Page 2 of 3 1 2 3
Re: 440 MPG? [Re: mgoblue9798] #2913180
04/21/21 09:48 PM
04/21/21 09:48 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The biggest thing you can do to help a 440 is slow down the RPM either by reducing speed or gearing higher and locking the converter, higher gears don't do much if you just slip the converter more. If your building a motor than run as much compression as you can get away with, enough compression to require premium fuel helps MPG enough to cover the extra cost in fuel, any tricks to permit more compression helps also like a source of fresh not underhood air, air gap style intake with no crossover, tight quench with closed chamber heads, fully radiused and polished exhaust valves, sodium filled if you can find them, ceramic coated exhaust under the hood retard cam timing a few degrees. An 850 thermoquad (800 gets into the secondaries too much even cruising) done by someone who really knows how to tune it will do better than a holley. Very little if any cam overlap and as much lift as possible heck some 1.7 rockers on a stock cam would work great. Well tuned spark timing (they like a lot 20 idle, 40WOT 50 or more cruise). Run a 3 angle valve job on the intake to break up fuel droplets.
I know I will get flack from old timers on this but I used to always try to run smallest ports I could find for my MPG motors but eventually found out it didn't help in reality and just killed any chance of getting a few RPM out of a motor (probably the only reason they ever APPEAR to help is you CAN'T turn any RPM), actually the opposite as I have hemi heads that flow 330CFM on my 2011 ram and it can get 20 on the highway empty. I would even run a maxwedge port on that and the longest runner, matching intake manifold I could find.
Re: 440 MPG? [Re: HotRodDave] #2913205
04/21/21 10:43 PM
04/21/21 10:43 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Some good ideas but just a couple points.
Gearing higher in my rv build will be done with gear vendors od. I am not so sure about using a lockup converter for heavy RV or something that is towing heavy loads. I have not been able to locate a gas unit with more than a single clutch. There are modern converters being built now that stall at 1100-1200 rpm behind a 440. I think that is a better choice in terms of durability.
I am building a 440 six pack pistons near zero deck, 413 closed chamber heads with sodium valves from ma mopar. Will work out to right at 9 to 1. At least 2 points better than from the factory. Not sure what gas prices are in your area, but 93 premium here is about 70 cents higher that regular 87 at about 2.20 a gallon. When stuff was only 20 cents a gallon more, I could see making up the difference in cost. I don't see any way to make up a 30% higher fuel cost though.
Agreed on the 850 thermoquad to try to run on the primaries as much as possible. All big block intakes are "air gap" design. Maybe I should fit a tunnel ram under the doghouse? grin I will get the thermoquad dialed in using a wide band O2 sensor. I think I am going to put a bung in each header tube to be able to measure what individual cylinders are doing. Might be time to play with some epoxy and popsicle sticks. I know I can't get it perfect, but can at least prevent a too lean condition in one or more of the cylinders. I am going to send the headers to get jet hot coated after fitting and welding the bungs.
On a carb build, wouldn't oversized ports make for lazy flow, poorer mix, increased chance for detonation, and less throttle response? The 413 heads have small block sized ports- intake is a little taller than the intake port on a EQ head I have, and small 1.88 / 1.50 valves. Your hemi with multiport injection is an entirely different animal.
I'll be running a modern profile cam Mike Jones designed just for the 440 motorhome engines. 112 centerline, duration at 202. but .455 lift with 1.5 ratio and only 40 degrees overlap at the seat, and -19 at .050. Just my two cents, but I would rather spend the money on the cam than the rockers.
Dual snorkel cold air, polishing piston tops, chambers, and valves will be done. Heat is the enemy running a big block in an RV. Plan to run some electric fans, a triple flow radiator, and aluminum intake with the crossover blocked to try to keep it cool.
Re: 440 MPG? [Re: mgoblue9798] #2913402
04/22/21 12:52 PM
04/22/21 12:52 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
I say NAY to the blocked crossover WITH the 413 heads.
