Re: Speedometer cable lube [Re: B1MAXX] #2920862
05/10/21 05:59 PM
05/10/21 05:59 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Okay got it out. It pulls out from the speedometer end it just took a little persuasion and then it slid right out. I guess after close to 40 years it’s bound to be a little stuck. There’s a little collar on that and it stops it from being pulled from the other end I just couldn’t see it down in there. As I mentioned it is a NOS cable and it definitely had grease on it. But it was kind of dried out from all the years so I wiped it clean and I use the Napa lubricant. Time for install and these aren’t the easiest to get to being that they insert to transfer case. I have to do things in baby steps… Time permitting LOL. Thanks for the help.
Facts are stubborn things.
Re: Speedometer cable lube [Re: B1MAXX] #2920896
05/10/21 07:25 PM
05/10/21 07:25 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Originally Posted by B1MAXX
says speedo cable right on it, -20 to +600f shruggy
Sorry, jumped right past that reply. Yes, I own a tube of that I bought for a brake caliper rebuild project. It's thin enough that I think it would be good to try.
