Re: Headers: Wrap or coat?
[Re: 70Drop]
#2900128
03/17/21 04:10 PM
03/17/21 04:10 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
100% coated. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I've never been a fan of header wrap. I hate the way it looks and, in my experience, it deteriorates the headers themselves.
[Re: an8sec70cuda]
#2900155
03/17/21 05:49 PM
03/17/21 05:49 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
100% coated. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I've never been a fan of header wrap. I hate the way it looks and, in my experience, it deteriorates the headers themselves. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Cab_Burge]
#2900194
03/17/21 08:23 PM
03/17/21 08:23 PM
Posts: 1,413 Central Pa
moparjim79
Central Pa
I love the way coated headers look, but im always amazed at how the wrap all but eliminates any heat from the exhaust. I do some work in the natural gas industry, and the natural gas engines I work on have the entire exhaust wrapped. Natural gas engines exhaust is a lot hotter than your run of the mill hot street car and race car running off any kind of gas.
Just as an example, these engines are governed to run at 1500 rpm, 80% of the run time is "loaded", but the rpm stays the same. The manifolds glow red, and if you bump your hand into the wrapped portion of exhaust, you feel pretty much nothing.
Not to hijack, but what about those exhaust jackets?
[Re: moparjim79]
#2900205
03/17/21 08:58 PM
03/17/21 08:58 PM
Posts: 22,731 Bitopia
jcc
Bitopia
The problem with the wrap, it exceeds the reliable heat range of the exhaust material, which leads to rapid oxidation ( view as rust) and metal fatigue, as the metal excessively expands and contracts thru every heat cycle. You can wrap SS and not have same downsides to a point, or wrap CI or Inconel, but mild steel will not last. My guess on the constant speed motors, they are not mild steel tube manifolds..
[Re: JERICOGTX]
#2900244
03/18/21 12:34 AM
03/18/21 12:34 AM
Posts: 223 California
70Drop
California
I'd love to have gone stainless, but my only option on these headers was mild steel. But I did get a stainless-steel price, lol. The coated headers I've had in the past seem to run as hot as non-coated headers. On my last set of headers, I painted them, then wrapped them. Didn't get any rust (but I do live in southern CA). I might just do that again and just deal with the ugliness
[Re: 70Drop]
#2900285
03/18/21 09:23 AM
03/18/21 09:23 AM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
Ive heard, don’t know for sure, that coated inside and out frees up HP, same with the wrap. And something about stainless is better than mild steel for HP
[Re: 70Drop]
#2900307
03/18/21 10:20 AM
03/18/21 10:20 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Header wrap on mine, it works great, its time to redo them after 9 years, the wrap has gotten crunchy & from having to pull the headers a few times it is time, where it has come off the headers still have the black paint I put on them, no rust at all. they have over 11k miles on them the 2nd pic is when I first did them
[Re: sasquatch]
#2900651
03/19/21 10:00 AM
03/19/21 10:00 AM
Posts: 2,260 IL
furious70
IL
my manifolds and mild steel piping for the turbo setup on my Fury have been wrapped for 9 years now and I took it apart over the winter and all the pipes are just fine. Street car that is never driven in bad weather. I had wrapped headers on my coronet for years and it sat for long period in a shop that 'sweated' as the seasons changed and those headers were also fine. I'm not sure how severe of treatment is necessary for wrap to cause premature fatigue on pipes but I think I've tested past most people's use cases.
70 Sport Fury 68 Charger 69 Coronet 72 RR
