Piston to head minimum? #2895200
03/03/21 01:27 PM
03/03/21 01:27 PM
gregsdart Offline OP
Looking for input on where i should set piston to head clearance. 440-1 heads, molnar 7.1 h beams, Gibtech custom pistons line2line coated, stroke 4.315, bore 4.500. Power should be 925 hp, shift at 7400 max rpm 7600 rpm limit, trap rpm 7500 max. Digital 7 MSD for a rev limiter. What have you run at 4.5 bore and 7500 rpm?
Re: Piston to head minimum? [Re: gregsdart] #2895211
03/03/21 01:48 PM
03/03/21 01:48 PM
I haven't ran that bore size but I have seen witness marks on my heads with .035 P to head clearances and not with .040 clearances shruggy
Those were a set of Ross custom race pistons with around .0080 piston to cylinder wall clearances on my old pump gas stroker motor, those witness marks were on the cam side and motor mount side only so they were close when firing when they reversed directions with combustion pressure on them shruggy work
I'm of the opinion that with the street alloy you can run them a tiny bit closer than with the looser race alloy work
Your choice on this up
Re: Piston to head minimum? [Re: Cab_Burge] #2895322
03/03/21 06:35 PM
03/03/21 06:35 PM
Cab due to the large bore i am guessing .040 may or may not be safe. I was running .045 with the iron block. I assume i can go .040 cold with the aluminum block? Never run one before.
Re: Piston to head minimum? [Re: gregsdart] #2895372
03/03/21 07:54 PM
03/03/21 07:54 PM
On my deal I would rock the pistons over both ways to get the piston edges up as high as they would go at TDC use that for making .035 and .040.
I've never warmed up a aluminum block enough to see how much the deck of the block grows in height in relation to the sleeves, rods and pistons at TDC from room temps to above 160 F work
Re: Piston to head minimum? [Re: Cab_Burge] #2895396
03/03/21 08:53 PM
03/03/21 08:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
For sure .050" clears.
Doug
Re: Piston to head minimum? [Re: gregsdart] #2895410
03/03/21 09:42 PM
03/03/21 09:42 PM
WA
JD Dart Offline
JD Dart  Offline
WA
II run .040 with 4.5 bore Indy block no witness marks. Thru the traps at 7700
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Piston to head minimum? [Re: JD Dart] #2895414
03/03/21 10:03 PM
03/03/21 10:03 PM
JD is that an aluminum block? Steel rods? Stroke?
Re: Piston to head minimum? [Re: gregsdart] #2895423
03/03/21 10:49 PM
03/03/21 10:49 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I think the rule that with steel rods, .040 is ideal and .060 for aluminum rods is pretty much spot on, first from my personal experience. And a few years ago I built a 512, with a world products aluminum block, aluminum rods, and aluminum heads. I knew the .060 rule for those rods, but I pondered about the aluminum block and it's affect on the clearance. WELL, my son is a mechanical engineer and I called him and asked him to calculate the required clearance, he said he needed the aluminum alloy numbers, and some other measurements, after he did the calculations, he came up with .058 for my engine. So I just figure the .060 is a pretty iron clad result.
Re: Piston to head minimum? [Re: jwb123] #2895492
03/04/21 06:31 AM
03/04/21 06:31 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've run BME 426 forgings at..055" at 4.500" with no issues.
Doug
Re: Piston to head minimum? [Re: JD Dart] #2895576
03/04/21 11:41 AM
03/04/21 11:41 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The consensus on what is a safe number is going to be .050" for an aluminum rod and .040" for a steel rod. The reason being is you need to have some "wiggle" room. Things many don't account for is skirt design, and piston to wall, as well as ensuring the stroke is equal on all cylinders and the type of material used for the rods etc. So I think you will find those to be the most common numbers thrown around out there.
I have run as little as .040" aluminum block aluminum rod with no issues on my sruff. We run the Vette even tighter at .033" with an aluminum block and rods too at 10,000rpm. But alot of things have to be perfect to get away with that tight of a clearance. When trying to get to 18-1 compression you have little choice but to push things a bit.
Re: Piston to head minimum? [Re: gregsdart] #2895661
03/04/21 02:24 PM
03/04/21 02:24 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Aluminum block Molnar steel rods 4.250 stroke
Re: Piston to head minimum? [Re: JD Dart] #2897152
03/08/21 04:12 PM
03/08/21 04:12 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have run as low as .028 in a SB with no contact. That being said, it's gonna depend on bore size, and bore clearance, bearing clearance, rod material and RPM. Also remember on an aluminum block the clearance with steel rods will grow as it warms up, aluminum rods should grow at a similar rate and keep clearance about the same.
Re: Piston to head minimum? [Re: HotRodDave] #2897213
03/08/21 08:28 PM
03/08/21 08:28 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The lightest contact (-.001") won't even leave witness marks. It may slightly collapse the normal .006" ring to groove vertical clearance and reduce ring seal. If it continues the land will fracture.
There are too many variables to have more than a range.
A 2" long skirt, .001" wall clearance, 2:1 rod ratio, and 3.50" bore with pin offset can run tighter than 1" long skirt, .005" wall clearance, 1.5:1 rod ratio, and 4.60" bore with centered pin.
Boffin Emeritus
Re: Piston to head minimum? [Re: HotRodDave] #2897304
03/09/21 06:55 AM
03/09/21 06:55 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
[i][/i]Greg, I had .042 head gaskets and zero deck clearance on my 528, I over revd it once to 8200. I ended up with witness marks on the heads.
Re: Piston to head minimum? [Re: quickd100] #2897584
03/09/21 11:31 PM
03/09/21 11:31 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
With a .039 head gasket I like to put the piston .003 - .005 in the hole. .000 deck with a .045 gasket.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
