Re: Heads are done. A couple questions...
[Re: feets]
#2910574
04/15/21 05:14 PM
04/15/21 05:14 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I didn't even get a thank you. Wow. Sorry to hear you got screwed over.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: CSK]
#2910590
04/15/21 05:47 PM
04/15/21 05:47 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you can get them to Katy Tx, take them apart & bring 2 retainers with locks & one each valves & I will fix them & give you some flow #'s off of my toy Super Flow bench,, No charge !!! Tremendous offer from you Charlie!!!
[Re: Uberpube]
#2910638
04/15/21 07:43 PM
04/15/21 07:43 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
I'm interested to know where not to send my heads. Touché
[Re: feets]
#2910715
04/15/21 09:49 PM
04/15/21 09:49 PM
Posts: 1,793 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
As most everyone has already stated, these should not look like that.
But...to make you feel better (well, meaning this [censored] happens far too many times to all of us), check out the attached photos...the crud on the side of the guide is the left-over machining junk that the shop left in my factory SB heads.
That was after $1.5K CAD in '99 (so yeah, freaking expensive, but this was a highly recommended racing machine shop in London, ON, Canada - 'Atchison Machine Service').
Good thing I pulled these apart, I was going to try my hand at some serious head porting work...glad I did!
[Re: feets]
#2910995
04/16/21 03:55 PM
04/16/21 03:55 PM
Posts: 4,203 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
as a machinist, i don't like what i see on that guide, CNC program or not. those heads need taken apart and that mess touched up/fixed. how many ports are like that ? All ports are like that. This is not what I expected to see after being told "around $750" and being charged $1233. What all was done for $1233? Cleaning used parts, full cnc (ports and chamber) and valvejob? Shipping?
[Re: HardcoreB]
#2911034
04/16/21 06:21 PM
04/16/21 06:21 PM
Posts: 28,096 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The heads were used but clean, disassembled, and freshly decked. I supplied new valves, seats, retainers, locks, and springs. I didn't supply the seals because I didn't know what would be needed after the work was done.
I told him that I needed every bit of flow I could get out of them. He and I discussed it at length and he said it would be around $750.
Everyone scoffed at the $1600 quote I had previously so I thought that price was more typical.
He did the ports, chambers, faced the valve seats, and assembled the valves.
[Re: HardcoreB]
#2911889
04/19/21 11:02 AM
04/19/21 11:02 AM
feets
Senior Management
Senior Management
Irving, TX
The rest of the work looks good to me. I was disappointed to see the lack of attention and hand finishing. That made me think he was taking short cuts.
