Re: Heads are done. A couple questions... [Re: feets] #2910574
04/15/21 05:14 PM
04/15/21 05:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted by feets
Originally Posted by pittsburghracer
Did you get a flowsheet?
I didn't even get a thank you.
Wow. Sorry to hear you got screwed over.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Heads are done. A couple questions... [Re: CSK] #2910590
04/15/21 05:47 PM
04/15/21 05:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
If you can get them to Katy Tx, take them apart & bring 2 retainers with locks & one each valves & I will fix them & give you some flow #'s off of my toy Super Flow bench,, No charge !!!
Tremendous offer from you Charlie!!! up
Re: Heads are done. A couple questions... [Re: fast68plymouth] #2910630
04/15/21 07:37 PM
04/15/21 07:37 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I'm interested to know where not to send my heads.
Re: Heads are done. A couple questions... [Re: Uberpube] #2910638
04/15/21 07:43 PM
04/15/21 07:43 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Touché
Re: Heads are done. A couple questions... [Re: feets] #2910715
04/15/21 09:49 PM
04/15/21 09:49 PM
Windsor, ON, Canada
Diplomat360 Online content
Diplomat360  Online Content
Windsor, ON, Canada
As most everyone has already stated, these should not look like that.
But...to make you feel better (well, meaning this [censored] happens far too many times to all of us), check out the attached photos...the crud on the side of the guide is the left-over machining junk that the shop left in my factory SB heads.
That was after $1.5K CAD in '99 (so yeah, freaking expensive, but this was a highly recommended racing machine shop in London, ON, Canada - 'Atchison Machine Service').
Good thing I pulled these apart, I was going to try my hand at some serious head porting work...glad I did!
Re: Heads are done. A couple questions... [Re: fast68plymouth] #2910910
04/16/21 12:14 PM
04/16/21 12:14 PM
moparx Offline
moparx  Offline
Originally Posted by fast68plymouth
Quote
iagree bow
beer
Re: Heads are done. A couple questions... [Re: feets] #2910995
04/16/21 03:55 PM
04/16/21 03:55 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by moparx
as a machinist, i don't like what i see on that guide, CNC program or not.
those heads need taken apart and that mess touched up/fixed.
how many ports are like that ?
beer
All ports are like that.
This is not what I expected to see after being told "around $750" and being charged $1233.
What all was done for $1233? Cleaning used parts, full cnc (ports and chamber) and valvejob? Shipping?
Re: Heads are done. A couple questions... [Re: HardcoreB] #2911034
04/16/21 06:21 PM
04/16/21 06:21 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The heads were used but clean, disassembled, and freshly decked. I supplied new valves, seats, retainers, locks, and springs. I didn't supply the seals because I didn't know what would be needed after the work was done.
I told him that I needed every bit of flow I could get out of them. He and I discussed it at length and he said it would be around $750.
Everyone scoffed at the $1600 quote I had previously so I thought that price was more typical.
He did the ports, chambers, faced the valve seats, and assembled the valves.
- Stu Harmon
Re: Heads are done. A couple questions... [Re: feets] #2911879
04/19/21 10:13 AM
04/19/21 10:13 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
All said I don't think that was a bad price at all to pay for what you got. In your new post it looks like a VALVE JOB was done as well as lapped seats? Honestly the chips of aluminum i see you'll never know it went thru the motor. That said I would take a scribe and remove anything that looked 'loose'. The work looks good.
Re: Heads are done. A couple questions... [Re: HardcoreB] #2911889
04/19/21 11:02 AM
04/19/21 11:02 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The rest of the work looks good to me. I was disappointed to see the lack of attention and hand finishing. That made me think he was taking short cuts.
- Stu Harmon
