E-Body Rear Sway Bar Mounting To Frame: #2904015
03/29/21 02:10 PM
03/29/21 02:10 PM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
I was thinking about this last night & figgered I'd post it up. On the E-body cars with the rear sway bars, where the brackets mounted to the rear frame rails - they mount with 4 beefy sheetmetal screws on each side. Would it be better/stronger to use two long grade 8 bolts with a locking nut to run through the rails, or is the 4 screw method perfectly adequate?
Re: E-Body Rear Sway Bar Mounting To Frame: [Re: Sunroofcuda] #2904022
03/29/21 02:37 PM
03/29/21 02:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Originally they used the four screws per side. I'm pretty sure that when you get an aftermarket bar, they come with long bolts to go all the way through the frame. The problem with that is if you aren't careful, you can crush the frame if you overtighten the bolts. I've seen where people open up the holes, install a thick tube inside the frame and tack it in place. Then you can't crush the frame.
Re: E-Body Rear Sway Bar Mounting To Frame: [Re: Sunroofcuda] #2904030
03/29/21 03:19 PM
03/29/21 03:19 PM
AndyF Offline
AndyF  Offline
I'd probably install nutserts in the frame and use bolts rather than screws.
Re: E-Body Rear Sway Bar Mounting To Frame: [Re: AndyF] #2904081
03/29/21 07:39 PM
03/29/21 07:39 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
its self treading screws, I would stay away from long bolts..its not needed that badly
Re: E-Body Rear Sway Bar Mounting To Frame: [Re: Sunroofcuda] #2904095
03/29/21 08:32 PM
03/29/21 08:32 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I wouldn't think there are a great deal if stress put on those screws because of how the sway bar is designed to function.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: E-Body Rear Sway Bar Mounting To Frame: [Re: A39Coronet] #2904101
03/29/21 09:05 PM
03/29/21 09:05 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Nutserts would do a pretty good job, I wouldn't put any type of "self-tapping" fastener there. FWIW, My aftermarket Hotchkis brackets are welded in.
If you are through-bolting it, you want to add some compression sleeves inside the frame rail to avoid crushing it. Drill ~7/8" holes, insert 7/8" compression sleeves, install bracket, put 1/2" bolts through it.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: E-Body Rear Sway Bar Mounting To Frame: [Re: Sunroofcuda] #2904210
03/30/21 08:53 AM
03/30/21 08:53 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
The only problem I've seen with those brackets is that he frame rail rusts out underneath and compromises the rail. There isn't enough stress there to worry about stripping the bolts and if there was the best solution would be to fully weld around the perimeter for strength and moisture sealing. Through bolts are too easy to crush the rail. While you are at it, make it so you can change the bushing more easily. Essentially make a new bracket design or modify the originals with bolts.
Re: E-Body Rear Sway Bar Mounting To Frame: [Re: Sunroofcuda] #2904215
03/30/21 09:07 AM
03/30/21 09:07 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've done this several times adding rear factory bars to my E bodies for the last few decades....zero issues, easy pezzy... employed none of the over thinking mentioned in other posts above, just drill/bolt done.... the one on my 71 Challenger has been on there 40+ yrs with poly bushings....zero issues
Re: E-Body Rear Sway Bar Mounting To Frame: [Re: DAYCLONA] #2904257
03/30/21 11:20 AM
03/30/21 11:20 AM
Highland, MI.
Highland, MI.
I was thinking the same thing. The bracket that fits over the unibody frame rail is beefy enough itself without even thinking about crushing the frame. I was mainly wondering if the bracket movement over the years was enough to start working the 4 screws loose. I'll leave it as is.
