Removing weight from a crankshaft?
#2892895
02/24/21 11:43 PM
02/24/21 11:43 PM
Posts: 9,560 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Ive a crankshaft thats going to need approx 330 grams removed to balance it out.
When I toss it in the lathe to remove some from the counterweights is there any way to determine how much to remove or at least not go too far?
TIA!
STOP POTATO HATE!
Re: Removing weight from a crankshaft?
[Re: Mr PotatoHead]
#2892903
02/25/21 12:35 AM
02/25/21 12:35 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
I believe the counterweights are drilled to add or drilled to remove.
China is the enemy.
[Re: dvw]
#2892928
02/25/21 06:20 AM
02/25/21 06:20 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Trouble with turning the counter weights is if the amount you need to remove isn't in the center of the counter weight itself. Leave yourself some extra weight to fudge it. Doug My crank was enitially balanced by Crower by machining counter weights down. But like Doug stated, you will have to cut a little, check the balance, and repeat as needed till you gain more experiance in balancing that way.
[Re: gregsdart]
#2892988
02/25/21 11:33 AM
02/25/21 11:33 AM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Thank you for the informative replies.
Pretty grey area for me. What im wondering about is drilling 330 grams out of a scat cast crank extreme?
I use to have the approx figures of how much weight was removed by drilling but can no longer find them.
Thanks.
STOP POTATO HATE!
[Re: Scully]
#2893239
02/25/21 11:15 PM
02/25/21 11:15 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
[Re: Scully]
#2893240
02/25/21 11:21 PM
02/25/21 11:21 PM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Thats what my intentions were was to take a bit off for less drilling. The weights simple, lightweight scat I beams and small bore short skirt stroker pistons. Crank should be 2050 from the box and I was using approx weight from a similar build and with the parts I will use im getting 1698 grams. So in reality im looking at shedding 350 grams. How did you come up with a figure of 330 grams. You can cut the counter weights down a little but you need to leave enough weight there to be able to drill where it is needed.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2893259
02/26/21 12:09 AM
02/26/21 12:09 AM
Posts: 201 PA
Scully
PA
Thats what my intentions were was to take a bit off for less drilling. The weights simple, lightweight scat I beams and small bore short skirt stroker pistons. Crank should be 2050 from the box and I was using approx weight from a similar build and with the parts I will use im getting 1698 grams. So in reality im looking at shedding 350 grams. You can shed that weight but it might not be in the right place, I have a crank balancer in my shop and have done many balance jobs. You might get lucky, you might not, probably not, IMO. How did you come up with a figure of 330 grams. You can cut the counter weights down a little but you need to leave enough weight there to be able to drill where it is needed.
[Re: AndyF]
#2893263
02/26/21 12:35 AM
02/26/21 12:35 AM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Andy I have the lathe but not the machine. My lathe is old old but still good enough I used to cut my own cam blanks and send them to crane for lobes.
I guess what im getting at is this.... can they drill 350 grams out of the crank? Yea I could call and ask but if I dont get the one guy who does my work im not gonna get good info.
I do have a option im not thrilled about it though as id like to use the scat rods, ive a nice worked set of old dc 340 rods that are a bit lighter then stock 340 rods I just put arp-s but would need to get them resized which would put me at 1972 grams on the 2050 crank so that would be an easy balance.
STOP POTATO HATE!
[Re: AndyF]
#2893268
02/26/21 01:15 AM
02/26/21 01:15 AM
Posts: 201 PA
Scully
PA
The math is easy if you use 100 grams per cubic inch for steel. If it was me I'd cut 3 cubic inches off the counterweights and then spin it on the balancer. 3 cubic inches is probably less than 0.100 of depth but you need to measure the length and width of your counterweights to be sure. Do you have a rigid setup on your lathe that will let you cut the counterweights without chatter? We tried some different setups over time and eventually hit on a carbide cutter and a feed and speed combination that produces a mirror finish with very little noise. But the setup has to be dialed in and rigid.
131.72 grams per CI
[Re: Scully]
#2893345
02/26/21 12:13 PM
02/26/21 12:13 PM
Posts: 31,073 Oregon
AndyF
131.72 grams per CI Yes I know. But the math is easier if you use 100 grams. The final 30 grams per cubic inch is taken off either by drilling or hand shaving. You want to leave it a little heavy when it comes off the lathe since balance point usually has to be moved a little off center.
[Re: AndyF]
#2894039
02/28/21 12:44 PM
02/28/21 12:44 PM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Hi folks, Read this a few times now about 440 cranks in a 400 block! I heard it’s approximately 0.125 of an inch. Is that the depth or overall off the diameter? Wonder how much weight that actually is? I was gonna use aluminium rods anyways, so that’s cool...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
