Re: Towing with RV
[Re: A/MP]
#2915627
04/27/21 11:38 AM
04/27/21 11:38 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
#1: Rancho 9000 adjustible shocks so you can dial them in to your liking. #2 biggest rear sway bar you can get.
I found air bags good at carrying a load, but they can contribute to the boat in the waves feel.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Towing with RV
[Re: 340Cuda]
#2915678
04/27/21 12:53 PM
04/27/21 12:53 PM
Posts: 1,776 Keymar, MD
DusterKid
Keymar, MD
While I don't know I would assume your rated towing capacity is about 5,000 pounds.
Most race rigs weigh more than that.
If that is the case you might want to look at reinforcing the rear frame of the coach and perhaps upgrading the brakes on the coach and trailer if possible. My particular RV is rated at 7,000. I'm prob right there at that weight limit. The previous owner swapped out the factory hitch for a heavier one, along with beefed up the rear frame and what not. The rv stops just as well as my 2500 ram did pulling the trailer, just trying to get it drive more like a dodge and less like a ford.
Re: Towing with RV
[Re: DusterKid]
#2915680
04/27/21 12:58 PM
04/27/21 12:58 PM
Hemi_Joel
Minnesota
You might want to check the toe. A little extra toe in can really straighten them out. Or if it is toed out, it will never go straight. How many miles on it?
Re: Towing with RV
[Re: Hemi_Joel]
#2915685
04/27/21 01:24 PM
04/27/21 01:24 PM
DusterKid
Keymar, MD
You might want to check the toe. A little extra toe in can really straighten them out. Or if it is toed out, it will never go straight. How many miles on it? Its a 2020 with 6,500 miles.
Re: Towing with RV
[Re: DusterKid]
#2915689
04/27/21 01:28 PM
04/27/21 01:28 PM
Hemi_Joel
Minnesota
Oh, that's way to new for me to know anything about...
Re: Towing with RV
[Re: DusterKid]
#2915694
04/27/21 01:39 PM
04/27/21 01:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You might want to check the toe. A little extra toe in can really straighten them out. Or if it is toed out, it will never go straight. How many miles on it? Its a 2020 with 6,500 miles. Is yours a 2wd or 4wd..if you have the tires on the front I think you have.. they tend to wander around take a pic of the front tires
Re: Towing with RV
[Re: jwb123]
#2915863
04/27/21 08:08 PM
04/27/21 08:08 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My motorhome is only a 25 footer so I added the best hitch offered and bought a “Trailer Toad”. It makes hauling an enclosed trailer so much safer. I started out with a 23 foot one with a Chevy 400 engine and it towed my open trailer great. They I bought a 27 foot one with a 460 Ford engine and it was a PIG. Then I found the 25 foot one 2001 with a fuel injected big block Chevy and this thing is a powerhouse. Man it tows my loaded 26 foot trailer great.
Re: Towing with RV
[Re: DusterKid]
#2916297
04/28/21 09:01 PM
04/28/21 09:01 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Following this topic as I have an '08 E450, ad hope to tow my open aluminum car hauler. I would like to try and eliminate the feel you have thru the steering wheel of the Ford I beam suspension. Can you describe what it is you are feeling with this? My brother has an E450 chassis that is much newer than mine (2019?), and he has no complaints, and does not feel it has any peculiar habits. Mine doesn't seem right, but it's the first twin I beam truck I've had, so I don't know what is normal and what is not.
Re: Towing with RV
[Re: DusterKid]
#2916651
04/29/21 06:50 PM
04/29/21 06:50 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
I've only driven the rv from the dealership home and than from home to the track and back so I'm still learning. But just driving the rv either with or without a trailer when you hit a bump in the road you feel it in the steering wheel (almost like there's not steering damper). I think this is just natural due to Ford's front suspension. I've always driven Dodge trucks so they have a much better more comfortable feel to me. A buddy of mine has a 01 Ford E350 and he upgraded the steering damper and front shocks to Bilstein and said the shocks made a world of difference. Being a 01 it may of still had the original shocks so that maybe why such and improvement. Seems RV manufactures just take the chassis from Ford and add the RV body and don't really upgrade the suspension for the extra weight. From an RV site it seems the most popular upgrades are:
Assure tire pressures are per manufacture for how the RV is loaded Front end alignment Heavy Duty Front Sway Bar Heavy Duty Rear Sway Bar Heavy Duty RV Shocks Aftermarket Steering dampner Rear Trac Bar
Being my RV is a 2020 with only 6500 miles I wouldn't think the shocks and steering damper would be worn out yet. I already have a front and rear sway bar (although they are about 2/3 the size of the heavy duty aftermarket ones) I'm thinking of adding a Rear Trac Bar and going from there. Most of the way to the track is a normal 2 lane road but speed limits are 50-55mph. When trucks (even pickups) come the opposite direction I can really feel the air move me around. It's not white knuckle or anything, but more than I think it should be. When I bought my B1500 high top van it had 142k on it. Still had original shocks. Replaced them almost immediately with some Monroe gas shocks on sale from Rockauto. It drove better, but still had an issue maintaining a lane on the interstate if an 18 wheeler passed or with a moderate side wind. Once I could afford the Bilsteins I put them on and it made a night and day difference. Little to no sway anymore, and can maintain a lane driving with one hand and actually relax and enjoy the ride. It isn't about shocks being worn out on a 2020. It is about better parts being available that are more suited to the job. Don't take my word for it though. Check out some of the RV forums and the reviews those that have installed Bilsteins give them.
Re: Towing with RV
[Re: DusterKid]
#2916659
04/29/21 07:07 PM
04/29/21 07:07 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
I've only driven the rv from the dealership home and than from home to the track and back so I'm still learning. But just driving the rv either with or without a trailer when you hit a bump in the road you feel it in the steering wheel (almost like there's not steering damper). I think this is just natural due to Ford's front suspension. I've always driven Dodge trucks so they have a much better more comfortable feel to me. Dodge puts real springs in everything they make, that's why they handle so well. Ford builds their RV chassis for old people that want a smooth ride. My F53 Class A is the same thing: soft springs, no road feel, mediocre handling. I actually had to put an extra rear leaf on the double-slide side of the machine because it was sagging. Stiffer front springs are the only cure in your case and in mine. I've decided to live with mine the way it is and just gloat in the fact that a Ford will never match a Dodge in the handling department. Keep in mind, your RV is light for what you are asking it to do. They are more ideal for towing a Smart car or fiberglass boat, not 5000 plus pounds of car hauler, race car, and tools. No hitch upgrade will fix this either. They Factory rate the hitch for a reason (brakes, transmission, frame, cooling and weight) and match it to DOT expectations. Could be worse: you could have bought one of them wimpy Blunder Motors RVs. Lol, they don't even make a Class "A" anymore because of how lousy they were.
Mo' Farts
Moderated by "tbagger".
