Page 7 of 8 1 2 3 4 5 6 7 8
Re: Mancini Selling Callies Blocks [Re: sasquatch] #2920845
05/10/21 05:24 PM
05/10/21 05:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
A song comes to mind:
Rich H.
Esse Quam Videri
Re: Mancini Selling Callies Blocks [Re: ZIPPY] #2920854
05/10/21 05:30 PM
05/10/21 05:30 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Yes the drain backs are clearly a hemi thing but I am not sure if it matters. I have seen some of the earlier Mopar wedge blocks with drain holes. Does not seem to hurt anything. I remember one vividly as it had a machine tool broke off in it!!! ON a wedge no worries on a hemi big problem.
Todd
Re: Mancini Selling Callies Blocks [Re: sasquatch] #2920868
05/10/21 06:20 PM
05/10/21 06:20 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Zipster, do you think the price will come down? Or the quality go up?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Mancini Selling Callies Blocks [Re: Hemi_Joel] #2920893
05/10/21 07:22 PM
05/10/21 07:22 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Your guess is as good as mine, Joel!
Callies has a good reputation for quality... I'd think they'd take care of these "minor issues"
and leave the price where it is.
Rich H.
Esse Quam Videri
Re: Mancini Selling Callies Blocks [Re: ZIPPY] #2920912
05/10/21 08:20 PM
05/10/21 08:20 PM
Mo.
racerx Offline
racerx  Offline
Mo.
What is the price on these Callies? And do they make it in the short decks?
Re: Mancini Selling Callies Blocks [Re: racerx] #2920922
05/10/21 08:38 PM
05/10/21 08:38 PM
Maryland
MoparMike1974 Offline
Maryland
The block was $4800 plus shipping and tax.
Yep, the top row of head bolts were not drilled and tapped. Have to call and get this resolved.
Thanks for the heads up on the hemi oil drain back holes. I had no idea what they were there for. Not sure why they put them on an RB. They are drilled straight through to the sump and are not covered by the head.
Ship weight was 340# so around 320 sounds right for the block.
Yes, the rear main has alignment dowels installed.
Re: Mancini Selling Callies Blocks [Re: MoparMike1974] #2920990
05/10/21 10:44 PM
05/10/21 10:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Sorry if I was unclear, the dowel revision was actually in the seal retainer.
All 5 main caps were doweled from day one, but the seal retainer was only doweled towards the end of Chrysler's engineering involvement
with the product.
The head bolts and drainbacks are just errors.
I know I speak for many here when I say, if you'd take the time
to report how they take care of you, we'd sure be interested to know.
Best of luck to you.
Rich H.
Esse Quam Videri
Re: Mancini Selling Callies Blocks [Re: ZIPPY] #2920996
05/10/21 11:05 PM
05/10/21 11:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I guess how this “should” be taken care of will differ depending on who you ask.
Imo, how it should be handled is a call tag is sent to pick up the block, and a “non-defective” unit should show up as it’s replacement.
I look at the hemi oil drain holes there as something that would classify that one as a “blem”...... which would be sold as such, at a discounted price, with the buyer aware of it......... and that’s after the head bolt hole situation has been rectified.
Re: Mancini Selling Callies Blocks [Re: fast68plymouth] #2921001
05/10/21 11:18 PM
05/10/21 11:18 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Callies is aware of the problem, however they just found out like today. I am sure that steps will be taken to resolve the problem quickly.
Re: Mancini Selling Callies Blocks [Re: sasquatch] #2921004
05/10/21 11:29 PM
05/10/21 11:29 PM
Maryland
Maryland
Yes, the rear main seal retainer has dowels. I forgot to type the word seal smile
Re: Mancini Selling Callies Blocks [Re: sasquatch] #2921012
05/11/21 12:32 AM
05/11/21 12:32 AM
AndyF Online content
AndyF  Online Content
Someone at the factory got their CNC machining programs mixed up between Hemi and Wedge. They'll need to inspect all the blocks on the floor to figure out when the program got mixed up and how many blocks were made wrong. Hate to see stuff like that get out the door. Costs 10x as much to fix once the parts leave the dock.
Re: Mancini Selling Callies Blocks [Re: AndyF] #2921093
05/11/21 10:16 AM
05/11/21 10:16 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
We all make mistakes but it's nice to know there's no quality control whatsoever. How does the QC man sleep at night? His services are worth nowhere near minimum wage.
2011 Drag Pak Challenger
Re: Mancini Selling Callies Blocks [Re: fast68plymouth] #2921105
05/11/21 10:55 AM
05/11/21 10:55 AM
NW Illinois
MoonshineMattK Offline
NW Illinois
Originally Posted by fast68plymouth
Quote
I'm looking for the upper row of head bolts and can't see them.
Uuuuuhhhh.........
I’m also wondering how deep those hemi head oil drain back holes go(and why they’re there at all).
What else is different between a HEMI and wedge block? Other than upper head bolts and the oil drain? Could this block just get the HEMI upper bolt position drilled and be used as a HEMI block?
Re: Mancini Selling Callies Blocks [Re: AndyF] #2921122
05/11/21 11:32 AM
05/11/21 11:32 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Costs 10x as much to fix once the parts leave the CNC machine. Once it's moved off the setup, it takes some work to get it dialed in again. They should rebate some of the cost of the block to compensate, say half price?
Floyd Lippencott IV
Re: Mancini Selling Callies Blocks [Re: mr_340] #2921125
05/11/21 11:33 AM
05/11/21 11:33 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It would be better to have them send another block.
Re: Mancini Selling Callies Blocks [Re: MoonshineMattK] #2921131
05/11/21 11:49 AM
05/11/21 11:49 AM
Quote
Uuuuuhhhh.........
Not sure about the motor mounts. They would need to drill and tap the Hemi mounts and maybe machine off the ears? I'm not sure what the process is for these blocks. In any case, if the buyer thought he was buying a wedge block and it was sold as a wedge block then someone at the factory messed up. They either pulled the wrong block off the line or something else went wrong. I'm sure they'll figure it out but it is a bad start.
Re: Mancini Selling Callies Blocks [Re: AndyF] #2921147
05/11/21 12:34 PM
05/11/21 12:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
For whatever reason, there seems to be a lot of drama with anything to do with replacement blocks for BB/Hemi Mopars.
Re: Mancini Selling Callies Blocks [Re: fast68plymouth] #2921171
05/11/21 01:39 PM
05/11/21 01:39 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Quote
You are so right
Re: Mancini Selling Callies Blocks [Re: MoonshineMattK] #2921194
05/11/21 02:01 PM
05/11/21 02:01 PM
Fl
Superlead Offline
Superlead  Offline
Fl
Quote
Uuuuuhhhh.........
The Hemi block has eight steam holes near the lower head bolt holes. The wedge block does not have these steam holes. The block pictured above is correct for a wedge block and does not have the Hemi steam holes.
The wedge industrial blocks had these steam holes.
Re: Mancini Selling Callies Blocks [Re: Superlead] #2921311
05/11/21 06:43 PM
05/11/21 06:43 PM
NW Illinois
NW Illinois
Do you have a picture of the steam holes? I've not seen them before.
