Re: Collector Extension [Re: Kindafast] #2898849
03/13/21 09:48 PM
03/13/21 09:48 PM
BigFish69 Offline
BigFish69  Offline
did you change the collector or just add extension.
Re: Collector Extension [Re: BigFish69] #2898851
03/13/21 10:00 PM
03/13/21 10:00 PM
BigFish69 Offline
BigFish69  Offline
I have a set of hooker headers 1 5/8 with 360-1 head planning on a new set 1 7/8 in the future I was considering cutting off the 3 in collector and replacing it with 3 1/2 wondering if that would help or hurt the scavenging
Re: Collector Extension [Re: BigFish69] #2898852
03/13/21 10:05 PM
03/13/21 10:05 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
[quote=BigFish69]did you change the collector or just add extension. [/quote
I didn't change the collector. TTI Had 3.5" Collector. I just added 18" 3.5" extension. Really happy with the pick up.
6.50 @105.26
Re: Collector Extension [Re: Wirenut] #2898967
03/14/21 10:42 AM
03/14/21 10:42 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Originally Posted by Wirenut
Been thinking about this myself .
So if you run crankcase evacs do you move them to the end of the extension , or leave them in the collector?
Evac tubes stay put............gas velocity is fastest just past the merge and you generate the most negative pressure there.
Re: Collector Extension [Re: Kindafast] #2899096
03/14/21 04:40 PM
03/14/21 04:40 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Look into these extensions. Hendren Racing anti-reversion mufflers
Re: Collector Extension [Re: Kindafast] #2899278
03/15/21 10:31 AM
03/15/21 10:31 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Awesome! I bet you're feeling better now!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Collector Extension [Re: an8sec70cuda] #2899332
03/15/21 12:36 PM
03/15/21 12:36 PM
Seaford, Va
Seaford, Va
Yes sir I am. All last year I backed up and went slower. LOL it was nice to see an improvement starting this year . Thanks
6.50 @105.26
Re: Collector Extension [Re: Kindafast] #2901012
03/20/21 10:32 AM
03/20/21 10:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I thought I remembered years ago when racers ran collector extensions that they used to say cut it off where you see it making a ring on the collector ? I believe these were 24" collectors but I never tried it. Ron