And YEA to water injection up
Re: 440 MPG? [Re: mgoblue9798] #2913405
04/22/21 12:59 PM
04/22/21 12:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I used to try to run the 302 casting high swirl heads on my MPG small blocks, but then one time tried the 308 milled to closed on a zero deck 318 motor and MPG jumped up quite a bit, on another 440 for a friend we swapped on some eddelbrocks in place of the 516 and mpg jumped up. A third was a 99 durango (I know EFI...) we put on a set of RT heads and his 5.9 and mpg jumped up a lot so I gave up on the small port theory (since then I have found the magnum is way happier and efficent with big ports especially in the pushrod pinch RT RHS Eddy...). I think when the piston starts sucking through a very small well designed valve curtain area (sharp valve edges, no shrouding...) the fuel is va-poo-rized and atomized as it's sucked through there very fast then as well as the high vacuum lowers boiling point of the hydrocarbons so what's happening in the port is not that important as long as it's not a flow restriction. I used to argue with my grandpa for years about how he was wrong because of port velocity when he would tell me they would maximum port a cylinder head and get much better MPG (1970s), till I started trying it myself after he was gone and found out the old man wasn't so dumb after all. I think it's one of those things that is great in theory but not reality. The only thing it (very small ports) really does is act like a governor. Use the cam timing and compression to keep vacuum very high instead of a restricted port size.
Heck even a 906, 452, 915 BB head is barely if any any better than a magnum or X head. Those 413 motor home heads are way too small.
I would seriously get a lock up converter, especially if you make a very high tq motor in a motor home with a gear vendor, non lock up is gonna generate a TON of heat in the trans and lose a lot of efficiency, then you also don't have to compromise on the stall speed you need to get that big rig moving. They are not un-reliable, I have re-built hundreds of those trannys (727, 904, a-500, 518 and REs) with lock-up and never seen any big issues caused by lock up.
As for compression, you could easily add another point maybe two if you get everything else just right with premium fuel. It seriously helps MPG, TQ, HP... I did a 318 with flat tops and magnum heads milled .030 and .029 piston to head clearance and it helped that little motor dramatically in every way (99 1/2 ton long bed ex cab with a slide in camper). That was the only mod, even put the cam, old rings and bearings back in after zero decking the block to get a true comparison.
Re: 440 MPG? [Re: HotRodDave] #2913424
04/22/21 01:45 PM
04/22/21 01:45 PM
Florida STAYcation
Florida STAYcation
HRD .. remember... this combo is nearly 10,000 lbs and is as AERO as a barn door
Re: 440 MPG? [Re: HotRodDave] #2913532
04/22/21 05:26 PM
04/22/21 05:26 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
HRD I am going to build a high compression 11 to 1 340 for my challenger, but I am not comfortable building something with compression on the ragged edge for an 27 foot rv that I will be towing a car through the mountains. I am building it to run on cheap swill, with a backup plan to run premium if required at times. If it wasn't for the sodium valves, quench, and center located spark plug in the heads am not sure I would even push it to 9 to 1.
Reliable no trouble service is first goal, then followed by mileage and increased torque. Full time premium costs just don't add up to savings at any rate. Bumping compression a point or even two from 9 to 10 or 11 to one is not going to net 30% increase in fuel mileage, but it will cost 30% more (minus whatever increased efficiency realized is) at the pump.
Those 413 heads flowed enough to make 445 ft lbs at 2000 rpm in factory trim. That with a compression ratio that in reality is less than 7 to 1. You may very well be correct about the ports, but I am going to find out what this combo is capable of doing. No comparison between the 413 water pump and cooling capacity and the regular 440 stuff.
With your 318 you mentioned, any idea what compression ratio you wound up at with those mods? Guessing it was at 11 to 1 with the block decked and heads cut that much.
Re: 440 MPG? [Re: mgoblue9798] #2913575
04/22/21 07:13 PM
04/22/21 07:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I don't know if I have the exact number saved anywhere but yes I think it was around 11 to 1, still didn't ping audibly on 87 octane pulling a 65 dart on an open trailer up those big passes coming out of LA in the heat. Premium wasn't even needed in that thing. Ultra tight quench really works to keep down knock. I would liked to have pushed it higher but you can't mill a magnum any more than that without getting into the intake valve seat.
