Re: New Headers
[Re: Leigh]
#2904077
03/29/21 07:33 PM
03/29/21 07:33 PM
Posts: 10,049 MN
JERICOGTX
MN
Now the tig welding, I'm not sure about you but that's my fav part. I enjoy TIG welding, but I'm lucky enough to have a coworker that is WAY better then I am at it, willing to weld them up for me. A man has to know his limitations. They look great. If the National Geographic photographer is doing the finish welding, will he be back purging? Yes they are being back purged. Leigh, do you know a coworker of mine?
69 GTX
68 Road Runner
Re: New Headers
[Re: gregsdart]
#2904131
03/29/21 10:30 PM
03/29/21 10:30 PM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
Good looking set of tubes! You are much more patient than I.
Re: New Headers
[Re: DusterKid]
#2904424
03/30/21 10:37 PM
03/30/21 10:37 PM
Posts: 2,260 IL
furious70
IL
Doing a single 2.5" -> 3" per side for the turbos on my Fury was bad enough, can't imagine fitting those in there.
Not in the 'did it wrong' category, but from curiosity and my own battle with the T bars, did you first try to avoid trapping them or is there no way with that size pipe?
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: New Headers
[Re: furious70]
#2904441
03/31/21 01:17 AM
03/31/21 01:17 AM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Beautiful work, Jeff. Now to complete the journey and without worry of damage, build yourself some header/pan "savers" under each side of the car. Simple to do, and you will thank yourself later bud. Here's what Team Z sells, but you can make your own to fit how you like. Unless of course you already have a set installed. Wes [img] http://www.teamzmotorsports.net/product_p/tzm-wsop.htm[/img]
"Any fool can know. The point is to understand"
- A. Einstein
Re: New Headers
[Re: furious70]
#2904461
03/31/21 06:14 AM
03/31/21 06:14 AM
Posts: 10,049 MN
JERICOGTX
MN
did you first try to avoid trapping them or is there no way with that size pipe? I could have made them like TTi Headers, but didn't see any reason to do so. Since these pictures were taken, I cut the tube going around the torsion bar, and welded in a V band clamp. makes it super easy to install. I can install the headers with the engine in place. On the driver side, I'll be putting in a t lest 2 V band clamps. One for the header going around the torsion bar, and another to remove a tube, to easily change a starter if I have to. Wes, my K member is shaped just like what you posted. The headers actually don't hang down as much as my old Hooker Headers.
69 GTX
68 Road Runner
Re: New Headers
[Re: JERICOGTX]
#2904465
03/31/21 06:30 AM
03/31/21 06:30 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Supersonic indeed!
Now for the questions?
What car is they on ( 69 Gtx or 68 runner ) and why SO BIG?
If an exhaust valve is approx. 1.81 diameter in a good wedge motor then 2.00 ‘OD’ pipe should be plenty?
Would this design work my 71 Gtx (512, 440-1) and how much for another set ( please ) lol...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: New Headers
[Re: Gtxxjon]
#2904472
03/31/21 07:00 AM
03/31/21 07:00 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Supersonic indeed!
If an exhaust valve is approx. 1.81 diameter in a good wedge motor then 2.00 ‘OD’ pipe should be plenty? Maybe 1-7/8 od is ok too in most cases, or am I missing something???
Would this design work my 71 Gtx (512, 440-1) and how much for another set ( please ) lol... 563 CID and 440-1 CNC 345 heads, I don't know the specifics of the build but that foundation can easily make well over 800 horse. Regardless of the valve size his headers are not too big. As far as 1-7/8" headers, I don't think I'd run them on anything more than a warmed 383
Re: New Headers
[Re: Gtxxjon]
#2904494
03/31/21 09:19 AM
03/31/21 09:19 AM
Posts: 10,049 MN
JERICOGTX
MN
Supersonic indeed!
Would this design work my 71 Gtx (512, 440-1) and how much for another set ( please ) lol... These fit my 68 Road Runner, As for building a set for someone else, I just can't do it. One is time, and the other is I have a coworker do the final welding. Not that I couldn't do it, but I don't want that pressure.
69 GTX
68 Road Runner
Re: New Headers
[Re: JERICOGTX]
#2904750
03/31/21 09:37 PM
03/31/21 09:37 PM
Posts: 4,085 Mo.
racerx
Mo.
Those turned out really nice!
Should we start a pool to bet on how long before one of the resident geniuses comes along to tell you what all you did incorrectly? Shouldn't take too long. ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) .....They do look nice tho, but i have a question did you you tack them with mig and then have them tig them up? I can't imagine how hard it would be to fab your own headers. I thought of building a set of turbo headers once tho.
Re: New Headers
[Re: racerx]
#2904820
04/01/21 06:05 AM
04/01/21 06:05 AM
Posts: 10,049 MN
JERICOGTX
MN
Should we start a pool to bet on how long before one of the resident geniuses comes along to tell you what all you did incorrectly? Shouldn't take too long. ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) .....They do look nice tho, but i have a question did you you tack them with mig and then have them tig them up? I can't imagine how hard it would be to fab your own headers. I thought of building a set of turbo headers once tho. I tacked them with a TIG. Sometimes in the car, and most time's I'd mark the piece, and lay it out on a table, and tack it, retest fit everything.
69 GTX
68 Road Runner
Re: New Headers
[Re: JERICOGTX]
#2909458
04/12/21 12:47 PM
04/12/21 12:47 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Already seen a few times on the phone, but looks even better on a larger computer screen.
Not many will attempt this. Hats off to ya.
Rich H.
Esse Quam Videri
Re: New Headers
[Re: ZIPPY]
#2909468
04/12/21 01:18 PM
04/12/21 01:18 PM
Posts: 7,499 Minnesota
Hemi_Joel
Minnesota
Looks good! Lots of work went into those, I'm sure.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: New Headers
[Re: Hemi_Joel]
#2909488
04/12/21 02:42 PM
04/12/21 02:42 PM
Posts: 10,049 MN
JERICOGTX
MN
Thanks everyone. I'm almost finished with the headers. The passenger side is 100% complete, and I just need to weld in my EGT bungs, and add a couple V band clamps to the drivers side header, and they are complete. I'm more than happy with how they turned out. Even if they do not make 1hp over my 2" Hookers, I'll still be happy, as they fit, and will not rust.
69 GTX
68 Road Runner
