Re: Modern Bullitt build
[Re: NITROUSN]
#2904875
04/01/21 11:03 AM
04/01/21 11:03 AM
Posts: 676 Maryland
Keepat
Maryland
Very nice. Any pics on the antenna motor mounting? Hard to see in the picture but I had to make a small L bracket to hold the motor Thanks image post
[Re: larry4406]
#2905441
04/02/21 03:55 PM
04/02/21 03:55 PM
Posts: 676 Maryland
Keepat
Maryland
That retract antenna is a nice find!
Pat this build is absolutely top notch. I can't get over how well executed every thing is on this build. The planning and workmanship is amazing.
Thanks for showing your work. Larry, thanks for following along with this 7 year build and for your kind comments! The project is getting closer to the end and I’m looking forward to driving it soon! Thank You! Pat
[Re: Keepat]
#2906497
04/04/21 07:15 PM
04/04/21 07:15 PM
Posts: 9 Vancouver,BC
Mopar300F
Vancouver,BC
Will there be a separate switch for the Antennae of will it extend and retract when the radio is on/off? My dad had a 68 New Yorker with power antennae and there was a switch on the dash near the radio.
[Re: Mopar300F]
#2906562
04/04/21 09:10 PM
04/04/21 09:10 PM
Posts: 676 Maryland
Keepat
Maryland
Will there be a separate switch for the Antennae of will it extend and retract when the radio is on/off? My dad had a 68 New Yorker with power antennae and there was a switch on the dash near the radio. The new but original looking stereo has a power antenna output. Thanks Pat
[Re: Keepat]
#2911356
04/17/21 02:59 PM
04/17/21 02:59 PM
Posts: 676 Maryland
Keepat
Maryland
My LO horn is bad, looking for a replacement Prestolite horn. Please see picture for part numbers. I’m not concerned with date code but would like to have the same horn. Thanks Pat
[Re: Neil]
#2911366
04/17/21 03:45 PM
04/17/21 03:45 PM
Posts: 676 Maryland
Keepat
Maryland
Just the grainy texture that is the issue? If the horn still works I'd just work the surface smooth with primer/sanding and repaint it. No, does not work.
[Re: Neil]
#2911395
04/17/21 06:08 PM
04/17/21 06:08 PM
Posts: 676 Maryland
Keepat
Maryland
Sorry, my mistake. I see they sell reproduction horns in sets, but they appear to be the Spartan type. Yes I think classic industries sells them. But I really like to keep the same style horn as the old one that still works. Thank you!
[Re: Mopar300F]
#2911396
04/17/21 06:08 PM
04/17/21 06:08 PM
Posts: 676 Maryland
Keepat
Maryland
I have read you can get a stuck horn working again by spraying WD40 into it. I will give that a try! Thank you! Pat
[Re: DynoDave]
#2911606
04/18/21 12:31 PM
04/18/21 12:31 PM
Posts: 676 Maryland
Keepat
Maryland
The carbon fiber piece is sexy looking. Is that commercially available, or did you make it / have it made? What is the motor in this picture? Replaced the vacuum canisters with electric motors to operate the headlight doors. Thanks
[Re: Neil]
#2911607
04/18/21 12:35 PM
04/18/21 12:35 PM
Posts: 676 Maryland
Keepat
Maryland
Good stuff! Thanks for posting the link, I will give it a try! Pat
