Re: Do pre 1967 Mopars have a ported vac advance port on carb
[Re: ragtop]
#2916602
04/29/21 04:10 PM
04/29/21 04:10 PM
Posts: 3,916 usa
lewtot184
usa
[Re: cudaman1969]
#2916852
04/30/21 08:51 AM
04/30/21 08:51 AM
Posts: 1,340 VA
dragon slayer
VA
No mopar had manifold ported vacuum for distributor...wait for it.. What does this statement even mean?
[Re: dragon slayer]
#2916862
04/30/21 09:23 AM
04/30/21 09:23 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
No mopar had manifold ported vacuum for distributor...wait for it.. What does this statement even mean? I think he's waiting for a typical moparts argument to break out? I'm interested in the answer as well, I'm not old enough to remember when or if direct manifold vacuum was used. I_think_ported vaccuum started in the emissions era but don't really know.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2916880
04/30/21 10:08 AM
04/30/21 10:08 AM
Posts: 15,527 Omaha Ne
TJP
Omaha Ne
Ported vacuum comes from a small opening / passage that is slightly above the primary throttle blades at normal idle opening IE: 750 or so RPM with no radical camshafts that require more throttle opening at idle speeds. As the throttle blades begin opening during acceleration the air passing by the opening begins drawing air (vacuum if sealed of hooked up to a non leaking vacuum advance. This is known as the venturi effect. See pic below. the red indicates air flow, the blue vacuum. As the throttle blades are opened, more air passes by the port and the vacuum increases adding more advance. So there is no vacuum available at idle speeds . Manifold vacuum ion the other hand is highest when the throttle blades are closed ( depending on camshaft) as the pistons are trying to draw air/ fuel against a restricted opening (the throttle blades). However it drops rapidly on acceleration due to the throttle blades opening. As one reaches cruising speed and the blade opening in relaxed the vacuum then returns to a higher state. Which is better? I'm not going to open that debate. To my knowledge Chrysler used ported vacuum in most applications. That may have changed during the emission years. hope this helps ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
![Name: venturi effect.jpg
ID: 425703 venturi effect.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/425703/filename/venturi effect.jpg)
[Re: 3hundred]
#2916939
04/30/21 11:38 AM
04/30/21 11:38 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
No mopar had manifold ported vacuum for distributor...wait for it.. What does this statement even mean? I think he's waiting for a typical moparts argument to break out? I'm interested in the answer as well, I'm not old enough to remember when or if direct manifold vacuum was used. I_think_ported vaccuum started in the emissions era but don't really know. I started working in service stations in 1961, I remember a lot of the early GM cars had manifold vacuum advance back then, hence the disconnect the vacuum advance and plug the fitting instructions before setting the timing ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) As far as I can remember now all Mopars engines I worked on had ported vacuum advance, all of them ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: dragon slayer]
#2917001
04/30/21 02:04 PM
04/30/21 02:04 PM
3hundred
Colleyville
The info Cab furnished jibed with what I'd gleaned over the years. It seemed the older guys, the chev centric guys, all asserted manifold vacuum was the "correct" way to hook up vacuum advance to the point they'd arbitrarily change it to manifold on whatever car they were working on even if it didn't come that way. By the time I started my mechanic years (1973) mid '60's cars coming into the shop was a bit of a rarity, let alone earlier ones. At that time cars 5~10 years old made up the bulk of junkyard denizens which made parts for my '68 readily available cheaply.
[Re: Sniper]
#2917166
04/30/21 10:05 PM
04/30/21 10:05 PM
3hundred
Colleyville
Well my 51 Plymouth has ported vacuum stock Were they still using hard plumbed lines then or had they gone to rubber hoses by then?
[Re: 3hundred]
#2917246
05/01/21 08:16 AM
05/01/21 08:16 AM
Posts: 6,325 nowhere
Sniper
nowhere
Well my 51 Plymouth has ported vacuum stock Were they still using hard plumbed lines then or had they gone to rubber hoses by then? Hard line from carb to vacuum canister, as is the 52 Dodge 230 I bought to build and hot rod.
[Re: Sniper]
#2917344
05/01/21 01:02 PM
05/01/21 01:02 PM
Posts: 19,629 north of coder
moparx
i'm not going to start a debate here. everything was ported up to around 74ish [?], then, if i REMEMBER correctly [???] there were trees on the rear of the intake manifold that went to a vacuum "enhancer", then to a temperature sensor in the water pump housing, then to the carb, then to the distributor and vacuum pots controlling the air filter snorkel flaps. i just looked at a 440 out of a 78 newyorker, and a 400 from a 76 newport [both with thermoquads] that are on my shelf, and that is the way they have the myriad of vacuum hoses ran. they were this way when removed, and i just left everything as was just to keep the holes plugged. i "think" this started in 74, because i remember the round multi-port "vacuum enhancer" on the china wall of my wife's 74 charger with a 400/727 combo. remember, this is for the big blocks. i don't remember, nor have, any small blocks to compare. so manifold through temperature [wax pellet] senders to ported. i don't know what this setup could be correctly categorized. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2917585
05/02/21 09:19 AM
05/02/21 09:19 AM
Sniper
nowhere
i'm not going to start a debate here. everything was ported up to around 74ish [ The OP specifically asked about pre 67. Why bring up the newer stuff?
[Re: Sniper]
#2917667
05/02/21 12:55 PM
05/02/21 12:55 PM
moparx
because it was stated previously that there was never manifold vacuum used. your point could also be used about 30's and 40's engines, as well as the steel and rubber lines. i was just offering a little more to the story, sorry if i rubbed you the wrong way. please accept my apology. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: dragon slayer]
#2917979
05/03/21 11:50 AM
05/03/21 11:50 AM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
No mopar had manifold ported vacuum for distributor...wait for it.. What does this statement even mean? Wait for all the know it alls (keyboard jockeys) to claim otherwise.
[Re: NANKET]
#2917982
05/03/21 11:55 AM
05/03/21 11:55 AM
cudaman1969
fredericksburg,va
Short answer is yes there is a ported vacuum connection on carbs before 67. I have a 62 383-2bbl, and a 62 413-4bbl both have it done in rubber hoses. 1960 413-4bbl has it with a hard steel line. Not for distributor advance
