Dyno test 440 exhaust manifolds.
#2899626
03/16/21 10:56 AM
03/16/21 10:56 AM
Posts: 2,532 God's Country Maryland
GODSCOUNTRY340
Nick's Garage just dyno tested a 440 using factory HP exhaust manifolds, max wedge manifolds and headers. Results: HP manifolds---- 375 horsepower------ torque- 389 Max Wedge------ 410 HP ----------------- torque-446 Headers ---------- 419 HP ----------------- torque-463 The headers (1 7/8" tubes) increased 44 horsepower. Back in the day everybody claimed they only gave you 15 more horses.
Re: Dyno test 440 exhaust manifolds.
[Re: GODSCOUNTRY340]
#2899632
03/16/21 11:05 AM
03/16/21 11:05 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
And I still hear guys today saying the HP manifolds are just as good as headers, lol. Of course they are always the car show type...scared to have to prove anything.
#2899639
03/16/21 11:28 AM
03/16/21 11:28 AM
Posts: 31,066 Oregon
AndyF
Nick's Garage just dyno tested a 440 using factory HP exhaust manifolds, max wedge manifolds and headers. Results: HP manifolds---- 375 horsepower------ torque- 389 Max Wedge------ 410 HP ----------------- torque-446 Headers ---------- 419 HP ----------------- torque-463 The headers (1 7/8" tubes) increased 44 horsepower. Back in the day everybody claimed they only gave you 15 more horses. All depends on the combination. Those dyno tests can be "rigged" by changing the camshaft. The results also will change a lot depending on the muffler and tailpipes that are used.
[Re: an8sec70cuda]
#2899644
03/16/21 11:35 AM
03/16/21 11:35 AM
Posts: 4,698 Wichita
GY3
Wichita
And I still hear guys today saying the HP manifolds are just as good as headers, lol. Of course they are always the car show type...scared to have to prove anything. I always invite car show guys to the dragstrip and they never show...
[Re: GY3]
#2899647
03/16/21 11:48 AM
03/16/21 11:48 AM
Posts: 1,848 South Bend
John Brown
South Bend
Car show types wouldn't like the Pure Stock Drags. Most of the cars there are show worthy, and will kick their ash on the strip to boot.
[Re: AndyF]
#2899654
03/16/21 12:11 PM
03/16/21 12:11 PM
GODSCOUNTRY340
Nick's Garage just dyno tested a 440 using factory HP exhaust manifolds, max wedge manifolds and headers. Results: HP manifolds---- 375 horsepower------ torque- 389 Max Wedge------ 410 HP ----------------- torque-446 Headers ---------- 419 HP ----------------- torque-463 The headers (1 7/8" tubes) increased 44 horsepower. Back in the day everybody claimed they only gave you 15 more horses. All depends on the combination. Those dyno tests can be "rigged" by changing the camshaft. The results also will change a lot depending on the muffler and tailpipes that are used. He didn't change anything on the engine except the manifolds. Go to Youtube and type in Nick's Garage, he's a Mopar guy too.
[Re: A727Tflite]
#2899682
03/16/21 01:22 PM
03/16/21 01:22 PM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
Watch the video - the aerial portion above the carbs.
Notice the fuel atomization differences between the three setups. more airflow = higher atomization!
[Re: A727Tflite]
#2899686
03/16/21 01:25 PM
03/16/21 01:25 PM
Posts: 8,337 fredericksburg,va
cudaman1969
fredericksburg,va
Notice the fuel atomization differences between the three setups. I saw that too, interesting. Glad someone posted the numbers, I couldn’t understand a thing he said lol. I’m guessing the difference between the Max and headers is the collector and length-size of tubes. But just bolt on stuff was cool.
#2899725
03/16/21 02:46 PM
03/16/21 02:46 PM
Posts: 88 IL
83hurstguy
IL
Nick's Garage just dyno tested a 440 using factory HP exhaust manifolds, max wedge manifolds and headers. Results: HP manifolds---- 375 horsepower------ torque- 389 Max Wedge------ 410 HP ----------------- torque-446 Headers ---------- 419 HP ----------------- torque-463 The headers (1 7/8" tubes) increased 44 horsepower. Back in the day everybody claimed they only gave you 15 more horses. All depends on the combination. Those dyno tests can be "rigged" by changing the camshaft. The results also will change a lot depending on the muffler and tailpipes that are used. He didn't change anything on the engine except the manifolds. Go to Youtube and type in Nick's Garage, he's a Mopar guy too. Andy's comment is valid... when you have a cam with a bunch of overlap, the power difference between manifolds and headers will be magnified - headers support scavenging and manifolds don't. As soon as I saw the vacuum gauge reading around 11 in-hg with a pretty lumpy idle, I knew you'd see a big difference. It was impressive to see the max wedge manifolds hang with the headers. When running a factory-type stock cam, I've seen engines only pick up 10-15 hp with headers on back-to-back dyno pulls.
