Re: Worth the Scat to Hellcat cai air box upgrade?
[Re: Cometstorm]
#2905282
04/02/21 10:32 AM
04/02/21 10:32 AM
Posts: 3,288 West Coast, USA
jbc426
West Coast, USA
If you get the car to a good tuner, they can maximize the motors performance for the cold air intake beyond what the factory tune gives. If you really want to improve performance, think about adding a water/methanol injection set-up and a cat-back exhaust before getting a chassis dyno tune.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2905286
04/02/21 10:45 AM
04/02/21 10:45 AM
Posts: 2,778 St. Louis, Missouri area
Cometstorm
"Beat It"
"Beat It"
If you get the car to a good tuner, they can maximize the motors performance for the cold air intake beyond what the factory tune gives. If you really want to improve performance, think about adding a water/methanol injection set-up and a cat-back exhaust before getting a chassis dyno tune. Thanks JBC... I’m just tinkering around a bit. I’m too old to swim deep! ![coffee coffee](/ubbthreads/images/graemlins/custom/coffeetime.gif)
[Re: Cometstorm]
#2905306
04/02/21 11:19 AM
04/02/21 11:19 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I have a 2020 WB Scat pack auto with 700 miles.
I’m considering the headlight intake to Hellcat air box upgrade.
Anyone else done this?
Worth it, or just mostly bling?
To really find out the true effect of a CAI it is a big job. You need at least two vehicles, and need to swap the modification between the two vehicles either at a dragstrip over multiple passes, or even better with the two vehicles doing side by side wide open throttle steep hill climbs, preferably in one gear. Manifold Air Pressure sensor and Intake Air Sensor readings would ideally be recorded too. Owners routinely underestimate the effort to correctly test either CAI or MPG.
[Re: 360view]
#2905339
04/02/21 12:04 PM
04/02/21 12:04 PM
Posts: 4,794 Holland MI Ottawa
2boltmain
Holland MI Ottawa
The car hobby is all about tinkering and modifying. I say yes do it. You know it wont be like adding 100hp but many many mods are done to old and new cars that do not necessarily increase power. Big ole Accel super coils, 8mm plug wires- aftermarket electronic distributors and ignitions, chrome valve covers Moroso chrome air cleaner etc did not make more power on old iron but they were fun to install and look fantastic!
Keep old mopars alive.
[Re: 2boltmain]
#2905347
04/02/21 12:20 PM
04/02/21 12:20 PM
Cometstorm
"Beat It"
"Beat It"
The car hobby is all about tinkering and modifying. I say yes do it. You know it wont be like adding 100hp but many many mods are done to old and new cars that do not necessarily increase power. Big ole Accel super coils, 8mm plug wires- aftermarket electronic distributors and ignitions, chrome valve covers Moroso chrome air cleaner etc did not make more power on old iron but they were fun to install and look fantastic! Well said! That’s where I’m at... ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) My Scat is about 80 % garage art, 20% pleasure driving (I’m retired). Will never be raced or abused (not to say I won’t pounce it once in awhile to keep it awake!)
[Re: roadrunninMark]
#2905451
04/02/21 04:22 PM
04/02/21 04:22 PM
Cometstorm
"Beat It"
"Beat It"
I watched the video and I like the idea of putting the small tube in first (behind the light), even though no one has done it. I think it would be easier too, if you trim down that tube on the side it goes into the air box. It looks like a good 1/2" of plastic could be removed on that outside of the tabs. That would give quite a bit more room to install it. I think there’s several brands of these two parts, and there is likely some small tolerance variances. The one’s coming to me are Mopar OEM, so I’m hoping for no issues.
[Re: Cometstorm]
#2905918
04/03/21 06:35 PM
04/03/21 06:35 PM
Posts: 3,337 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
I bought a used one (take off) a few years ago for my SRT 392. I don't recall installation being difficult at all. Did it give a noticeable difference...not really but the intake air temps did drop a few degrees.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: Cometstorm]
#2909850
04/13/21 05:24 PM
04/13/21 05:24 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
I watched the video and I like the idea of putting the small tube in first (behind the light), even though no one has done it. I think it would be easier too, if you trim down that tube on the side it goes into the air box. It looks like a good 1/2" of plastic could be removed on that outside of the tabs. That would give quite a bit more room to install it. I think there’s several brands of these two parts, and there is likely some small tolerance variances. The one’s coming to me are Mopar OEM, so I’m hoping for no issues. If you're buying the OE Hellcat stuff you'll need to trim the large end of the fiber tube where it mates to the headlight (maybe 3/4" or so...), and remove the blockoff plate in the headlight. There's also a foam gasket on the bottom of the airbox they don't give you, that's on the factory 392 box. Some foam weatherstripping from Wally World will work fine. Plenty of YouTube videos for this install...
[Re: Sixpak]
#2910006
04/14/21 09:17 AM
04/14/21 09:17 AM
Cometstorm
"Beat It"
"Beat It"
I watched the video and I like the idea of putting the small tube in first (behind the light), even though no one has done it. I think it would be easier too, if you trim down that tube on the side it goes into the air box. It looks like a good 1/2" of plastic could be removed on that outside of the tabs. That would give quite a bit more room to install it. I think there’s several brands of these two parts, and there is likely some small tolerance variances. The one’s coming to me are Mopar OEM, so I’m hoping for no issues. If you're buying the OE Hellcat stuff you'll need to trim the large end of the fiber tube where it mates to the headlight (maybe 3/4" or so...), and remove the blockoff plate in the headlight. There's also a foam gasket on the bottom of the airbox they don't give you, that's on the factory 392 box. Some foam weatherstripping from Wally World will work fine. Plenty of YouTube videos for this install... Thanks! Got “er done last week. No modifications needed. The headlight tube is 2019/2020’specific so no trim needed. I did apply weatherstrip to those areas not provided. Removing the two T10 (tiny) torx screws on the headlight cap was kind of a pain, and the only real hard part. Using a 2mm hex to back them out (after getting the screw unseated) helped a lot. Worth the upgrade? Dunno, haven’t even driven it yet. But surely won’t hurt anything. Now have a catch can on order. Can’t decide whether I’ll install it or not. Lots of debate on that subject.
[Re: Cometstorm]
#2910164
04/14/21 03:49 PM
04/14/21 03:49 PM
Butterscotch71
Lost Title
Lost Title
I watched the video and I like the idea of putting the small tube in first (behind the light), even though no one has done it. I think it would be easier too, if you trim down that tube on the side it goes into the air box. It looks like a good 1/2" of plastic could be removed on that outside of the tabs. That would give quite a bit more room to install it. I think there’s several brands of these two parts, and there is likely some small tolerance variances. The one’s coming to me are Mopar OEM, so I’m hoping for no issues. If you're buying the OE Hellcat stuff you'll need to trim the large end of the fiber tube where it mates to the headlight (maybe 3/4" or so...), and remove the blockoff plate in the headlight. There's also a foam gasket on the bottom of the airbox they don't give you, that's on the factory 392 box. Some foam weatherstripping from Wally World will work fine. Plenty of YouTube videos for this install... Thanks! Got “er done last week. No modifications needed. The headlight tube is 2019/2020’specific so no trim needed. I did apply weatherstrip to those areas not provided. Removing the two T10 (tiny) torx screws on the headlight cap was kind of a pain, and the only real hard part. Using a 2mm hex to back them out (after getting the screw unseated) helped a lot. Worth the upgrade? Dunno, haven’t even driven it yet. But surely won’t hurt anything. Now have a catch can on order. Can’t decide whether I’ll install it or not. Lots of debate on that subject. My catch can is usually about 3/4 full at each oil change...
