Re: 426 wedge
[Re: mr_340]
#2905852
04/03/21 03:03 PM
04/03/21 03:03 PM
Posts: 459 las vegas,nv
mopar muscle7271
las vegas,nv
Time you get that crank and pistons you can get custom pistons for about same the crank would cost.that be a stupid way to go as well.
Re: 426 wedge
[Re: mopar muscle7271]
#2906241
04/04/21 01:08 PM
04/04/21 01:08 PM
Posts: 3,505 DFW
mr_340
DFW
Time you get that crank and pistons you can get custom pistons for about same the crank would cost.that be a stupid way to go as well. True, if you don't want the extra 40+ cubic inches and 50 lb-ft of torque. Why get 478 CID instead of 431? Spend $1200 on a set of Diamonds instead. Your engine and money. Do WTFYW.
Floyd Lippencott IV
Re: 426 wedge
#2911815
04/18/21 11:27 PM
04/18/21 11:27 PM
Posts: 3,505 DFW
mr_340
DFW
Arent they a 075 over pistons? Only +.005" on my standard bore 440 block. I think it can be honed out to fit the pistons. Not sure which CP pistons they are. Al said there were no numbers stamped in the tops, like M14, etc. New stocker rings will cost a lot more than the pistons.
Floyd Lippencott IV
Re: 426 wedge
[Re: dOoC]
#2913703
04/22/21 11:10 PM
04/22/21 11:10 PM
mopar muscle7271
las vegas,nv
That's the stock size of a wirst pin for a big block mopar engine
Re: 426 wedge
[Re: dOoC]
#2913729
04/23/21 12:30 AM
04/23/21 12:30 AM
mopar muscle7271
las vegas,nv
Couldnt they be machined to a .990 wirst pin size? Not much from a .984 then l could get reducer bushings or rods for the .990 size
Re: 426 wedge
#2914109
04/23/21 09:28 PM
04/23/21 09:28 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Have found some 426 wedge pistons old school mickey pistons ones brand new but they take a .984 wirst pin, which is the small block wirst pin size, what kind of pin or bushing to make them work with a big block stock rods? Try calling both Jahns, if they are still in business and or Ross pistons and see if they will remachine the wrist pin hole in those old M/T pistons for you. Mickey Thompson always had vendors make his parts, he didn't own the company that made them for him, Maybe even try Crower on fixing them for you
Re: 426 wedge
[Re: Cab_Burge]
#2914174
04/23/21 11:58 PM
04/23/21 11:58 PM
mopar muscle7271
las vegas,nv
Oh ok I can try and call a few piston shops up.jahns is called je pistons now