[Re: 83hurstguy]
#2899726
03/16/21 02:49 PM
03/16/21 02:49 PM
an8sec70cuda
Nick's Garage just dyno tested a 440 using factory HP exhaust manifolds, max wedge manifolds and headers. Results: HP manifolds---- 375 horsepower------ torque- 389 Max Wedge------ 410 HP ----------------- torque-446 Headers ---------- 419 HP ----------------- torque-463 The headers (1 7/8" tubes) increased 44 horsepower. Back in the day everybody claimed they only gave you 15 more horses. All depends on the combination. Those dyno tests can be "rigged" by changing the camshaft. The results also will change a lot depending on the muffler and tailpipes that are used. He didn't change anything on the engine except the manifolds. Go to Youtube and type in Nick's Garage, he's a Mopar guy too. Andy's comment is valid... when you have a cam with a bunch of overlap, the power difference between manifolds and headers will be magnified - headers support scavenging and manifolds don't. As soon as I saw the vacuum gauge reading around 11 in-hg with a pretty lumpy idle, I knew you'd see a big difference. It was impressive to see the max wedge manifolds hang with the headers. When running a factory-type stock cam, I've seen engines only pick up 10-15 hp with headers on back-to-back dyno pulls. Given what the power output will be w/ a factory stock cam...10-15 hp w/ headers is still a big gain.
[Re: ph23vo]
#2899745
03/16/21 03:34 PM
03/16/21 03:34 PM
Posts: 3,089 Michigan
A727Tflite
Notice the fuel atomization differences between the three setups. more airflow = higher atomization! Look again. Notice the pulsing.
[Re: AndyF]
#2899756
03/16/21 04:00 PM
03/16/21 04:00 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
Nick's Garage just dyno tested a 440 using factory HP exhaust manifolds, max wedge manifolds and headers. Results: HP manifolds---- 375 horsepower------ torque- 389 Max Wedge------ 410 HP ----------------- torque-446 Headers ---------- 419 HP ----------------- torque-463 The headers (1 7/8" tubes) increased 44 horsepower. Back in the day everybody claimed they only gave you 15 more horses. All depends on the combination. Those dyno tests can be "rigged" by changing the camshaft. The results also will change a lot depending on the muffler and tailpipes that are used. <---> this is where it is...... the correct cam and combo will help overcome the lack in exhaust efficiency . an effective cam would pick up the power on manifolds and there would be little if any from the addition of headers.......
[Re: ek3]
#2899817
03/16/21 07:12 PM
03/16/21 07:12 PM
cudaman1969
fredericksburg,va
Nick's Garage just dyno tested a 440 using factory HP exhaust manifolds, max wedge manifolds and headers. Results: HP manifolds---- 375 horsepower------ torque- 389 Max Wedge------ 410 HP ----------------- torque-446 Headers ---------- 419 HP ----------------- torque-463 The headers (1 7/8" tubes) increased 44 horsepower. Back in the day everybody claimed they only gave you 15 more horses. All depends on the combination. Those dyno tests can be "rigged" by changing the camshaft. The results also will change a lot depending on the muffler and tailpipes that are used. <---> this is where it is...... the correct cam and combo will help overcome the lack in exhaust efficiency . an effective cam would pick up the power on manifolds and there would be little if any from the addition of headers....... you’re both missing the point, it wasn’t an all out dyno session of many combination of parts, just three different exhaust types and how they worked on THAT engine. Heck he could’ve put Indy heads, roller cams, you name it, the purpose wasn’t for extracting every bit of HP, just what if. Take what he did and go have a coffee break. Sheesh
[Re: cudaman1969]
#2899824
03/16/21 07:28 PM
03/16/21 07:28 PM
AndyF
Nick's Garage just dyno tested a 440 using factory HP exhaust manifolds, max wedge manifolds and headers. Results: HP manifolds---- 375 horsepower------ torque- 389 Max Wedge------ 410 HP ----------------- torque-446 Headers ---------- 419 HP ----------------- torque-463 The headers (1 7/8" tubes) increased 44 horsepower. Back in the day everybody claimed they only gave you 15 more horses. All depends on the combination. Those dyno tests can be "rigged" by changing the camshaft. The results also will change a lot depending on the muffler and tailpipes that are used. <---> this is where it is...... the correct cam and combo will help overcome the lack in exhaust efficiency . an effective cam would pick up the power on manifolds and there would be little if any from the addition of headers....... you’re both missing the point, it wasn’t an all out dyno session of many combination of parts, just three different exhaust types and how they worked on THAT engine. Heck he could’ve put Indy heads, roller cams, you name it, the purpose wasn’t for extracting every bit of HP, just what if. Take what he did and go have a coffee break. Sheesh We're not missing the point, we know what the point is since we've done it ourselves many times. I can do a dyno test just like that and have very little difference between HP manifolds and headers. I can also run a dyno test where there is a big difference between manifolds and headers. The test itself is kind of meaningless since it can easily be rigged to provide a wide range of answers. I can do the same thing with rocker arm ratios. I can "prove" that rocker arm ratio doesn't matter or I can "prove" that it matters a lot. All I have to do is use a different camshaft. And if I don't tell anyone what cam is in the motor then most guys won't know the difference. They'll just accept what the magazine article says as fact.
