78 Trailduster - wiring nightmare #2907223
04/06/21 11:32 AM
04/06/21 11:32 AM
High Plains of South Dakota
O
olwhite64 Offline OP
O
Putting together a 78 Trailduster for a buddy of mine and the engine harness is a mess, along with a few bad/cut wires on the cab side of the bulkhead connector too. I've tried searching for a wiring diagram on here with no luck. Does anybody have a link or PDF of a 78 engine/bulkhead/harness that they'd be willing to either post or email me?
I'm in the home stretch with this thing but the wiring is really holding me up! HELP!
Thanks in advance...
Matt
Re: 78 Trailduster - wiring nightmare [Re: olwhite64] #2907228
04/06/21 11:43 AM
04/06/21 11:43 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 78 Trailduster - wiring nightmare [Re: stumpy] #2907284
04/06/21 12:53 PM
04/06/21 12:53 PM
O
O
If only he'd blown up the whole page...! Oh well.
The rest are of different makes/models.
Anybody else?
Re: 78 Trailduster - wiring nightmare [Re: olwhite64] #2907289
04/06/21 12:59 PM
04/06/21 12:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Instead of just searching just here try an online search. "My mopar wiring diagrams" has a 1979 diagram under trucks that should be pretty close if not the same.
Re: 78 Trailduster - wiring nightmare [Re: olwhite64] #2907396
04/06/21 06:42 PM
04/06/21 06:42 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Anybody else?
The '79 is different? I believe it is slightly different as you wrote. I ask because I have a FSM for '79.
Facts are stubborn things.
Re: 78 Trailduster - wiring nightmare [Re: larrymopar360] #2907425
04/06/21 07:49 PM
04/06/21 07:49 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Go to Ramchargercentral.com. Look for member Dodgeboys and pm him or email him.
Angry white pureblood male
Re: 78 Trailduster - wiring nightmare [Re: ruderunner] #2908669
04/10/21 10:07 AM
04/10/21 10:07 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
If you can't find it on line get the factory service manual. Even then the stock set up will most likely have melted/heating up bulkhead connectors. Check out the link one of the most common problems is the amp gauge wiring.
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
Re: 78 Trailduster - wiring nightmare [Re: Moparite] #2908688
04/10/21 10:51 AM
04/10/21 10:51 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Maybe this site would help since the Ramcharger is the same platform.
https://ramchargercentral.com/vehicle-help/school-me-on-wiring-78-rc-column-wiring-(ignition)/
