Re: combo/cam help
[Re: Furious67]
#2893024
02/25/21 01:40 PM
02/25/21 01:40 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
To go along with the new heads, intake, headers, gears........ Iād suggest a 750 double pumper type carb, the Hughes Whiplash cam, and a decent 9.5ā or 10ā converter.
68 Satellite, 383 with stock 906ās, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
Re: combo/cam help
[Re: Furious67]
#2893033
02/25/21 02:16 PM
02/25/21 02:16 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
I would build the current 400 motor into a 4.250 stroke stroker motor after having it sonic tested to make sure you end up with at least .150 cylinder wall thickness on the cam side and motor mount sides of all 8 cylinders. The 400 blocks have a lot thicker main webbing and you can crack the 440 main webs a lot easier than the 400 block I would and do use either 6.700 or 6.800 good brand long H beam rod to safely make 600+ HP on pump swill As far as the cam to use I like big ones On the exhaust system I would and do use a 3.0 pipes from the collectors to the 3.0 inlet and outlet high flow muffs. You need a good converter to work well at the track and driving to the races, I like and do use a good 8 inch Not a cheap one My first "drag race only car" was a 1960 Dodge Phoenix that weighed 4050 lbs. without me in it, I traded a 1955 Chrysler Fire Power 331 C.I. Hemi and installed into the guys roadster for a stroker 383 motor (unknown the true C.I., I was told it had a welded up 413 crank that had a 4.250 stroke and bored to 4.310 ) that I put a stock type dual 4 barrel set up on that motor. That car ran 12.80 on a set of J.C. Penney 7x26x14 slicks, yes they sold them for a while back in the late 1960s. That was with a stock cast iron torqeflyte and stock low stall converter with 3.73 gears and no posi . I was very happy with those results Good luck on your build Make sure and degree the cam and verify the compression ratio on all 8 cylinders
Re: combo/cam help
[Re: fast68plymouth]
#2893046
02/25/21 02:35 PM
02/25/21 02:35 PM
Posts: 12,243 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
With those changes, the OP is gonna need some more traction, too. Launching well over 4,000lbs is gonna take more tire, U joints, Sure-Grip, shocks, maybe better springs and other traction aids. And you'll find out how sound that 727 is, too.
Getting that old boat into the 13s is certainly doable. But not with many of the grocery-getter 318 parts still aboard. The original 318 had maybe 200 - 225hp. According to the Wallace calculators, the Fury will need about 125 more horsepower to hit the high 13s. Probably even more unless the combo is well balanced.
Master, again and still
Re: combo/cam help
[Re: Furious67]
#2893060
02/25/21 03:04 PM
02/25/21 03:04 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
This deal will need a lot of help . the weight and altitude are killers. I calculated 4300 weight and 13.00 et to come up with a hp figure of 385 crank hp. To run the number you will need to do cam, heads, headers , high stall converter (4000 rpm or more) at least 3.91 gears and slicks to get there. If you spend the $$ to get heads for your future build you can gain compression and airflow big time. Check out MARSH PERFORMANCE sidewinder heads. Todd is great to deal with and can help you with a cam also. The plan IMHO should be to spend the$$$ on what can transfer to the next motor. The 400 is the motor you want to stroke. A 499 cube stroker that has 10/1 compression can run on pump gas with aluminum heads. And 500 + hp is a piece of cake.
