Page 1 of 3 1 2 3
Your 2021 Racing goals? #2904969
04/01/21 04:00 PM
04/01/21 04:00 PM
MN
JERICOGTX Offline OP
MN
What is everyone's 2021 racing goals for the year? Post a picture of your car, and tell us what your goals, and upgrades you have done.
Myself, I just want to dial in the car, and top my 9.72 best, AND make it past first round. I sent off my McLeod Soft Lok clutch to Cale Aronson, at Black Magic clutches, and had it rebuilt. My 499 is at the machinist getting new bearings, and rings. Wasn't really tired, but the long block has been together since 2003.
Lets hear em!
69 GTX 68 Road Runner
Re: Your 2021 Racing goals? [Re: JERICOGTX] #2904976
04/01/21 04:17 PM
04/01/21 04:17 PM
an8sec70cuda Offline
Go faster than 8.91.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Your 2021 Racing goals? [Re: an8sec70cuda] #2904982
04/01/21 04:30 PM
04/01/21 04:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ummmmm to find a new car and make a pass before years end
Re: Your 2021 Racing goals? [Re: JERICOGTX] #2904986
04/01/21 04:44 PM
04/01/21 04:44 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
.......AND make it past first round ??!! eek
jX .... do you do THIS for fun or the potential glory ?
Me thimks I’ll start a separate topic ... smoke
Re: Your 2021 Racing goals? [Re: dOOc] #2904995
04/01/21 04:57 PM
04/01/21 04:57 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I have one more track to visit in PA, and then I will have raced at every active track in Pennsylvania. Bonus points if I can win at least two rounds there, as I have at all the others. I also set a goal every year of racing at one new track out of state that I have never been to, I was able to add two tracks to that list last year.
The other big goal is finally finishing my Super Stock car. Hoping to have it ready for mid-summer.
Re: Your 2021 Racing goals? [Re: dOOc] #2904996
04/01/21 04:57 PM
04/01/21 04:57 PM
oregon
greendart408 Offline
oregon
I have raced for 26yrs and am 42yrs old. Ran it with a 430sb NA,59 degree, injected on alky, went 9.30@144@3185lbs. I got my w8, f2 deal In finally and has been more than complete nightmare for the past 4yrs. Enough that I have just parked it for a couple yrs and ran my daily driver 69, 340, 4spd dart that runs 12s. So much more fun. I’m way deep into the efi swap as we speak so I can hopefully enjoy it again. I’m a do it yourself person so I take pride in it all. Hopefully it will be fun this yr again.
Re: Your 2021 Racing goals? [Re: dOOc] #2905003
04/01/21 05:03 PM
04/01/21 05:03 PM
MN
MN
Yeah Doc, 2020 was a bad year. Broke the car every time I took it out. That happens when you actually have a race car. Go blow smoke up someone else’s a$$.
Re: Your 2021 Racing goals? [Re: dOOc] #2905005
04/01/21 05:06 PM
04/01/21 05:06 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Finishing up my new 408 as we speak to replace the 422 that has been in my black duster for five years. Indy headed 422 went 5.98 in the 1/8th mile and 9.42 in the 1/4. Hoping the new moved pushrod Edelbrock headed 408 runs 6.0’s and 9.50-9.60’s. My 572 is in my blue heads up duster and bolted to a 1.69 low gear powerglide I built. It needs fuel lines made, wired, etc so hopefully it’s ready to go by June.
19B24B98-E5D8-4C30-9B7C-FC85CE7E09B1.jpegBB69E867-760C-4DFF-82A1-5331A16049BD.jpeg00DA60E4-7051-4B20-9DD6-79930BAC8984.jpegE2EAB9F3-16CD-4DBE-AC7A-9C8A9241DD22.jpeg
1970 Duster
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Your 2021 Racing goals? [Re: JERICOGTX] #2905008
04/01/21 05:13 PM
04/01/21 05:13 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
jX ....NO NEED to be so grumpy tsk
... and I’m not blowing smoke ... pity
Re: Your 2021 Racing goals? [Re: dOOc] #2905013
04/01/21 05:21 PM
04/01/21 05:21 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
No pics. I've tried and get them to post. However, I'm looking for a genuine wheels up launch, thanks to the new A1 converter that should arrive shortly. and somewhere around (1/8 mile) 7.00-7.2, with a few more MPH. 96-98, I'm thinking. smile (69 Dart, 360.)
