Hemi storage cradle / dolly plans?
#2910488
04/15/21 01:37 PM
04/15/21 01:37 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Hi, does anyone have a blueprint to build a little dolly or cradle for storing Gen 2 hemis? I used to have one that bolted onto the motor mount holes and the bell housing area. It would be nice if it left the bellhousing flange open to put a transmission on it if needed.
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Hemi storage cradle / dolly plans?
[Re: Hemi_Joel]
#2910491
04/15/21 01:54 PM
04/15/21 01:54 PM
Posts: 10,039 MN
JERICOGTX
MN
Just use an old semi tire. I’m sure you have a few laying around.
My engine cradle just mounts on the front side of the bell housing face, so I could have the bell indexed.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2910492
04/15/21 01:58 PM
04/15/21 01:58 PM
Hemi_Joel
Minnesota
I used to have a nice one I got from Lofgren, but I don't know what happened to it. It would be nice to get a good design, set up the chop saw and the welder, and knock out a few assembly line style.
[Re: JERICOGTX]
#2910493
04/15/21 02:00 PM
04/15/21 02:00 PM
Hemi_Joel
Minnesota
My engine cradle just mounts on the front side of the bell housing face, so I could have the bell indexed. Something a little more precise and steady...
[Re: Hemi_Joel]
#2910494
04/15/21 02:03 PM
04/15/21 02:03 PM
Posts: 10,039 MN
JERICOGTX
MN
I'd send you a picture of mine, but it is at Harlans at this time.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2910495
04/15/21 02:07 PM
04/15/21 02:07 PM
Hemi_Joel
Minnesota
OK, I'll check back with you on that in 6 months. Wedge and Hemi are different anyway.
[Re: Hemi_Joel]
#2910497
04/15/21 02:11 PM
04/15/21 02:11 PM
Posts: 10,039 MN
JERICOGTX
MN
OK, I'll check back with you on that in 6 months. Wedge and Hemi are different anyway. Yes, but easy to do. Just bolts up differently, just like my INDY block.
69 GTX
68 Road Runner
[Re: AndyF]
#2910501
04/15/21 02:22 PM
04/15/21 02:22 PM
Hemi_Joel
Minnesota
If I design one, I'll make to fit onto a $15 Harbor Freight furniture dolly. Cheaper than buying caster wheels, and can be set in a truck bed without the wheels for stability.
[Re: Hemi_Joel]
#2910511
04/15/21 02:31 PM
04/15/21 02:31 PM
Posts: 10,039 MN
JERICOGTX
MN
If I design one, I'll make to fit onto a $15 Harbor Freight furniture dolly. Cheaper than buying caster wheels, and can be set in a truck bed without the wheels for stability. Harbor Freight, and stability do not go hand in hand. LOL.
69 GTX
68 Road Runner
[Re: Hemi_Joel]
#2910529
04/15/21 03:36 PM
04/15/21 03:36 PM
Posts: 10,144 A Red State
SNK-EYZ
A Red State
If I design one, I'll make to fit onto a $15 Harbor Freight furniture dolly. Cheaper than buying caster wheels, and can be set in a truck bed without the wheels for stability. What I use for an engine dolly on old engines (usually short blocks) are the Harbor Freight car dollies. They don't roll very well with a car on them, but do just fine with an engine. They could have brackets welded to them to bolt an engine on them like AndyF's pic. They would be strong with less fabrication needed than building from scratch, you just need brackets to bolt the engine in place.
[Re: SNK-EYZ]
#2910571
04/15/21 05:03 PM
04/15/21 05:03 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Here's mine, no prints but tape measure and a chop saw will almost get you there. Also have seen more than one grocery cart sacrificed for the cause....
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Hemi_Joel]
#2910818
04/16/21 09:00 AM
04/16/21 09:00 AM
Posts: 10,737 North Dakota
6PakBee
North Dakota
If I design one, I'll make to fit onto a $15 Harbor Freight furniture dolly. Cheaper than buying caster wheels, and can be set in a truck bed without the wheels for stability. I haven't had success going that route. I built six dollies using the Harbor Freight 1000# furniture dollies. There are two problems. The first is the casters, they are too small in diameter and of poor quality. With the weight of a fully dressed out 440 you can barely move it as they catch on every minor defect in the floor. After you have moved them around for a while, loaded all the time, the casters start deteriorating making it harder to push. The second is the dolly itself, I made a box on top of the dolly that the oil pan fits into. Even with this additional reinforcement, with the constant load of an engine the dolly starts to sag. The next one is going to be steel square tube and at least 3" diameter casters.
[Re: 6PakBee]
#2910903
04/16/21 11:57 AM
04/16/21 11:57 AM
Posts: 31,050 Oregon
AndyF
If I design one, I'll make to fit onto a $15 Harbor Freight furniture dolly. Cheaper than buying caster wheels, and can be set in a truck bed without the wheels for stability. I haven't had success going that route. I built six dollies using the Harbor Freight 1000# furniture dollies. There are two problems. The first is the casters, they are too small in diameter and of poor quality. With the weight of a fully dressed out 440 you can barely move it as they catch on every minor defect in the floor. After you have moved them around for a while, loaded all the time, the casters start deteriorating making it harder to push. The second is the dolly itself, I made a box on top of the dolly that the oil pan fits into. Even with this additional reinforcement, with the constant load of an engine the dolly starts to sag. The next one is going to be steel square tube and at least 3" diameter casters. Exactly. I tried a bunch of different designs when I first started building engine dollies and ended up with a steel frame and 5 inch poly casters. Nothing else held up or worked for very long.
[Re: AndyF]
#2911279
04/17/21 11:09 AM
04/17/21 11:09 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I’ve built a few out of 1-1/2” square .083” wall. They are plenty beefy. Some i used the factoru munt brackets welded to the cradle, and others i just got some 3/8” ppipe welded to arm supports for ft mounts.
