Re: RV2 AC Compressor or new style rotary . . .
[Re: a12rag]
#2944888
07/19/21 04:29 PM
07/19/21 04:29 PM
Posts: 2 USA, Washington
mashayafai
USA, Washington
If the advantages of the new compressor attract you so much, you can change it. But I don't recommend it. First of all, remove the exhaust manifold from the engine. After that, loosen the generator belt and release the compressor pulley. Next, an external inspection of the compressor is performed, and the freon circulation tubes are removed. After that, pull out the plug with the wires from the compressor connector and unscrew the nuts of its fastening. Remove the old compressor, and install a new one in its place. But in general, I don't advise you to do it yourself. It's better to find affordable and reliable aircon service.
[Re: Moparteacher]
#2945351
07/20/21 08:28 PM
07/20/21 08:28 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
The oil, whether it be mineral, PAG or Ester, does not circulate with the refrigerant in an RV2/R-12 system like a rotary/134a compressor system, regardless of the refrigerant you choose to use.
Any of the three oils should work on the RV2 as long as you add it to the crankcase of the compressor and NOT the charging port. THE OIL DOES NOT MIX AND CIRCULATE WITH THE REFRIGERANT with an RV2 or York/Tecumseh..
I'm by no no means an AC system expert, but according to the service manual in an RV2/R12 system the oil does mix with and is carried by the R12 through the entire system.
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: KWF340]
#2945376
07/20/21 08:55 PM
07/20/21 08:55 PM
Posts: 12,248 Looking for a way out of Middl...
IMGTX
I'm by no no means an AC system expert, but according to the service manual in an RV2/R12 system the oil does mix with and is carried by the R12 through the entire system. I think he was referring to the RV2 twin cylinder compressor used on old Mopars. The majority of the oil sits in the sump splash oiling the Compressor like a lawn mower engine does. Yes, you are correct that oil will circulate but it will not get into the sump through the hoses. With the RV2 compressor, putting oil in the hoses is like adding adding oil to a lawn mower engine through the carburetor. Because it will circulate, you should also add some to the system in the drier when installing everything from scratch to lubricate the other parts. i.e. compressor valves, expansion valves I use ester oil in R12 systems because PAG and Mineral Oil are not compatible. At least the manual says they aren't so I have never tried it any other way.
[Re: IMGTX]
#2945500
07/21/21 09:54 AM
07/21/21 09:54 AM
KWF340
Hinckley, Ohio
Yup I was also referring to the RV2 twin cylinder compressors. Maybe a semantics issue - IDK. Anyway, here is the relevant part of the 1970 service manual that I was referring to.
