Re: EFI port injection on a tunnel ram.
[Re: Bad340fish]
#2893906
02/27/21 10:04 PM
02/27/21 10:04 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
My EFI street car, works awesome,
[Re: AndyF]
#2894098
02/28/21 03:51 PM
02/28/21 03:51 PM
Posts: 4,647 aotearoa
rebel
aotearoa
Unless you really like doing stuff the hard way you should just sell that manifold and buy a new one from Indy that is already drilled and set up for fuel rails. If you insist on doing it the hard way I can sell you a kit of bungs and fuel rails that you can have installed on your existing manifold. You'll need to find someone who can TIG weld aluminum. I'll have to go the hard way Andy, this manifold is for a B engine & 2 months ago, ICH told me they were out of stock & was unknown when they would have stock. Whats the price on your bung & rail set?, tig welding is easy as well as getting any machining done, thats what friends are for right?
[Re: rebel]
#2894277
03/01/21 07:05 AM
03/01/21 07:05 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
EFI does not increase HP, unless your tune is out to lunch or your carb is too small, which is probably not your issue.....Add a Sniper 4500...have fun.
