Page 1 of 5 1 2 3 4 5
Dyno test 440 exhaust manifolds. #2899626
03/16/21 10:56 AM
03/16/21 10:56 AM
God's Country Maryland
GODSCOUNTRY340 Offline OP
Nick's Garage just dyno tested a 440 using factory HP exhaust manifolds, max wedge manifolds and headers.
Results:
HP manifolds---- 375 horsepower------ torque- 389
Max Wedge------ 410 HP ----------------- torque-446
Headers ---------- 419 HP ----------------- torque-463
The headers (1 7/8" tubes) increased 44 horsepower. Back in the day everybody claimed they only gave you 15 more horses.
Re: Dyno test 440 exhaust manifolds. [Re: GODSCOUNTRY340] #2899632
03/16/21 11:05 AM
03/16/21 11:05 AM
an8sec70cuda Offline
And I still hear guys today saying the HP manifolds are just as good as headers, lol. Of course they are always the car show type...scared to have to prove anything.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dyno test 440 exhaust manifolds. [Re: an8sec70cuda] #2899638
03/16/21 11:26 AM
03/16/21 11:26 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Boy, those Max Wedge manifolds sure do a nice job. I was not expecting that big of a difference between HP and Max Wedge.
Thanks for posting that.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Dyno test 440 exhaust manifolds. [Re: GODSCOUNTRY340] #2899639
03/16/21 11:28 AM
03/16/21 11:28 AM
AndyF Online content
AndyF  Online Content
Results:
All depends on the combination. Those dyno tests can be "rigged" by changing the camshaft. The results also will change a lot depending on the muffler and tailpipes that are used.
Re: Dyno test 440 exhaust manifolds. [Re: an8sec70cuda] #2899644
03/16/21 11:35 AM
03/16/21 11:35 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I always invite car show guys to the dragstrip and they never show... laugh2
'63 Dodge 330
11.19 @ 121 mph
Re: Dyno test 440 exhaust manifolds. [Re: GY3] #2899647
03/16/21 11:48 AM
03/16/21 11:48 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Car show types wouldn't like the Pure Stock Drags. Most of the cars there are show worthy, and will kick their ash on the strip to boot.
Re: Dyno test 440 exhaust manifolds. [Re: AndyF] #2899654
03/16/21 12:11 PM
03/16/21 12:11 PM
Results:
He didn't change anything on the engine except the manifolds. Go to Youtube and type in Nick's Garage, he's a Mopar guy too.
Re: Dyno test 440 exhaust manifolds. [Re: GODSCOUNTRY340] #2899661
03/16/21 12:28 PM
03/16/21 12:28 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Dyno test 440 exhaust manifolds. [Re: GODSCOUNTRY340] #2899673
03/16/21 12:59 PM
03/16/21 12:59 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I have sure replaced a lot of manifolds with headers over the years and the headers always helped. But 44hp and 74lbs more torque sounds like an awful lot. The advertising departments sure missed their chance on that one. Frankly, it's been a long time now since I swapped manifolds for headers, but I don't remember that spectacular of a difference. At least not normally on a stockish combo. twocents
Master, again and still
Re: Dyno test 440 exhaust manifolds. [Re: DaveRS23] #2899678
03/16/21 01:11 PM
03/16/21 01:11 PM
A727Tflite Offline
A727Tflite  Offline
Watch the video - the aerial portion above the carbs.
Notice the fuel atomization differences between the three setups.
Re: Dyno test 440 exhaust manifolds. [Re: A727Tflite] #2899682
03/16/21 01:22 PM
03/16/21 01:22 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
more airflow = higher atomization!
Re: Dyno test 440 exhaust manifolds. [Re: A727Tflite] #2899686
03/16/21 01:25 PM
03/16/21 01:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I saw that too, interesting. Glad someone posted the numbers, I couldn’t understand a thing he said lol. I’m guessing the difference between the Max and headers is the collector and length-size of tubes. But just bolt on stuff was cool.
Re: Dyno test 440 exhaust manifolds. [Re: GODSCOUNTRY340] #2899725
03/16/21 02:46 PM
03/16/21 02:46 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
Results:
Andy's comment is valid... when you have a cam with a bunch of overlap, the power difference between manifolds and headers will be magnified - headers support scavenging and manifolds don't. As soon as I saw the vacuum gauge reading around 11 in-hg with a pretty lumpy idle, I knew you'd see a big difference. It was impressive to see the max wedge manifolds hang with the headers. When running a factory-type stock cam, I've seen engines only pick up 10-15 hp with headers on back-to-back dyno pulls.
Re: Dyno test 440 exhaust manifolds. [Re: 83hurstguy] #2899726
03/16/21 02:49 PM
03/16/21 02:49 PM
Results:
Given what the power output will be w/ a factory stock cam...10-15 hp w/ headers is still a big gain.
CHIP
Re: Dyno test 440 exhaust manifolds. [Re: ph23vo] #2899745
03/16/21 03:34 PM
03/16/21 03:34 PM
A727Tflite Offline
A727Tflite  Offline
Look again. Notice the pulsing.
Re: Dyno test 440 exhaust manifolds. [Re: an8sec70cuda] #2899751
03/16/21 03:47 PM
03/16/21 03:47 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Back in the day I recall 30-40 HP being tossed around by advertisers & bench-racers, but dynos & ET/MPH slips tell the truth.
Obviously, as the saying goes, "it's in the combination"; witness the F.A.S.T. guys for one example.
I recall a SoCal engine builder telling me (mid-90s) that his dyno headers were about 40 HP better than the headers that allowed a C/SA 440 to fit a '69 Cuda.
Some work ($$$) was needed to get some of that back.
The Maxie stuff in that test scored well, but those things are big, and heavy.
Re: Dyno test 440 exhaust manifolds. [Re: AndyF] #2899756
03/16/21 04:00 PM
03/16/21 04:00 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
Results:
iagree <---> this is where it is...... the correct cam and combo will help overcome the lack in exhaust efficiency . an effective cam would pick up the power on manifolds and there would be little if any from the addition of headers.......
Re: Dyno test 440 exhaust manifolds. [Re: topside] #2899797
03/16/21 05:50 PM
03/16/21 05:50 PM
Minn
SportF Offline
SportF  Offline
Minn
If you have ever lifted them you may be surprised. Max exhaust are heavy, but not nearly as heavy as they look.
Re: Dyno test 440 exhaust manifolds. [Re: ek3] #2899817
03/16/21 07:12 PM
03/16/21 07:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Results:
you’re both missing the point, it wasn’t an all out dyno session of many combination of parts, just three different exhaust types and how they worked on THAT engine. Heck he could’ve put Indy heads, roller cams, you name it, the purpose wasn’t for extracting every bit of HP, just what if. Take what he did and go have a coffee break. Sheesh
Re: Dyno test 440 exhaust manifolds. [Re: cudaman1969] #2899824
03/16/21 07:28 PM
03/16/21 07:28 PM
Results:
We're not missing the point, we know what the point is since we've done it ourselves many times. I can do a dyno test just like that and have very little difference between HP manifolds and headers. I can also run a dyno test where there is a big difference between manifolds and headers. The test itself is kind of meaningless since it can easily be rigged to provide a wide range of answers. I can do the same thing with rocker arm ratios. I can "prove" that rocker arm ratio doesn't matter or I can "prove" that it matters a lot. All I have to do is use a different camshaft. And if I don't tell anyone what cam is in the motor then most guys won't know the difference. They'll just accept what the magazine article says as fact.
