alternator frozen only with belt tension? #2917404
05/01/21 03:21 PM
05/01/21 03:21 PM
North Central Florida
E
eightlitermopar Offline OP
E
1971 Plymouth roadrunner, 383 engine. Newer stock style alternator bought and has been sitting for 18-24 months while I have been getting it up and running again.
Long story short, I got the engine started yesterday.
The alternator spins free by hand with no belt tension. The belt tightened and it is locked solid.
Started the car and the belt was spinning but alternator would not turn. It squealed and smoked the belt.
Took off the very hot belt and the alternator spun with no problems by hand again. Water pump pulley is also free and spins effortlessly.
I have another alternator in my stash, but I was wondering if anyone has ever seen anything like this before. It's a first for me.
eightlitermopar
Mopar or no car
Re: alternator frozen only with belt tension? [Re: eightlitermopar] #2917413
05/01/21 03:46 PM
05/01/21 03:46 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
bad bearing
Re: alternator frozen only with belt tension? [Re: ek3] #2917579
05/02/21 08:58 AM
05/02/21 08:58 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Is the alternator charging?
Re: alternator frozen only with belt tension? [Re: 6PakBee] #2917586
05/02/21 09:20 AM
05/02/21 09:20 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
How would it charge if it's locked up?
Re: alternator frozen only with belt tension? [Re: eightlitermopar] #2917616
05/02/21 10:48 AM
05/02/21 10:48 AM
Midwest
MoparsnMissiles Offline
Midwest
Took off the very hot belt and the alternator spun with no problems by hand again............
............ but I was wondering if anyone has ever seen anything like this before. It's a first for me.
eightlitermopar
Yes, I've seen this very problem. Its quit simple but not obvious to everyone.
When you have the belt off, all the mounting bolts are loose and the alternator spins normally.
When you tighten the belt, you now have tightened the mounting bolts to hold the alternator in place and keep the belt tight.
Well, IF YOU DON'T HAVE ALL THE CORRECT SPACERS between the ears of the alternator and between the alternator and the head, you are now squeezing the ALTERNATOR CASE together enough that it locks up the rotor of the alternator.
I'd put money on the fact that you are missing one or more of the correct factory spacers for the alternator bolts.
Re: alternator frozen only with belt tension? [Re: MoparsnMissiles] #2917621
05/02/21 10:55 AM
05/02/21 10:55 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
eightlitermopar
^^^^^^^^^ yup
Re: alternator frozen only with belt tension? [Re: Sniper] #2917649
05/02/21 12:12 PM
05/02/21 12:12 PM
North Dakota
North Dakota
Sigh. If the OP is in the car, starts the engine, and from the driver's position hears the belt squealing and then shuts the engine off to investigate, how do we know it's not just an overloaded alternator? It's just a question, Christ, lighten up.
Re: alternator frozen only with belt tension? [Re: Wirenut] #2917670
05/02/21 01:05 PM
05/02/21 01:05 PM
moparx Offline
moparx  Offline
eightlitermopar
^^^^^^^^^ yup
a BIG 10-4 ! i have had many experiences with this happening !
beer
Re: alternator frozen only with belt tension? [Re: MoparsnMissiles] #2917853
05/02/21 09:42 PM
05/02/21 09:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
eightlitermopar
Also the single locking bolt on the adjustment arm, if it's too long it will hit the vanes on the rotor and lock up the alt....DAMHIK
Re: alternator frozen only with belt tension? [Re: moparx] #2917857
05/02/21 09:47 PM
05/02/21 09:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Squiring the case is a pretty high possibility.
One other thing I've seen was the bolt that tightens the alt to the slotted adjusting bracket is too long. When its tight, it protrudes into the case too far and stops the armature from spinning. Often times, a second flat washer between the head of the bolt and the adjusting slot is enough to make it work, but a shorter bolt is a better option. Putting a couple washers under the bolt head would give a pretty quick answer as to how much shorter that bolt may need to be.
At any rate, without the belt in place, you need to tighten up both bolts and try to spin the alt. Then loosen one of the two bolts at a time to see which one, or if both bolts are the problem. if its not a bolt problem, the next bet would be a bad bearing, but you should be able to see the pully move in the case if a bearing was the problem. Gene
Re: alternator frozen only with belt tension? [Re: poorboy] #2917872
05/02/21 10:13 PM
05/02/21 10:13 PM
E
E
Thanks for the input guys! I was chasing an electrical short when I got the new alternator 2 years ago.
I may have messed up when putting the new alternator on. I will investigate tomorrow and let everyone know what I find.
Thanks for the heads up!
eightlitermopar
Mopar or no car
Re: alternator frozen only with belt tension? [Re: DAYCLONA] #2917883
05/02/21 10:56 PM
05/02/21 10:56 PM
Midwest
Midwest
eightlitermopar
It sure will, thanks, I forgot about that little possibility. Done that in the past also.
Re: alternator frozen only with belt tension? [Re: MoparsnMissiles] #2918045
05/03/21 02:38 PM
05/03/21 02:38 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I have seen when the power is on the field that it also locks up the alternator, try it all unplugged and disconnected from any power.
Re: alternator frozen only with belt tension? [Re: AARCONV] #2918180
05/03/21 08:24 PM
05/03/21 08:24 PM
E
E
Alright, update:
It turned out it was the bolt squeezing the "ears" together, which was causing the alternator to lock up. My old alternator had no issues, but the new alternator casting was slightly wider, and the spacer was more "sloppy" with enough play to allow this to happen.
I placed a washer next to the spacer and it worked fine.
However, the long arm adjustment bolt hole was "wallered out". So instead of tapping for a bigger bolt, I put my old alternator back on and it runs great.
I did notice that the alternator is charging at 15 volts, but maybe it was just charging a slightly drained battery. I replaced my voltage regulator with one I had laying on the shelf, but that one only would increase from 12.6 up to 12.63 with the engine RPM's raised and the amp meter on the dash was jumping around.
Long story short (and a discussion for another thread most likely), I returned the original regulator to its proper place and its charging again, although a little high. I'll dig into that later.
It was the bolt squeezing the alternator case and locking up the belt. I have never had the privilege of experiencing that before.
Thanks for the help, I really appreciate it.
Eightlitermopar
Mopar or no car
Re: alternator frozen only with belt tension? [Re: eightlitermopar] #2918187
05/03/21 08:39 PM
05/03/21 08:39 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thank you for following up on the results and resolution.
That really helps others that might get in same situation or prevent it from happening.
Re: alternator frozen only with belt tension? [Re: autoxcuda] #2918310
05/04/21 08:35 AM
05/04/21 08:35 AM
North Dakota
North Dakota
Yes, thanks for closing the loop. up
Re: alternator frozen only with belt tension? [Re: eightlitermopar] #2918337
05/04/21 09:48 AM
05/04/21 09:48 AM
Missouri
randavis Offline
randavis  Offline
Missouri
How about putting a heli-coil in it?
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: alternator frozen only with belt tension? [Re: randavis] #2918394
05/04/21 11:53 AM
05/04/21 11:53 AM
moparx Offline
moparx  Offline
thanks for the follow up ! up
those case holes are easy to helicoil. i have done several.
beer
