Gas Odor #2915698
04/27/21 01:50 PM
04/27/21 01:50 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
89 Dakota 3.9 2WD. Especially after hauling a load, I smell gas around the vehicle. Not so much in the engine bay, but more around the bed/fuel tank area. No visible leaks whatsoever.
Grandma always said I had "hands of gold"!
Re: Gas Odor [Re: CHRGR69] #2915712
04/27/21 02:21 PM
04/27/21 02:21 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Something to check would be the gas cap first and then if that's not it I would check the fuel pump assembly/housing that's in the tank. Sometimes due to age they do crack.
Re: Gas Odor [Re: OrangeProwler] #2915726
04/27/21 02:50 PM
04/27/21 02:50 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
And fill neck grommets
Facts are stubborn things.
Re: Gas Odor [Re: larrymopar360] #2915897
04/27/21 09:23 PM
04/27/21 09:23 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would be looking at the condition of the fuel lines and rubber hoses. 89 still used rubber hose and steel lines. The fuel lines will start to weep where they are clamped to the frame, and the hoses will crack over time. Look for discoloration or witness trails, those leaks often will weep but not drip for a short while before they fail completely.
Another thing to look at is the condition of the hoses at the fuel filter.
There is also a joint on both the supply line and the return line up near the transmission. The steel lines are joined to braded steel lines as they go along the trans, those junction points will often start as a drip under pressure. Unfortunately, that area requires new lines.
On my 90, the leak at the transmission started the entire ball rolling. I ended up replacing all of both lines and all of the hoses and the filter. The newer Dakota's used the plastic lines, as much of a pain as it is to get the lines converted from the steel and rubber to the plastic lines, it was worth it in the end. Gene
