11/27/22 04:02 PM
Seattle
LarryJoew Offline
LarryJoew  Offline
Seattle
I suppose that you should tell us where you want to order it. Update, I didn't say that they won't be able to make the shipping in some particular state or something; I just asked to know which websites to advise you. There are a huge number of variants for you; I just wanted to find something more affordable and near you. The best option at this point for you is https://www.scrooz.com.au/nuts-and-bolts/ website, selling many different bolts and stuff for construction and reparation. Be sure that you find the right one and pick all the options correctly to avoid mistakes and problems after shipping.
Page 2 of 3 1 2 3
