Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: mopargem] #2897576
03/09/21 11:03 PM
03/09/21 11:03 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
Originally Posted by mopargem
If it’s a big block you can use the same mountingbrackrt from 440 motor homes. It bolts to the rear vally pan rail and is made for the box to mount to
Won't work on this big block. Hemi's don't have pan rails...
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2897590
03/10/21 12:20 AM
03/10/21 12:20 AM
KY USA
mopargem Online tonguue
mopargem  Online Tonguue
KY USA
Nope! 71 Hemi too rare to use a motor home bracket anyway lol did you just get that car?nice
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2897632
03/10/21 08:54 AM
03/10/21 08:54 AM
E
earlymopar Offline
earlymopar  Offline
E
I run an MSD boost-control module and have it mounted to the floor under the driver's seat.
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: mopargem] #2897638
03/10/21 09:23 AM
03/10/21 09:23 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
That space is already taken on mine..
'63 Dodge 330
11.19 @ 121 mph
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2897644
03/10/21 09:45 AM
03/10/21 09:45 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted by RSI700VIPER
I like the factory stock look under the hood, but I also like the reliability and low maintenance of an electronic ignition system. I once hid a control box in the washer reservoir on a '69 Charger but that was easy since it's essentially a hollow box sitting on top of the inner fender. I would prefer not to mount the box under the dash but will do if necessary. I would also prefer not to mount it under the battery tray. So where is everyone hiding their boxes on a '71 B-Body?
first... WHICH ignition control box ?
if using a Stock kind Ignition box, there is a bracket to be attached on rear rail of the block ( if BB )
71 B body gets plenty of room on fender behind the headlights thought!
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2897647
03/10/21 09:51 AM
03/10/21 09:51 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Well, looks like there was just enough room inside the long thin washer reservoir. Petronix is good but I like the added features of the Rev-in-ator box.
Oh, just noticed is a Rev-N-Nator!
nice place to hide it!
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: mopargem] #2897648
03/10/21 09:52 AM
03/10/21 09:52 AM
NW New Jersey
NW New Jersey
Mopargem - I bought it a few months back. Just giving the ole girl a facelift under the hood and tinkering to fit my interest up
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: GY3] #2897712
03/10/21 12:35 PM
03/10/21 12:35 PM
NW New Jersey
NW New Jersey
SWEET!
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: NachoRT74] #2897717
03/10/21 12:58 PM
03/10/21 12:58 PM
NW New Jersey
NW New Jersey
I would have thought putting the box there would be too close to a heat source, no?
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: NachoRT74] #2897718
03/10/21 12:59 PM
03/10/21 12:59 PM
NW New Jersey
NW New Jersey
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2897773
03/10/21 03:31 PM
03/10/21 03:31 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
RS -- I have always had my ECU (chrome Chrysler box) relocated under the dash.. actually just above the pedals... out-of-sight... just had to extend and splice the wires from the control box. Also, by getting out of the engine bay, not only does it appear stock, but the ECU stays cooler as is needed. I've had it this way since about 1978 on my car (Challenger). There are circular grommeted holes for the wires under the master brake firewall assembly that I've passed the wires through. The ECU is simply screwed to the inside firewall above the brake pedal area... out-of-sight.
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: Mopar Mitch] #2897984
03/10/21 11:14 PM
03/10/21 11:14 PM
NW New Jersey
NW New Jersey
Mitch,
Plan B was to go under the dash. You might not know but the Revinator has a button on the box to set the RPM limit. Is it easier to climb under dash and push the button or pop 3 screws under the hood? Guess it depends on your age and flexibility. I'm older (59) and not as flexible so under hood it is.
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2898387
03/12/21 11:34 AM
03/12/21 11:34 AM
Mopar Mitch Offline
Mopar Mitch  Offline
RS -- As for the Rev-Limiter feature, set-it and forget it after you determine the max RPM limit. I have an adjustable Mallory RPM tach that I use for setting the limits.
I'm fortunate to still be flexible.. at 64.. and stay fit best as possible...
