Ported head inspection photos
#2911692
04/18/21 05:46 PM
04/18/21 05:46 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The shop that did my Eddy RPM heads left some scraggly bits around the valve guides. It didn't sit well with me and I remembered a comment he made about really hard exhaust seats. A quick check with my straight edge showed a .014" variance in valve height. Not perfect but not a crippling variance. Those things left me feeling a bit unsure so I popped a couple valves out.
Most of the work looks pretty good to my untrained eye. Being a machinist I know what I'm seeing in metal but have never ported heads.
I will caution the unknowing by saying machined metal rarely photographs well. There are some hollows in the casting that didn't clean up but that's Edelbrock, not the porter. The flaky scraggly bits are the porter.
The seats are very nice without any sharp edges or ridges.
What do you folks think about the work done?
Re: Ported head inspection photos
[Re: feets]
#2911711
04/18/21 07:22 PM
04/18/21 07:22 PM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I'm not seeing anything that would bother me. Sometimes the temptation is there to remove any evidence of the casting but that's not necessarily a good thing. The fact he left some of the casting flaws alone would indicate he has some knowledge of how far is too far. The exhaust port looks well done around the guide. On the intake its nice to have a sharp transition around the guide, but that can only be achieved if the material is there to work with. Doesn't look like its was.
[Re: Stanton]
#2911735
04/18/21 08:24 PM
04/18/21 08:24 PM
feets
Senior Management
Senior Management
Irving, TX
The bit that bothered me was the flakes of aluminum coming off around the guides. On a few ports there are flakes of aluminum left flapping in the breeze. Those are the bits that should have been cleaned up by hand before assembly.
Most of the work looks really nice but I don't know all the little secrets that improve flow.
[Re: merpar]
#2911817
04/18/21 11:30 PM
04/18/21 11:30 PM
Posts: 16,514 On the run…
BloFish
On the run…
Obviously that would need to be addressed imho.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: jwb123]
#2911891
04/19/21 11:06 AM
04/19/21 11:06 AM
feets
Senior Management
Senior Management
Irving, TX
The porter assembled the heads as per our agreement.
[Re: powertrip]
#2911892
04/19/21 11:08 AM
04/19/21 11:08 AM
feets
Senior Management
Senior Management
Irving, TX
The other thing to check is to make sure your chosen gasket doesn't overhang the combustion chamber anywhere, I hate it when they blow out the chamber around the valves so the only gasket you can use is one for a 4.500" bore.
Yep. I had to go to 4.500 gaskets on my 4.375 bore to clear the chambers.
[Re: feets]
#2912072
04/19/21 07:07 PM
04/19/21 07:07 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
I like to blend the bottom cut on the seat to the bowl, also its hard to tell from the pictures BUT I like to lay back the short side radius on that intake port, & also I like to lap all the valves, to make sure there is contact 360 deg on the seat. that said some sandpaper roll work & a good cleaning .
[Re: CSK]
#2912086
04/19/21 08:01 PM
04/19/21 08:01 PM
feets
Senior Management
Senior Management
Irving, TX
It looks like he spent some time lapping the valves. I can see the change in surface finish on the valves and seats. That looks thoroughly done.
