Aftermarket aluminum heads??
#2903250
03/27/21 12:08 AM
03/27/21 12:08 AM
Posts: 106 waco tx
gogo318
waco tx
So Getting ready to do something with scamp project . Plans will be a fun weekend strip toy that can be driven to and from the track Engine will is 318 that's was built copying the 318 cheaper than dirt build that engine masters built ( don't look for it ,it's long been taken down sadly) It's not cheaper than dirt I can tell you that and there are a few things that they didn't cover I had to discover the hard way . Anyhowzer, one of those things is the need for stronger rocker arms, As I found out the spring combo they boasted likes to punch pushrods through the factory stampings that they swore could handle it . So I'll be plunking down my hard earned for a set of Harland sharps . But I got to thinking , If I'm going to pour some more money into this guy ,why not spring for some decent aluminum heads that will flow better than the 302 castings , Perferably a naked head I can transfer all my goodies on to . The 302s have been carved to fit 2.02 intakes and 1.65 exhaust ( I'm guessing at the exhaust I know it's what ever is most popularly gone with the 2.02s.) Any recommendations on brands or even a particular head ?
67 charger fastback 318 stock
67 belvedere II 4dr soft top built 318
68 newport 2dr hard top 318
84 b150 440/727
84 d150 short wheel step side 4x4 lifted
87 omnitruck (you just have to see it )
new addition 63 dart wagon !!!
Re: Aftermarket aluminum heads??
[Re: gogo318]
#2903377
03/27/21 01:54 PM
03/27/21 01:54 PM
Posts: 14,509 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Perferably a naked head I can transfer all my goodies on to . Unless you changed the guides and the new valves you installed have 11/32” stems, I don’t think you’re going to find any currently produced aftermarket aluminum head that will facilitate the factory sized 3/8” stem valves. I’d use the SM aluminum heads for a budget performance option to replace some reworked 302’s. Just buy them complete and swap out the springs if you have to.
[Re: fast68plymouth]
#2903508
03/28/21 06:54 AM
03/28/21 06:54 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Nice to see guys talking 318ci again lol...
Seen them running TENS in a A-Body so they is OK for RACE!
But I would go 360ci with Edelbrocks or something else cheap ALI head wise?
The bigger heads need a 'bigger bore' methinks to work proper.
Or a 318ci with a steel crank, trick rods, that will take 7000rpm, maybe more?
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: gogo318]
#2903780
03/28/21 08:39 PM
03/28/21 08:39 PM
Posts: 4,446 Michigan
MarkZ
Worthy
Worthy
Mopar Performance used to sell stamped replacement SB rockers that were supposedly thicker than stock. Had that same problem with spearing rockers using factory seasoned parts. Cam was a real mild flat tappet Crane with something like .450ish" lift. Set of those cured the problem, but I'd be damned if I could find the part number. This was 15 years ago.
[Re: gogo318]
#2904255
03/30/21 11:18 AM
03/30/21 11:18 AM
Posts: 43,255 Bend,OR USA
Cab_Burge
CNC ported 195 CC Speedmaster and or Pro Comp heads I have a set I bought back in November on their black Friday sell, I didn't get them until late last month The ones I ordered had the valve springs for hydraulic for roller cams and they showed them not in stock after I order them direct from Speedmaster
[Re: Moparteacher]
#2904822
04/01/21 06:41 AM
04/01/21 06:41 AM
Posts: 162 Chicago-area Illinois
4mopower
[quote=Moparteacher]I'm not much of a small block guy so.... If you stay with an LA head a set of 273 ductile rockers may be a less expensive alternative that'll easily handle your springs. Will likely require a different set of pushrods, but so will the Harlan Sharps.
This is what I did years ago, i purchased 273 stock replacement rocker arms (from the local auto parts store) for my 509 cam 340ci.
Worked great.
[Re: 4mopower]
#2905883
04/03/21 04:47 PM
04/03/21 04:47 PM
Posts: 106 waco tx
gogo318
waco tx
The engine already has trick flow oil thru push rods ( that the engine masters build totally didn't mention ) I had to have those because the stock push rods we're several thousands too short and o couldn't tell you why maybe because the build called for a 0 deck ?? But they are still ball end . I'm assuming that's why your saying they won't work?
84 b150 440/727
[Re: gogo318]
#2905900
04/03/21 05:24 PM
04/03/21 05:24 PM
fast68plymouth
So. Burlington, Vt.
HS rockers use ball and cup pushrods, not ball and ball.
The PRW stainless rockers use ball/ball pushrods. However, don’t assume they will end up requiring the same pushrod length as your current rockers.
They might......they might not. Just be aware of it going in.