Re: Your 2021 Racing goals? [Re: dOOc] #2905019
04/01/21 05:33 PM
04/01/21 05:33 PM
birdtracker Offline
birdtracker  Offline
Racing is a very difficult sport. At least in my thinking. It only takes one small thing to completely wreck your plan to go racing. Imagine your driving down the road and some driver cuts you off and your car gets damaged past the point of being repaired and your done for maybe a year or 2. Then what if you built your engine and a part ended up not being heat treated correctly or a part was a cheap chinese knock off and took your engine out. Then what if you got water in your oil and couldn't figure out what was causing it. Small things detrimental effects.
That being said I will probably do back flips if my bucket of bolts would just make a pass under power. Just saying. Birdtracker
Re: Your 2021 Racing goals? [Re: JERICOGTX] #2905074
04/01/21 08:16 PM
04/01/21 08:16 PM
tboomer Online work
tboomer  Online Work
If yours breaks Jeff you can always drive mine! Now that you have it figured out! wave
Re: Your 2021 Racing goals? [Re: tboomer] #2905093
04/01/21 08:46 PM
04/01/21 08:46 PM
gregsdart Offline
gregsdart  Offline
Make it through two weekends without having to fix anything😳
Re: Your 2021 Racing goals? [Re: JERICOGTX] #2905110
04/01/21 09:38 PM
04/01/21 09:38 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
get my act together on the tree having gone back to footbrake .
Win at least one event , runnered up 2 weeks ago.
Do at least 1 ANDRA event interstate preferably @ SouthCoast Raceway . Havent raced there .
dont break anything .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Your 2021 Racing goals? [Re: tex013] #2905116
04/01/21 09:52 PM
04/01/21 09:52 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Get my street car to run at least a 9.99. It did a 10.01 on the last pass of last season. shout
New Viking Crusader shocks, tires and front wheels this year.
'63 Dodge 330
11.19 @ 121 mph
Re: Your 2021 Racing goals? [Re: GY3] #2905120
04/01/21 10:10 PM
04/01/21 10:10 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Just get to the track and make some passes.
America First!
Re: Your 2021 Racing goals? [Re: tex013] #2905121
04/01/21 10:11 PM
04/01/21 10:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would like to get the roll bar in my car so I can legally and safely go 10.50 in street trim. Gonna have to master Tig welding so it looks presentable and strong .
Jeff it looks like Norwalk is a go this year are we going to see you there?
Gus beer
Old pic from the early 90's
64 Plymouth Savoy
Dana 60
Re: Your 2021 Racing goals? [Re: fourgearsavoy] #2905135
04/01/21 10:43 PM
04/01/21 10:43 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
Not really doing much to the car. Hoping to go big bucks racing this year and not break the car in the staging lanes..........
Re: Your 2021 Racing goals? [Re: slantzilla] #2905195
04/02/21 07:02 AM
04/02/21 07:02 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I want to do some more bracket racing, I hardly raced at all last year or the year before for that matter.
My car is super heavy for what it is and I have decided to just deal with it. I enjoy the stock seats way to much and I have put my super heavy folding backseat back in so we can cruise it around as a family once I get some good belts for the back seat to keep the 7 year old in.
Current best is 10.54 with a 1.4160ft at its lowest weight of 3550lbs. I would like it to see 10.30s at that same weight after my cam change. Its making more power but the starting line hasn't been my friend so that will be a focus because this thing would normally hook in a car wash lol. What Data I have says it should run 10.40s right now if I could get the starting line figured back out.
The new cam is from Comp's "low shock" line and the tech at comp said the RPM peak would be whatever my cylinder heads could support so that should be interesting. Trying to wring all I can from the premium 91 octane race fuel I run.
68 Barracuda Formula S 340
Re: Your 2021 Racing goals? [Re: Bad340fish] #2905209
04/02/21 07:50 AM
04/02/21 07:50 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Points start in two weeks would like to go some rounds in Sportsman Eliminator, run some more 11.50 index races including Cecil Countys Strange Street Car Shootout , go some rounds in my truck at South Mountains Mopar race in conjunction with Chryslers at Carlisle, hope to have my friend Win Bracket 3 at Island Dragways Mopars at the Patch driving my truck for the forth year in a row
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Page 1 of 3 1 2 3
