Re: 99 Ram 2 wheel drive axle swap question
[Re: StrokerPost]
#2916087
04/28/21 12:21 PM
04/28/21 12:21 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There is another speed sensor at the transmission so I think the speedo will be in error. Because both ratios were available in that year, the dealer can flash the PCM to accept the different ratio.
[Re: John_Kunkel]
#2916131
04/28/21 01:53 PM
04/28/21 01:53 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have swapped them like that in a 98 and it was fine with no flash. The sensor on the trans is for the trans to shift based on output shaft RPM just like the old centrifugal governors did, and the one on the rear is for the speedo and ABS, the one on the rear goes the same RPM as the rear tires.
