Re: preventative maintenance on high miler 5.7
[Re: 340Cuda]
#2913448
04/22/21 02:29 PM
04/22/21 02:29 PM
Posts: 2,922 Calgary, Alberta Canada
a12rag
Thanks, yes, my car gets oil changes every 3k miles, plugs every 30k miles, changed belt once, still on original battery - yup, still tests good ! Replaced the belt once, tranny serviced once, cooling system serviced couple times, including new rad, cap and t-stat . . . but I am more concerned about the internal wear items like the timing chain (which is fairly long), chain guides (plastic ??) and guide tensioners . . . think that even with regular oil changes, these wear items are just that wear items . . .
[Re: a12rag]
#2913953
04/23/21 03:06 PM
04/23/21 03:06 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
For one thing, 139,000 is nowhere remotely close to something called high mileage. 15,000 per year is average and on a 15 year old car should be 225,000. Even if it did have 225,000 miles I would not touch the timing chain unless I always ran way over on my oil changes and there was a lot of sludge in the engine and in that case you would probably have worse problems any how.
As for what maintenance I would do above and beyond what is regularly scheduled I would very closely inspect the water pump weep hole and bearing with the belt tension off, and radiator especially along the seams, they are both prone to develop leaks and one good overheat will cause valve seats to drop out. Heck if I was very concerned bout it I would just throw in a high quality pump and radiator and don't worry about it.
[Re: Kern Dog]
#2914754
04/25/21 01:20 PM
04/25/21 01:20 PM
Posts: 15,937 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
There was a "Customer Satisfaction Bulletin" (Not a recall) on timing chain tensioner in which they will replace chain and tensioner for free. It was because of the plastic tensioner itself. Could cause serious damage if it crumbled apart. Did you have that done? If not, might as well have that done. Otherwise, I'd just continue with the oil changes and DEFINITELY do coolant drain and fresh coolant/distilled water refill. Aluminum parts need the clean coolant and distilled water or electrolysis will eat a hole right through parts. I saw a timing chain cover that almost had two holes through it due to poor cooling system maintenance on a 5.7 police car 98,000 miles. Granted, lots of idle time too but don't take a chance on that.
Other than that, nothing else unless you want to do stuff so you don't end up on the side of the road and inconvenienced. I did hoses, serp belt and pulleys, thermostat with flush at 75k but it's police package and has enough idle hours to consider it around 100k miles. I have not change plugs because it runs well.
Looking further, that might only be on Eagle Head Hemis starting in '09 but I'd still check it out.
Facts are stubborn things.
[Re: Kern Dog]
#2914764
04/25/21 01:40 PM
04/25/21 01:40 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
My engine loses a bit of coolant over time. I suspected the water pump but in every other water pump that I had go bad in the past, it never just weeped and stopped, weeped and stopped like this one. Before, once they started to drip, it was only going to get worse so I replaced the pump. Same here. Lasted a long time though, including lots of idle hours but never dripped. Another work car made lots of awful noise but didn't drip.
