Re: Need a camshaft
[Re: carrman]
#2913306
04/22/21 08:43 AM
04/22/21 08:43 AM
Posts: 10,050 MN
JERICOGTX
MN
Cam cores are hard to come by right now. Make sure to look for something in stock.
69 GTX
68 Road Runner
Re: Need a camshaft
[Re: carrman]
#2913316
04/22/21 09:35 AM
04/22/21 09:35 AM
Posts: 3,916 usa
lewtot184
usa
Comp Cams XE268H. Made the Mistake of keeping it from my dead 451, as it only had a few thousand miles on it. The mechanic helping me on this feels I need to bite the bullet now and go roller. I know there is some work involved with it. all you need is a gentler profile.
Re: Need a camshaft
[Re: carrman]
#2913330
04/22/21 10:07 AM
04/22/21 10:07 AM
Posts: 43,364 Bend,OR USA
Cab_Burge
Did you keep the lifters on the same lobes in then new motor? If not that is the reason it failed ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
Re: Need a camshaft
[Re: carrman]
#2913346
04/22/21 10:53 AM
04/22/21 10:53 AM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
I'm using a MP .474 cam in my 440 C body, but my combo is different as I have a few high performance racing parts like a 2400 converter, and 3.23 one legger ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) . The Summit cam sounds pretty good for that app (if you can actually get one). I have a new Comp 268 high energy on the shelf if you'd like to try that.
Rich H.
Esse Quam Videri
Re: Need a camshaft
[Re: fast68plymouth]
#2913390
04/22/21 12:30 PM
04/22/21 12:30 PM
Posts: 3,916 usa
lewtot184
usa
i've used that small summit cam before in a mild 383. i thought it was a very nice reliable driver cam. don't think i'd trust summit lifters though. i don't think i'd use the 6401 summit cam in this app. zippy's 268 would probably be ok.
Re: Need a camshaft
[Re: Cab_Burge]
#2913511
04/22/21 04:51 PM
04/22/21 04:51 PM
Posts: 4,463 Michigan
MarkZ
Worthy
Worthy
A roller will set you back $1500 or about. Bronze gear, bronze tipped fuel pump push rod, cam shaft, lifters and springs.
Are you tearing the motor apart for inspection? That metal went somewhere.
Re: Need a camshaft
[Re: carrman]
#2913782
04/23/21 09:29 AM
04/23/21 09:29 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
Comp Cams XE268H. Made the Mistake of keeping it from my dead 451, as it only had a few thousand miles on it. The mechanic helping me on this feels I need to bite the bullet now and go roller. I know there is some work involved with it. So your 'mechanic helping' feels the need for the roller but he is unable to recommend which one? Curious thing there.
