Re: Valvetrain issues
[Re: clovis]
#2901312
03/21/21 11:49 AM
03/21/21 11:49 AM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Have you measured the lift at the valve, with zero lash to see what the effective rocker ratio is now?
[Re: clovis]
#2901315
03/21/21 11:54 AM
03/21/21 11:54 AM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
Springs are all installed, most came in about 1.81-1.83 and that puts them between 150-155 on the seat.
Went ahead and milled the hold downs and got everything shimmed and spaced. I installed the new shaft spacers and mocked up a pair of rockers to measure the scrub and see how everything lined up. With the shaft spacer (+.150) the rocker tip is fairly centered on the valve, the adjusters are about 1.5 threads out and looks like it will allow oil to reach inside the pushrod cup. The scrub, the best I can measure is coming in between .035-.037, so a significant improvement over my previous .135 and not too far off the theoretical ideal of .031.
The only thing that seems strange is the pattern on the exhaust valve is not all the way across. I measured several times and each time it would be the same partial pattern. I am only rolling it over 720* by hand to get the pattern and I am running about .025 rocker clearance. I checked a few time to ensure the rocker was centered over the valve, so I am unsure what the cause is.
Everything is better with pictures Spin the valve 180 deg & see if it changes, the valve tip might be faced at an angle,
[Re: CSK]
#2901448
03/21/21 09:43 PM
03/21/21 09:43 PM
Posts: 553 Kentucky
clovis
Kentucky
CSK, good call on turning the valve that seemed to do the trick. I did try another rocker before turning the valve but it didn’t change the one sided valve mark.
Fast, I got a chance this afternoon to measure the lift. I got .583 with no lash, so that would put the ratio at 1.606. At this point, I am going to put the rockers back on and move to the next project - installing an AFR gauge.
I appreciate everyone’s help.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#2901537
03/22/21 10:35 AM
03/22/21 10:35 AM
fast68plymouth
So. Burlington, Vt.
I think you’ll find it revs much easier/higher than it did before.