My current daily driver is a 4 door 4wd ram with 6.4 SRT8 short block with eagle heads, that has very high compression also around 11.5 I think and not very tight quench but does need premium and gets 20mpg doing 75 on the highway. Right now I am building a 6.4 SRT8 long block with 5.7 eagle cam for my 2011 ram 2500, I am going to zero deck the pistons to bump compression, (already milled the heads .020 to get closer to the eagle chamber size) and quench on this one, and am running the BGE head this time (same ports as SRT8 butt with faster heat conducting aluminum alloy and sodium ex valves) this truck will replace the current 1500 and I expect nearly the same MPG.
Re: 440 MPG? [Re: HotRodDave] #2914410
04/24/21 04:46 PM
04/24/21 04:46 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Couple of questions for you sir. If port size has so little to do with mileage and driveability in a carb application, then why do larger port single plane intakes kill the bottom end on street motors? Again only talking carb motors here.
Also, based upon your experience would there be a difference in running .030 v/s .040 quench in my engine? I guess it would depend upon how much more piston rock my 4.35 bore short block has if I can get by with that little.
Re: 440 MPG? [Re: HotRodDave] #2914797
04/25/21 02:52 PM
04/25/21 02:52 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This is impossible to believe.
Re: 440 MPG? [Re: dOc !] #2914904
04/25/21 08:31 PM
04/25/21 08:31 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Why would you not block the heat crossover? Cooler intake charge is more detonation resistant right?
Re: 440 MPG? [Re: mgoblue9798] #2915177
04/26/21 12:59 PM
04/26/21 12:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you have very low compression and no chance of detonation or vapor lock then sure, leave the heat crossover, it will vaporize the fuel better. On the other hand if you are trying to get maximum efficency through very high compression then block it or it will increase the chance of detonation.
Water injection does nothing but slow the combustion process like EGR does, unless you are running into detonation don't waste your time, it will hurt MPG. Al Gore would be happy if you do as it reduces NOx emissions by reducing combustion temps. It will like more spark lead (negative work done against the rising piston) and it will also mean less molecules burned before the exhaust valve opens and further combustion of those molecules already in there will not produce any power, you want to burn as many of the fuel molecules in the chamber as possible before the ex valve opens for peak efficiency.
Re: 440 MPG? [Re: Kern Dog] #2915184
04/26/21 01:08 PM
04/26/21 01:08 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would not have believed a complete stranger on the internet either so I experimented, first I had the block squared and zero decked and I re-assembled with stock heads and head gaskets, then pulled em off and ran .039 head gaskets still no sign of detonation, then the last time I pulled em I milled them till we were getting into the intake valve seat and put in the .028 head gaskets at the same time. Milling the heads I think it was around .030 made a much larger squish pad and the thin head gaskets made the really tight squish distance to maximize combustion mixing. The biggest improvement came with the combo of square decking and the .039 gaskets but I would do it all if I did another of those and probably will be doing another in a 92 dakota very soon.
Feel free to replicate my experiment and report back, my feelings won't be hurt.
I almost forgot, somewhere along the way I added a set of ford 4 hole yellow injectors after the initial square decking build when one of the stock injectors took a dump but I don't remember witch head gasket swap operation they were before or after.
Re: 440 MPG? [Re: mgoblue9798] #2915215
04/26/21 01:59 PM
04/26/21 01:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think those big single planes kill TQ more because of port length being very short and the fact they are usually on engines with very big cams, the ports on my 392 in my ram are humongous but it has loads of TQ down low.
Re: 440 MPG? [Re: mgoblue9798] #2915277
04/26/21 03:23 PM
04/26/21 03:23 PM
Florida STAYcation
Florida STAYcation
[code][/code]
My take ?...on the 413 industrial head WITH COOLANT HEAT ....leave it open. It’s not nearly the huge heat of the exhaust crossover
SORRY .. but water injection works ... I used it on a duallie tow rig with windshield washer fluid - it worked
Re: 440 MPG? [Re: dOc !] #2915287
04/26/21 03:32 PM
04/26/21 03:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
[code][/code]
Windshield washer fluid is alcohol so of course it would help. Also if you got a heat crossover baking the intake air it probably was burning the fuel in the chamber way too fast so slowing it down with alcohol probably helped keep it out of detonation. Remember not all detonation is audible.
