Re: Your 2021 Racing goals?
[Re: J_BODY]
#2905338
04/02/21 12:02 PM
04/02/21 12:02 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Well I live in Canada so the Pandemic is still in full rage up here! At this point no one knows when and if the tracks will open. Everyone in the race world is preparing like it is over and they will be on track early May. Personally I cannot see it happening. My racing is sorta on hold. The industry that both my wife and I work in has been decimated by this thing. Neither of us has worked since March of last year. Racing unfortunately has had to take a back seat.
With regards to my car. I have been fighting an inconsistency issue for the last 5 or 6 seasons. I was throwing parts at it like a drunken sailor to try and fix it with no success. I was finally spent a day and installed the Racepak that I purchased 4 years ago to help me find the issue and refused/was too lazy to install. I found the issue the next weekend. Made 3 runs on the throttle stop within .005 then on the First run the next morning it snapped the crank. So that is my luck! Figure out an issue that has plagued me for years, go into a big race with renewed confidence that I have a gun at a gun fightand the crank breaks! So my good motor is hurt. Luckily I had aluminum main caps on it and the caps took all of the abuse. My 230 400 block will live another day once I can get some more caps. It damaged a couple of rods and two pistons just touched the head but no real damage. I was extremely lucky!!!!!!!
So this brings me to my current situation. I had a 400 based 451 short block that was in my street car. It was a very strong running engine but it was a heater on the street. The block was a little thin in a couple places so I did a short fill. Did not work for me on the street but it will be perfect on the track. My plan is to put the top end off the 512 on it with a slightly smaller cam, reduce the compression and run it on pump gas. Race gas up here is crazy priced and I am sick of paying for it. I am also sick of having to get my car certified. I am sick of having to wear a 5 layer suit when my car runs 9:80s in the summer heat and at our altitude. All in all I think it will be a better plan all around.
So at this point I am squirreling away what cash I can to spend on it and I will be out when I can.
I wish all a good season, trouble free racing and lots of win lights!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: 451Guy]
#2905351
04/02/21 12:29 PM
04/02/21 12:29 PM
Posts: 16,550 On the run…
BloFish
On the run…
Finally went through the motor and got it back into the car. Dyno says 620hp. So hoping to go faster this year without any carnage.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: JERICOGTX]
#2905430
04/02/21 03:34 PM
04/02/21 03:34 PM
Posts: 2,124 Byron, NY
W.I.N. Racing
Byron, NY
As stated in a previous post I am embarking on a 20+ yr old plan, I am hoping to get to 6 of the 8 local events here and if things go well travel to some surrounding tracks as well. Quick 16 and 4.70 racing. We were able to get out for a few shakedown runs at the end of last season and with a ton of "limiters" (Launching off idle in High gear with12deg retard for 2 sec plus 3 pills sizes fat) in place we were able to ensure have the power now we just need to polish the crew and driver. There are a couple of car update for ease of maintenance plus a front strut upgrade. A engine bearing inspection and oil heater due to a low oil pressure condition (70 wgt and 50 deg amb not a good mixture) Should be fun.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: JERICOGTX]
#2905462
04/02/21 04:34 PM
04/02/21 04:34 PM
Posts: 289 PA
Harry's Taxi 2
PA
Hoping for an 8 second time ticket this year.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Harry's Taxi 2]
#2905535
04/02/21 06:49 PM
04/02/21 06:49 PM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
I haven't been down the track in over a decade, and I've never gone quicker than 13.0's. Awful, lol.
Goal is to at least run 12's with the new car and then slowly see if I can make it quicker, supposedly it last ran 12.70's but it has been mostly in storage for 5 years so I'm working those bugs out too.
Stretch goal is Drag Week!!!
Next year I'd like to get it down to 11.50's but don't know how much I'll need to change to get it there.
Edit: also looks like I'll need to go either to Lapeer or Martin as Milan may not open this year at all. I personally have never had issue with Milan and it's hard to argue it being a half hour from my house!
[Re: Blusmbl]
#2905618
04/02/21 11:39 PM
04/02/21 11:39 PM
Posts: 4,707 Wichita
GY3
Wichita
Edit: also looks like I'll need to go either to Lapeer or Martin as Milan may not open this year at all. I personally have never had issue with Milan and it's hard to argue it being a half hour from my house! That's a cool ride!
[Re: GY3]
#2905693
04/03/21 10:02 AM
04/03/21 10:02 AM
Posts: 570 UK
rb446
UK
Last year was a new learning curve for us and especially for the owner/driver of our '69RR that had never been faster than 12.5 with the car, with its new 589ci mild street motor, new built 727, D60 and racing on 10x29 bias slicks we have gone a best of 10.35@130 in full street trim driving to track and home. For this year although its limited to only a few meetings cos of all this c**p thats going on all we can hope for is to go past the 1st round and even get to a final brkt racing, the car won't have anything new on it I doubt so its all down to the driver getting better at it.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: GY3]
#2905703
04/03/21 10:19 AM
04/03/21 10:19 AM
Blusmbl
Plymouth, MI
Thanks, appreciate it! Hoping to make it as quick as yours one day, you seem to have found the sweet spot of performance/streetability with a traditional bb mopar build.
