Re: I hate bronze oil pump gears!
[Re: dvw]
#2908949
04/11/21 07:59 AM
04/11/21 07:59 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
My used gear has 700+ passes on it. Looks fine. Doug What material, what oil pump? \ Bonze gear. Indy single line pump cover with the Melling thick rotor pump. 5w20/30 JR1 synthetic. Cam endplay is controlled with a Jessel belt dive. Doug I am sure that 5W20 helps. Its amazing how much that eases the workload on that gear. I know I had to adjust my idle speed back down when I went from 15/40 to 10W30 on my old engine.
68 Barracuda Formula S 340
[Re: varunner]
#2908997
04/11/21 10:55 AM
04/11/21 10:55 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I'm in the process of setting mine up......again. I just got the 440 source welded aluminum cover and their ball bearing thrust button. Are you doing anything extra to get oil to the button ? i drilled and tapped the cover on my gear drive and ran a #3 oil line to it. Use a very small feed hole. .030?
