Re: Clover leaf removal Indy intake
[Re: HardcoreB]
#2900715
03/19/21 12:56 PM
03/19/21 12:56 PM
Posts: 476 Alberta, Canada
451Guy
Alberta, Canada
Thank you all for the input. At this point I have started the porting. I have removed the majority of the cloverleafs and I and going to cut back the two dividers like Wilson did in Andy's intake. I will not be extending them due to the fact that I cannot Aluminum weld and do not really have the budget to have someone else do it. Unfortunately, my comparison will not be real scientific. based on a completely different engine combination. But like my late dad used to say "God hates a coward!" So I am letting the chips fly!!!!!! What is the worst thing that can happen? I screw up a perfectly good intake! LOL!
Also I would post pictures but launching the space shuttle remotely from my phone is easier than posting picks on this site.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: 451Guy]
#2900719
03/19/21 01:03 PM
03/19/21 01:03 PM
Posts: 4,203 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
... I and going to cut back the two dividers like Wilson did in Andy's intake. ...
Yes GOOD...if you measure the divider-wall length, you will have a gage to make them all the same length. This is similar to what Wilson did. Most of my time spent IIRC was 'port-matching' because as i remember it, it was all over the map BAD. Also as evident by the latest data...LEAVE A BURR FINISH in the manifold.
[Re: 451Guy]
#2900896
03/19/21 08:38 PM
03/19/21 08:38 PM
Posts: 4,125 Mo.
racerx
Mo.
What type /tool/blade you use to cut out the clover ? i would of like to see pictures of how this was done.
[Re: racerx]
#2900941
03/20/21 12:59 AM
03/20/21 12:59 AM
451Guy
Alberta, Canada
I used a 4 inch aluminum cut off disk in a grinder. The one I used was slighty used to reduce the diameter a little. I cut wide if that makes sense. I then did some rough shaping with a file. Then i started to conture with a aluminum rotary burr. Now i am still trying to figure out how I am going to trim the runner divider!
Thanx 451 Guy
[Re: 451Guy]
#2908599
04/10/21 05:59 AM
04/10/21 05:59 AM
Posts: 2,981 A shed in England
Tig
A shed in England
We've used an early 4500 440-3 that appeared to be just a plunge cut, 4150 version. It was cut in 2 horizontally, the clover removed, welded and blended. We eventually swapped that out for a 440-3X both these manifolds had distribution issues with cylinders # 1 & 2 running leaner than the rest. We improved this with an old school trick of grinding a couple of grooves at the entry to the runners of 1 & 2.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: VernMotor]
#2927994
05/29/21 09:35 AM
05/29/21 09:35 AM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
Any updates on this thread?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: racerx]
#2937173
06/27/21 07:45 AM
06/27/21 07:45 AM
Posts: 4,125 Mo.
racerx
Mo.
