Sweet
![](/ubbthreads/images/graemlins/thumbs.gif)
thanks a lot that REALLY helps!
If you do manage to get your 71 measurements from your other shop as well that would be great too.
I'm guessing the 'vertical' measurement is halfway up the 'RT bulge', but if it were possible to give the distance from the side edge of the hood to the holes as well that would be fantastic (i.e to visualise, if you laid a piece of paper to follow the hood contour and marked the side edge of the hood and the badge holes, then laid the paper flat, what would the measurements be?)
Thanks again, much appreciated
