Re: Bendpak lifts, anyone have one?
[Re: Guitar Jones]
#2905636
04/03/21 01:38 AM
04/03/21 01:38 AM
Posts: 21,528 N.E. OHIO, USA
A12
N.E. OHIO, USA
A few years ago I told my friend that I was thinking about getting a low ceiling garage lift and he said save yourself a lot of time and start by looking at a Mohawk Lift and work from there. Click on "Feature Images" Here: Feature Images How they are Made In USA https://mohawklifts.com/library/How_2Posts_Lifts_Are_Made.pdf https://mohawklifts.com/automotive-lifts/2-post-lifts/a7/If you look at the comparison of features it's hard to not think about maybe spending a little (or is that a lot?) more? Dang the Mohawk lifts are built to a little higher grade.....but you pay for what you get as always. Not saying the Bendpak lifts are not worth their price, in fact I was considering a Bendpak all along and might end up with one if I can't figure out how to get the Mohawk.
[Re: A12]
#2905667
04/03/21 08:55 AM
04/03/21 08:55 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Question, are Bendpak cable raising lifts? Yes, with two redundant cables.
[Re: moparx]
#2905793
04/03/21 01:03 PM
04/03/21 01:03 PM
Posts: 5,919 ohio
ruderunner
ohio
If you can't raise the roof, you might lower the floor.
Angry white pureblood male
[Re: ruderunner]
#2906187
04/04/21 12:22 PM
04/04/21 12:22 PM
Posts: 19,555 north of coder
moparx
If you can't raise the roof, you might lower the floor. i have considered digging a pit, but as i live on a hillside, i'm concerned about how ground water flows here. and if i lower the floor, i will be below street level with a steep incline to the street, as the street is just over 1 1/2 car lengths from the garage.