Re: 440 MPG? [Re: HotRodDave] #2915297
04/26/21 03:47 PM
04/26/21 03:47 PM
Florida STAYcation
Florida STAYcation
Had to use the solvent because of the ARCTIC TEMPS !
Never was able to try it on a new build ... would have larryLOVEit to do that !
The combo I used it on was a worn out 400 with ZERO QUENCH
Re: 440 MPG? [Re: dOc !] #2915300
04/26/21 03:49 PM
04/26/21 03:49 PM
Florida STAYcation
Florida STAYcation
I should say that ole oGO is going balls out on the project up
Re: 440 MPG? [Re: dOc !] #2915411
04/26/21 07:51 PM
04/26/21 07:51 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
[code][/code]
I am going to respectfully decline Doc. I am thinking worst case scenario, the engine runs hot, coolant in the intake gets fuel temps way up in the carb. Don't need gas percolating while I am trying to restart on the side of the road. May give up a little mileage that way, I don't know.. I'll be driving in warm weather and it won't take long for the engine to get to temp even without the extra heat.
Re: 440 MPG? [Re: HotRodDave] #2915418
04/26/21 08:11 PM
04/26/21 08:11 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I don't know HRD. I have tried torker intakes on two small blocks street engines before I knew better. Wound up being a horrible mismatch of parts and absolutely killed any bottom end. I have also put 360 heads on a smog dog 318 with similar results. I am just skeptical based on these past experiences. I have used a street dominator before with a little cam and headers and had much better luck, I suspect because it has a lot smaller runner volume than the torker. I am going to give my frankenmotor a try with the 413 heads and see what i can do. I am going to estimate 500 ft tlbs of torque from 2000 or a little higher to a little more than 4000 rpm- exactly the range where I will be using the engine. I don't see the need to spin the engine up any higher, as that torque is higher than the first couple cummins models in dodge trucks put out.
As far as the high compression build, I have followed your posts through the years since you did the mileage experiments with your old a body barracuda. If you say you ran 11 to one I am sure you did. Magnum combustion chamber is a much better layout than my 413 cylinder heads though. I am going to try to run compression up on my 340 build with some closed chamber heads- either EQ or Eddies I have not decided.
In your mileage experiments did you ever test out any type of anti reversion chamber or muffler, or try to tune header/collecter length to achieve some type of anti reversion?
Re: 440 MPG? [Re: mgoblue9798] #2915458
04/26/21 09:39 PM
04/26/21 09:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The 318 with 360 heads absolutely kills compression, that's where the low end TQ goes, depending on what head gaskets you use (cheap rebuild kits are usually .054) and if you use pistons with 4 valve reliefs like most cheap replacements it is very easy to end up in the 6ish compression ratio. You need to run a 360 head milled to closed chamber and then you might as well go magnum with ports the same size as a 360 and already a good closed chamber design.
The torker was a terrible design no matter what motor you put it on, sharp angles turning into the ports causing fuel to drop out and no air gap to keep things cool.
No on the anti reversion mufflers, I don't think it would be hard to make some up (tesla valve maybe?) but I kind of doubt it's effectiveness unless you had a cam with too much overlap or something. My theory on it would be that if your exhaust flows good enough there won't be any significant reversion going on, maybe I need to try to build one for the 92 dakota.
It's not hard to make more tq than an old 12 valve, I Never could figure out why they were so popular for towing (at least in stock form), the 6.4 in my 2011 ram 1500 would destroy my old 93 12 valve in a towing contest, I just towed another 2011 1500 ram on an open trailer on a 200 mile trip and got 14.5 MPG passing 18 wheelers on a couple big passes. I did like running used oil and transmission fluid for fuel in the old cummins though, it was fun filling it with an endless supply of used oil at the honda dealer I was working at.
Page 2 of 3 1 2 3
