904 Torque Flight Decoding #2918536
05/04/21 04:50 PM
05/04/21 04:50 PM
E
earlymopar Offline OP
E
I've looked in several places on the internet and haven't located anything that is real specific about decoding the stamped numbers on 904 and 727 transmissions. Attached is what I have as far as a 904 and am simply trying to determine year and model this is from.
Thanks.
Re: 904 Torque Flight Decoding [Re: earlymopar] #2918541
05/04/21 04:59 PM
05/04/21 04:59 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Day 7263 is Tuesday, June 16, 1981
10,000 day calendar
Re: 904 Torque Flight Decoding [Re: 6bblgt] #2918567
05/04/21 05:40 PM
05/04/21 05:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Lock up converter? Should be.
Re: 904 Torque Flight Decoding [Re: 6bblgt] #2918600
05/04/21 06:48 PM
05/04/21 06:48 PM
E
E
Thank you. This must have been the original transmission in my dad's 1981 Dodge D150. Other than "904", what other model designation would there have been? Is this simply a $100 core or is there any other interest in this for other applications?
Re: 904 Torque Flight Decoding [Re: earlymopar] #2918887
05/05/21 02:06 PM
05/05/21 02:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's a lockup A-999 from behind a 318.
Re: 904 Torque Flight Decoding [Re: John_Kunkel] #2919288
05/06/21 12:11 PM
05/06/21 12:11 PM
Locomotion Offline
Locomotion  Offline
Just curious, but anything to indicate a 2.74 low gear?
Re: 904 Torque Flight Decoding [Re: Locomotion] #2919329
05/06/21 12:54 PM
05/06/21 12:54 PM
A727Tflite Offline
A727Tflite  Offline
This trans left Kokomo as a L/U, 4 pinion front and rear carrier, 4 disc front and rear clutch, and this part number Remained in use to 1985.
I can’t find the build chart but my best guess is that it was a low gearset trans.
Re: 904 Torque Flight Decoding [Re: Locomotion] #2919332
05/06/21 01:00 PM
05/06/21 01:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That part number was used from '81-'85 so it likely has the low gear set.
Re: 904 Torque Flight Decoding [Re: A727Tflite] #2919390
05/06/21 03:38 PM
05/06/21 03:38 PM
A727Tflite Offline
A727Tflite  Offline
This trans was actually a 999. The only units back then that didn’t get l/u were high altitude applications.
