Re: Tire Chain Recommendations
[Re: resqguy]
#2919638
05/07/21 11:07 AM
05/07/21 11:07 AM
Posts: 3,427 PA
PLATINUM6BBL
PA
V-bar tire chains and make sure they are of the cam lock style so you can get them tighter. If it is soft soil I don't know how much you'll really gain though as it is the front tires sinking that causes the "resistance" to make the rear tires break loose. Might be time to look at Alturnamats 4x8 treaded poly sheets.
1969-1/2 A12 LOH Road Runner A4 w/ M6S 13.34 at 104 PSMCDR 9/06 in Mopar Action 8/07 12.95 at 105.94 F.A.S.T. 11/06
[Re: resqguy]
#2919641
05/07/21 11:11 AM
05/07/21 11:11 AM
Posts: 10,755 North Dakota
6PakBee
North Dakota
To install the chains, or whatever, I was planning on jacking up the axle. The tire is only about an inch in the ground. What kind of ground are you in? Only an inch down and the tires are spinning? Such things as boards or ramps or whatever are great to get you onto solid ground if you are stuck. But what do you do when you get to the next foot of dirt that's just like the last foot? Some kind of traction aid on the tire seems warranted.