[Re: JERICOGTX]
#2905829
04/03/21 02:02 PM
04/03/21 02:02 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
What is everyone's 2021 racing goals for the year? Post a picture of your car, and tell us what your goals, and upgrades you have done.
Myself, I just want to dial in the car, and top my 9.72 best, AND make it past first round. I sent off my McLeod Soft Lok clutch to Cale Aronson, at Black Magic clutches, and had it rebuilt. My 499 is at the machinist getting new bearings, and rings. Wasn't really tired, but the long block has been together since 2003.
Lets hear em! A first round win? Why the lofty goal all of a sudden? ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif) Why not set a more realistic goal so you are not disappointed? ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Blusmbl]
#2905898
04/03/21 05:17 PM
04/03/21 05:17 PM
GY3
Wichita
Thanks, appreciate it! Hoping to make it as quick as yours one day, you seem to have found the sweet spot of performance/streetability with a traditional bb mopar build. Thanks! Building a car full of compromises certainly has its challenges. I keep thinking how much faster it would be if it weighed 1,000 lbs. less like the Fox bodies I see at the track! ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif)
[Re: GY3]
#2906005
04/04/21 06:56 AM
04/04/21 06:56 AM
Posts: 3,256 Md.
carnut68
Md.
Thanks, appreciate it! Hoping to make it as quick as yours one day, you seem to have found the sweet spot of performance/streetability with a traditional bb mopar build. Thanks! Building a car full of compromises certainly has its challenges. I keep thinking how much faster it would be if it weighed 1,000 lbs. less like the Fox bodies I see at the track! Your car is impressive as is. I'm sure you could find a few pounds to eliminate. I need to weigh my 68 Fastback, a friend weighed his dads 68 Notchback and it was 3250 with a 440 full interior, brass radiator, iron water pump. Manifolds full exhaust. Mine is backseat delete ,heater delete,glass hood Aluminum heads, water pump and radiator. I'm guessing I'm about 250lbs lighter than his.
America First!
[Re: carnut68]
#2906008
04/04/21 07:38 AM
04/04/21 07:38 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Thanks, appreciate it! Hoping to make it as quick as yours one day, you seem to have found the sweet spot of performance/streetability with a traditional bb mopar build. Thanks! Building a car full of compromises certainly has its challenges. I keep thinking how much faster it would be if it weighed 1,000 lbs. less like the Fox bodies I see at the track! Your car is impressive as is. I'm sure you could find a few pounds to eliminate. I need to weigh my 68 Fastback, a friend weighed his dads 68 Notchback and it was 3250 with a 440 full interior, brass radiator, iron water pump. Manifolds full exhaust. Mine is backseat delete ,heater delete,glass hood Aluminum heads, water pump and radiator. I'm guessing I'm about 250lbs lighter than his. My 68 Fastback is a tank. With 240 lbs of driver it sits at 3650 with all the factory seats in. That is with a full cage, Dana, Fiberglass hood, and lightweight wheels. It does have what is probably the heaviest small block you can build in it though. R1 Block with W2 heads. Street car problems! Everytime I do something to shed weight I feel like I end up doing something else to add weight all in the name of reliability and serviceability.
68 Barracuda Formula S 340
[Re: Hemi_Joel]
#2906059
04/04/21 10:14 AM
04/04/21 10:14 AM
Posts: 10,049 MN
JERICOGTX
MN
Lets hear em! A first round win? Why the lofty goal all of a sudden? ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif) Why not set a more realistic goal so you are not disappointed? Has not won a single round in competition, but does have this going for it.
69 GTX
68 Road Runner
[Re: Blusmbl]
#2906184
04/04/21 12:19 PM
04/04/21 12:19 PM
Posts: 17,918 S.E. Michigan
ZIPPY
S.E. Michigan
Stretch goal is Drag Week!!! Pit helper and tty photographer available. Especially for Lapeer with my place being on the way/just in case you need parts or something, not to mention the 200 or so times you were there whenever I needed you!
Rich H.
Esse Quam Videri
[Re: JERICOGTX]
#2906194
04/04/21 12:29 PM
04/04/21 12:29 PM
ZIPPY
S.E. Michigan
My only racing goals are the ongoing race to replace sheetmetal....
Actually this is an old pic...the left side is about as near complete as I can get it, while on the hoist. I should be starting on the right quarter/wheelhouses pretty soon.
Rich H.
Esse Quam Videri
