Re: Does any bodies toolbox look like this?
[Re: 67vertman]
#2906200
04/04/21 12:33 PM
04/04/21 12:33 PM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
You can get way more tools in the box without the fancy organizers.
[Re: slantzilla]
#2906208
04/04/21 12:41 PM
04/04/21 12:41 PM
Posts: 4,715 Wichita
GY3
Wichita
Friends that work in aircraft have boxes that look like that.
At the end of the day they have to account for every tool.
[Re: slantzilla]
#2906213
04/04/21 12:45 PM
04/04/21 12:45 PM
Posts: 6,020 Salem
Grizzly
Moparts Proctologist
Salem
Well, almost. But it doesn't explain why I have to clean the garage to find a quarter inch ratchet used for "only a minute" 6 months ago or why a Philips screwdriver is never around when you need it.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2906247
04/04/21 01:15 PM
04/04/21 01:15 PM
Posts: 19,682 north of coder
moparx
Well, almost. But it doesn't explain why I have to clean the garage to find a quarter inch ratchet used for "only a minute" 6 months ago or why a Philips screwdriver is never around when you need it. i have "notes" in different places in the garage where tools have "disappeared" into the piles of "stuff" when dropped while around said piles of "stuff". that way, one of these days i will be moving these piles and the "notes" will help remind me to be on the lookout for the tool that "disappeared" in that particular pile !
[Re: slantzilla]
#2906357
04/04/21 04:25 PM
04/04/21 04:25 PM
Posts: 20,696 in a cattle trailer down by th...
Guitar Jones
You can get way more tools in the box without the fancy organizers. This! I have 3 large boxes and a 4 drawer roll cart along with 2 open roll carts and still need more room. No place for fancy organizers. I do however know where most tools are, or at least a good idea of where it is.
[Re: Guitar Jones]
#2906439
04/04/21 06:45 PM
04/04/21 06:45 PM
Posts: 10,559 Rittman Ohio
fourgearsavoy
Rittman Ohio
I keep my tools in an organized drawers without special trays. When you work 100% flat-rate you need to know where your tools are at all times so you don't waste precious clock time trying to find a wrench. I work with a couple of younger techs with tools scattered everywhere. Now my home toolbox is a little less organized but I have specialized boxes at home, one for transmission work, carb and tuning , and engine work including valve spring compressors ,compression testers ,torque wrenches etc... Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2906512
04/04/21 07:41 PM
04/04/21 07:41 PM
Posts: 43,650 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I've parted out hundreds of car, I have filled a tool box with all the tools I have found in them...LOL
JB Rhinehart, Realist
A-Body's RULE!
[Re: poorboy]
#2906528
04/04/21 08:02 PM
04/04/21 08:02 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I wish I had the discipline to be that organized, but I do not!
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: 19swinger70]
#2906557
04/04/21 08:59 PM
04/04/21 08:59 PM
Guitar Jones
I wish I had the discipline to be that organized, but I do not! Don't feel bad, I'm pretty OCD, really bad but that is not an excuse to be that anal about tools. It works for me, you get used to it. Now buddy Wayne, no can't do that, 12,000 sq/ft shop and can't find anything? Nope. I at least put stuff back when I'm done.
[Re: GY3]
#2906574
04/04/21 09:52 PM
04/04/21 09:52 PM
Posts: 3,134 N.W. Florida
Fat_Mike
N.W. Florida
At the end of the day they have to account for every tool. Absolutely. In the Air Force, if your end product ends up on the flightline, every tool box is shadowed, every tool has its specific inventory number, every box has an inventory sheet, and every box is inventoried before and after every job. If you're a back shop, at the beginning and end of every shift. Jet engines are like very expensive vacuum cleaners. Sucked up random objects (like misplaced tools) play havoc on them, and they're very expensive to fix. Almost weekly (sometimes more often) an AF flightline gets shut down for a "lost object"...and a "lost object reports" go straight to the maintenance commander (colonel). They're normally lacking in the sense of humor department. I would hope similarly strict standards are held at civilian airports. EDIT: I didn't intend to be vague when I said the "flightline gets shut down." That means NOTHING moves until THAT tool is found (or the commander deems that all leaves have been turned). Flight hours lost, flight training for the day is disrupted....a very big deal. The sole mission of the Air Force in peacetime is to prepare for war...and a lost object brings it all to a halt..
[Re: Fat_Mike]
#2906591
04/04/21 10:46 PM
04/04/21 10:46 PM
Guitar Jones
At the end of the day they have to account for every tool. Absolutely. In the Air Force, if your end product ends up on the flightline, every tool box is shadowed, every tool has its specific inventory number, every box has an inventory sheet, and every box is inventoried before and after every job. If you're a back shop, at the beginning and end of every shift. Jet engines are like very expensive vacuum cleaners. Sucked up random objects (like misplaced tools) play havoc on them, and they're very expensive to fix. Almost weekly (sometimes more often) an AF flightline gets shut down for a "lost object"...and a "lost object reports" go straight to the maintenance commander (colonel). They're normally lacking in the sense of humor department. I would hope similarly strict standards are held at civilian airports. I am super familiar with mechanical objects. That is why I don't fly unless it's absolutely necessary. I also will not drive next to a semi truck..
[Re: Guitar Jones]
#2906693
04/05/21 08:13 AM
04/05/21 08:13 AM
Posts: 34,974 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Most my tool drawers are kept organized , except the screw driver area .. ..never found a good way to keep them organized
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Guitar Jones]
#2906770
04/05/21 10:03 AM
04/05/21 10:03 AM
RWG75
RWG75
Yes and no. On the upside: comes in handy in the boneyard - never lost a tool there. I also always know exactly where whatever I need is. Spare parts too. On the downside: I spend entirely too much time picking up the tool I just used and then getting it out again later. I also spend way too much time looking for that one tool than landed in the wrong drawer.
