Re: Freighter throws rods and destroys engine compartment [Re: jcc] #2893857
02/27/21 07:34 PM
02/27/21 07:34 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
We replaced a feedwater heater in the plant I used to work at. We used a heavy lifting firm whose primary business was removing diesel engines from ships to remove the old heater out and the new heater in. They had a modular skidding arrangement that pinned together to form a track. Each rail of the track had cross pins and they had a hydraulic apparatus that was fastened to the heater. The hydraulics engaged the cross pins in the track and literally pulled the heater along the track. Looked like a small railroad. In talking to the foreman what they typically did in ships was have an access hole cut in the side, they'd assemble the track, and then skid the engine(s) sideways out of the ship. I looked for some pictures of the setup but I must have lost them over the years.
Re: Freighter throws rods and destroys engine compartment [Re: 6PakBee] #2893911
02/27/21 10:25 PM
02/27/21 10:25 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Jack and slide. They use the same equipment to move big transformers.
Kevin
Re: Freighter throws rods and destroys engine compartment [Re: cudaman1969] #2894561
03/01/21 08:12 PM
03/01/21 08:12 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
Originally Posted by cudaman1969
Should of had a man standing beside that mess t show the size of engine
Here's a couple
Piston check
Crank replacement
Piston replacement
Engine removal
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: Freighter throws rods and destroys engine compartment [Re: 300rag] #2894584
03/01/21 09:45 PM
03/01/21 09:45 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
That was fascinating Thank you.
Curious as to what rod ratios are in play here, with that one crank, I'm guessing in way over the 5:1 range.
That crank change out rigging dance looked to be a bit sketchy, but they got it done.
The red suited crews definitely are trained for safety awareness.
The last video, piston swap crew, not so much.
Impressive. up
Re: Freighter throws rods and destroys engine compartment [Re: jcc] #2895125
03/03/21 09:27 AM
03/03/21 09:27 AM
USA
K
Kippy Offline
Kippy  Offline
K
USA
Ship will go into dry dock and the yard will cut out whatever is needed to remove and install a new block. I worked in ship repair for 20 plus years, granted on much smaller vessels, we gained access to the DC motors by cutting the main deck right above the motor room. We also on occasion removed ship service generators the same way. I never saw the deck above one of the four V 16 engines cut open on any of our ships to remove them. The machinists would remove power packs using a overhead trolley. They would replace main bearings through the crankcase side covers. All the welding and fit up is inspected by American Bureau of Shipping. All the welders have to pass ABS tests.
When I first started there I was told all repairs were done in house at one time. They had a armature winding shop and the last armature winder had just retired and he was not replaced. All the valves that leaked were rebuilt, babitt bearings were repoured and machined. I found moulds in a storage building and I was told many decades ago they even made parts from those moulds
No matter how much a [censored] a guy was, how much a lazy worker he was the work done was done to a high quality. Nobody wanted anything they did to fail. The last thing anyone wanted to happen was have a ship lose power while underway. Or have anything happen to put the thousands of passengers in peril
I think to some degree that's all changed
